Old 10-10-2006, 03:54 PM   #1 (permalink)
Manch-GTA's Avatar
Removing the Battery from the car
Has anyone removed the battery from the car?
If so, how can you get it out without removing the panel or other items in the way?
Manch-GTA is offline   Reply With Quote
Old 10-10-2006, 03:55 PM   #2 (permalink)
compression's Avatar
you cannot. you have to remove that whole "fender" it isnt hard at all. I didnt it all in about 30mins with putting it back together.
Why do you want to remove it ?
New Paint and wider rear end is done.
Now it is time for a NEW HEART.
compression is offline   Reply With Quote
Old 10-10-2006, 04:08 PM   #3 (permalink)
dylan01's Avatar
Send a message via MSN to dylan01
Yea Compression is right,
you gotta take off the whole side panel/fender to get at the battery.
I think Manch is takign it out for the winter right! Im doing the same!
(cant leave a battery out in minus 30 degrees (where im storing mine) )
2006 Pontiac Solstice
VIN 1,715
dylan01 is offline   Reply With Quote
Old 10-10-2006, 04:49 PM   #4 (permalink)
Manch-GTA's Avatar
Yeah.. want to put it inside, instead of outside for the winter.
Which is easier to remove, the fender or small metal panel?
Old 10-10-2006, 04:51 PM   #5 (permalink)
I took out the whole "fender"
like I said it wasnt hard at all.
Old 10-10-2006, 05:15 PM   #6 (permalink)
Small Dealer's Avatar
Here is the current procedure from the on-line version of the 2006 Solstice Service Manual
Battery Replacement
Removal Procedure
1.) Disconnect the negative battery cable (2). Refer to Battery Negative Cable Disconnect Procedure .
Battery Negative Cable Disconnection
Caution: Refer to SIR Caution in Cautions and Notices.
SIR Caution
Caution: When performing service on or near the SIR components or the SIR wiring, the SIR system must be disabled. Refer to SIR Disabling and Enabling . Failure to observe the correct procedure could cause deployment of the SIR components, personal injury, or unnecessary SIR system repairs.
Caution: Refer to Battery Disconnect Caution in Cautions and Notices.
Caution: Before servicing any electrical component, the ignition and start switch must be in the OFF or LOCK position and all electrical loads must be OFF, unless instructed otherwise in these procedures. If a tool or equipment could easily come in contact with a live exposed electrical terminal, also disconnect the negative battery cable. Failure to follow these precautions may cause personal injury and/or damage to the vehicle or its components.
1.) Record all of the vehicle preset radio stations.
2.) Turn OFF all the lamps and the accessories.
3.) Make sure the ignition switch is in the OFF position.
4.) Open the negative battery connection cover.
5.) Loosen the negative battery cable nut.
6.) Disconnect the negative battery (2) cable from the battery.
2.) Remove the wheelhouse liner. Refer to Wheelhouse Liner Replacement - Front .
Front Wheelhouse Liner Replacement
Preliminary Procedure
Remove the front wheel.
1.) Remove Front Wheelhouse Liner Bolts (Qty: 2)
2.) Remove Front Wheelhouse Liner Screws (Qty: 6)
3.) Remove Front Wheelhouse Liner Retainers (Qty: 3)
4.) Remove Front Wheelhouse Liner
3.) Lower the vehicle.
4.) Open the positive battery cable connection cover.
5.) Loosen the positive battery cable bolt.
6.) Remove the positive battery cable (1).
7.) Remove the front fender rear bracket to side rail bolts.
8.) Remove the front fender to front fender rear bracket upper (1) and lower (2) bolts.
9.) Remove the front fender rear bracket.
10) Remove the battery hold down retainer bolt and retainer.
Important: Do not tip the battery more than 40 degrees during removal.
11) Remove the battery.
Installation Procedure
Important: Do not tip the battery more than 40 degrees during battery installation.
1.) Install the battery.
2.) Install the battery hold down retainer and bolt. Tighten the bolt to 25 N·m (18 lb ft).
3.) Install the front fender rear bracket.
4.) Install the front fender rear bracket to side rail bolts. Tighten the bolts to 20 N·m (15 lb ft).
5.) Install the front fender to front fender rear bracket upper (1) and lower (2) bolts. Tighten the bolts to 20 N·m (15 lb ft).
6.) Install the positive battery cable (1).
7.) Tighten the positive battery cable bolt. Tighten the bolt to 17 N·m (13 lb ft).
8) Close the positive battery cable connection cover.
9.) Install the wheelhouse liner. Refer to Wheelhouse Liner Replacement - Front .
1.) Front Wheelhouse Liner.
2.) Front Wheelhouse Liner Bolts (Qty: 2) Tighten to 10 N·m (89 lb in)
3.) Front Wheelhouse Liner Screws (Qty: 6)
4.) Front Wheelhouse Liner Retainers (Qty: 3)
5.) Front Wheel.
10) Connect the negative battery cable (2). Refer to Battery Negative Cable Connect Procedure .
Battery Negative Cable Connection
Connect Procedure
Important: Clean any existing oxidation from the contact face of the battery terminal and battery cable using a wire brush before installing the battery cable to the battery terminal.
