Replace TPS? - Pontiac Solstice Forum
Old 01-20-2013, 09:20 PM   #1 (permalink)
Replace TPS?
I am getting some new tires. I don't trust anyone to jack up the car. I am taking the wheels off myself, loading them along with the new tires in the back of my pickup, and heading to a garage to have them mounted. Do I have to buy / replace the TPS on each tire when I buy new tires? My current TPS works fine and I know about reprogramming.
omw41 is offline   Reply With Quote
Old 01-20-2013, 09:57 PM   #2 (permalink)
KappaKadet's Avatar
A competent tire shop will be able to change the tires without harming the tire pressure sensors. No problemo'.
G In hoc signo vinces.
KappaKadet is offline   Reply With Quote
Old 01-20-2013, 10:30 PM   #3 (permalink)
Agree. I have even moved ther to new wheels on my commuter car
Old 01-21-2013, 10:56 AM   #4 (permalink)
Thanks guys. I kind of figured that, but when I went to some online tire places, they "recommended" I replace the sensors as well.
Old 01-21-2013, 11:04 AM   #5 (permalink)
Carpe Diem's Avatar
If you don't put each wheel back onto the same corner from which it was removed, you will have to reprogram your TPMS. It's not difficult, but I'd check to see if the tire shop is competent to do it and let them do it for you. Fore me it's just easier to let them do it, especially when they throw it in for the price of the product and service I'm already buying from them.
Carpe Diem
'Mysti' - '08 Mysterious 5-spd GXP, Custom HP tune, Hahn I/C, K&N filter, DDM ProBeam & Backbone, splash guards, Z0K Sway bars, poly bushings & BC Coilovers, Magnaflow catback, Solo hi-flo cat..
Old 01-21-2013, 11:27 AM   #6 (permalink)
Thanks. I'll take that under consideration. I am kinda weird though. I do not trust anyone when it comes to touching the car. In some ways, I would rather do it myself. Does that make sense?
Old 01-21-2013, 03:44 PM   #7 (permalink)
tps
Hello Carpe
I just rotated my wheels in situ, as it's stored for the winter. Does this mean my tps computer or whatever will need reprogramming? If so, what's the procedure Thanks!
jcoryea1 is offline   Reply With Quote
Old 01-21-2013, 03:50 PM   #8 (permalink)
AKA SolWhat?
DaveOC's Avatar
Originally Posted by jcoryea1 View Post
Hello Carpe
It should be in your owners manual, if you don't have one, I can probably find the correct procedure online. What year is your car?
edit: The procedure should be the same regardless of the year, it is detailed in the attachment:
1st 1K - #741
Old 01-21-2013, 04:45 PM   #9 (permalink)
Just something to keep in mind... There's a battery inside each TPM. They last around 7-10 years, so if you've got 5-6 years on them already, and you're changing tires, you might want to consider installing new ones NOW rather than having to unmount and install in say two years. Could last longer though.
09SkyGuy is offline   Reply With Quote
Old 01-21-2013, 07:43 PM   #10 (permalink)
Thanks Dave and Sky guy The car is a 2006 with 3400 miles on it. I bought it last fall with 2800 miles, drove it about three weeks then put it away for the winter. My man cave is heated so I've managed to do mud guards, Curt receiver,Solo NA axle back, Fiamm horn, Venom brace, Probeam and DDM backbone, DDM cam cover in stainless, and the brushed stainless "Solstice" logo under the bonnet,stubby antenna, and the G2 red caliper paint. I will flogg the RSA's in spring for a set of Hankook ventus .
Yes, I have an owner'sanual and have bought a lot of Solstice dealer literature off ebay.
Can I just eliminate the tps in the wheels?
When I put winter tires and wheels on the winter car, I did not put the sensors in the wheels. JUst got a dash light which I covered with a piece of tape until spring. Can I do this with the Solstice or is the system more complicated? I mean just eliminate the tps entirely, as the car goes to bed in October.
If not, thanks for the heads up on the tps battery. Too much technology..guess that's why I love my 57 MGA!
Thanks in advance!
You guys(gals) are the best!
Old 01-21-2013, 08:24 PM   #11 (permalink)
AKA SolWhat?
DaveOC's Avatar
FWIW, TPMS was installed in all Kappa cars starting with model year 2008, when it was required by Federal legislation.
If your car is a 2006, it isn't equipped with TPMS.
1st 1K - #741
Old 01-21-2013, 08:42 PM   #12 (permalink)
RedDevil's Avatar
He's right. You can also check your D.I.C. to see if your tire pressure is shown there for each tire. If it doesn't show up, that's another dead give away that you don't have it.
Red Devil 07' Solstice - Sport Package ( traded in 2012' )
Black Widow 08' Solstice - GXP
http://i5.photobucket.com/albums/y15...Car_Colage.jpg
http://www.hulu.com/watch/357322/my-...?from=fb_share
RedDevil is offline   Reply With Quote
Old 01-22-2013, 09:13 AM   #13 (permalink)
Thanks guys! One less thing to deal with..I'll check the dic, but I don't recall seeing that info on the display..think I'm good to go..
All the best,
Old 01-24-2013, 09:30 AM   #14 (permalink)
chickenwire's Avatar
So in summary, if you do not have TPMS sensors, you don't need to replace them.
IMPORTANT NOTE. If your tire shop recommends you replace the non-existent TPMS sensors, under NO circumstances should you agree to do it. It could result in an unnecessary lightening of the wallet.
That is all.