1.) Connect the negative battery cable (2) to the battery.
2.) Tighten the negative battery cable nut. Tighten the nut to 17 N·m (13 lb ft).
3.) Close the negative battery connection cover.
4.) Reset the radio stations and the clock.
Removing the Battery from the car-1593197.gif  Removing the Battery from the car-1593322.gif  Removing the Battery from the car-1593324.gif  Removing the Battery from the car-1593200.gif
INFORMATION POSTED ON SITE
Old 10-10-2006, 05:56 PM   #7 (permalink)
Why not invest in a battery maintainer for $20 and leave it in the car - that's what I am doing. The temps get below 0F here.
Ron
Ron
Sly/ebony leather/MP3/Power Pkg./Premium Pkg./Convenience Pkg./ABS/Stick
VIN117129
coiran is offline   Reply With Quote
Old 10-10-2006, 06:15 PM   #8 (permalink)
David Dougherty's Avatar
Battery Maintainer
Check http……..oops not an approved vendor.....send me a PM I have a source for maintainers for cheep!!!! They work, I use them on my boat and motor home!!!
Future so bright I have to wear shades!!!
Mean GXP (VIN 117835 11/06 )
Name: Growler (Vin #4878) Traded for Mean GXP 3/19/07
Mean, dark side, ebony leather w/red stiching, LSD, ABS, AC, Monsoon 6CD changer, mats , headliner, stability control, XM, power pkg., convenience pkg., chrome wheels, sport peddles, Fiam Air Horns, Magnaflow, De-badged, shortened waste gate rod mod.
Garage Mates: 2005 Yamaha FJR1300, 2003 Yukon w/K&N CAI, 2003 Honda CRV
David Dougherty is offline   Reply With Quote
Old 12-22-2006, 12:28 PM   #9 (permalink)
Dilbert pal's Avatar
Removing the battery...
So, if you buy battery somewhere besides Pontiac, they going to install for free? and more importantly, going to know how to do it?
are you kidding me? Can't believe this design!
Dilbert pal is offline   Reply With Quote
Old 12-24-2006, 04:51 PM   #10 (permalink)
baillieul's Avatar
I replaced the battery in my 2000 Jetta 1.8T last year. Not exactly a cake walk either. But, it was actually not as bad as replacing headlights in it. Thats why I love forums like this and vwvortex.com . You can figure these things out before you start wrenching and not mess up as often.
I'd also recommnd the battery maintainer. Mine was on sale at Canadian Tire for $20.00 and works like a charm. Don't have to remove the battery that way.
baillieul is offline   Reply With Quote
Old 12-24-2006, 05:36 PM   #11 (permalink)
PAO
PAO's Avatar
cant you just remove the fuze box....and lift the battery out..didnt someone do it that way????
VA/MD/DC Solstice Club
2006 Nationals Kansas City, KS
2007 Nationals Nashville, TN
2007 TOTD
2008 TOTD
2008 SE Regional Lexington, KY
2009 SE Regional Myrtle Beach, SC
It's not just a car, it's a lifestyle and a community
Other Cars: 04 Chevy Malibu Maxx, 09 Cadillac CTS
PAO is offline   Reply With Quote
Old 12-24-2006, 05:37 PM   #12 (permalink)
PAO
PAO's Avatar
another one post wonder..and troll I bet, registers to provide a post we all know about.....and leaves..........
2007 TOTD
2008 TOTD
Old 12-24-2006, 09:20 PM   #13 (permalink)
Member FDIC
JUSTICE's Avatar
My car is in a storage garage, but when spring time comes I'm just going to take out the stock battery and replace it with an Optima battery if I can find a yellow top that's small enough.
GXP Mysterious darkside l ebony leather with red
headliner l sport pedals l A/C l single disc Monsoon XM l chrome l no spoiler, onstar, smokers
Exhaust Depot charge pipes/intake, HKS BOV, Solo Street Race exhaust, EDAL, Eibach Pro Kit, Gravana 19" J2 stagg wheels, Eagle GS D3 rubber, HIDs, Optima batt, debadged, tint, Carolina Custom interior with Italian leather and Alcantara and suede backsplash with logo pop outs, Norm's fenders, Trifecta tune
banner courtesy of: crundell
JUSTICE is offline   Reply With Quote
Old 12-24-2006, 09:39 PM   #14 (permalink)
IBDRINKEN's Avatar
13.5@101.90
Norms Fenders
Kappa Intake
DDM Probeam, Backbone, IC Pipes, Coilcover
DDM Tune
JPM Shifter, Center Console
Custom Stereo System By JPM
Dejon Intercooler
Carbon Fiber Gas Door
IBDRINKEN is offline   Reply With Quote
Old 12-26-2006, 07:04 AM   #15 (permalink)
Critterman's Avatar
Lets see what other cars have such idiotic designs...
Audi, have to remove the rear seat to get to the battery.
Boxter, you can't work on the engine without removing parts of the interior.
Sybring, Got to remove the inner wheel liner to get at the battery
Corvette...yeap got to remove part of the bady to get the battery
That's all that comes to mind at the moment
DDM stage III w/custom CAI
DDM Stage III Upgrade here
