Service Tire Monitor? - Pontiac Solstice Forum
 1Likes
post #1 of 19 (permalink) Old 02-12-2017, 09:29 AM Thread Starter
I have a "Ser Tire Monitor" displayed and my tire pressure indications are blank. Tires are fine. Does this require maintenance by a dealer or is this something that I can perform? Computer reboot? Anyone have this before?
Thanks,
Steve
Bushpilot is offline
post #2 of 19 (permalink) Old 02-12-2017, 09:39 AM
AKA SolWhat?
DaveOC's Avatar
Thanks,
Steve
It may be the RCDLR which is located behind the rear panel behind the seats. It handles communications between the key fob remote controls and the wheel sensors. It may just need to be reprogrammed, see your owner's manual for instructions. If you can't reprogram the tire monitors, it'll probably mean a trip to the dealer.
Good luck!
1st 1K - #741
DaveOC is online now
post #3 of 19 (permalink) Old 02-12-2017, 10:49 AM
Sly Bob's Avatar
Does the car have a model year? Did they all go out at once?
Essayons likes this.
Born April 30, 2008
Delivered on May 27, 2008
Sly Bob is offline
post #4 of 19 (permalink) Old 02-12-2017, 12:28 PM
AKA SolWhat?
DaveOC's Avatar
FWIW, Tire Pressure Monitoring Systems became mandatory for the 2008 model year.
1st 1K - #741
post #5 of 19 (permalink) Old 02-12-2017, 01:26 PM Thread Starter
Yes, it is a 2008. Thx
post #6 of 19 (permalink) Old 02-12-2017, 02:11 PM
Did anything unusual happen at the time the TPMS stopped working? Does everything else work now?
post #7 of 19 (permalink) Old 02-12-2017, 02:51 PM
Sly Bob's Avatar
Early 2008 cars (which is why I inquired about the model year) would lose the TPMS system if the battery was disconnected and had to be reprogrammed by the dealer to restore that function. I suspect by now that battery had been disconnected at some point.
It DID work previously?
Born April 30, 2008
Sly Bob is offline
post #8 of 19 (permalink) Old 02-12-2017, 03:09 PM
I had forgotten that. Wasn't that fixable by a re-flash?
post #9 of 19 (permalink) Old 02-12-2017, 03:18 PM
Sly Bob's Avatar
It was. Are they all dead? if only a few wheels not reading could be a dead TPMS battery. Did anything change from when it used to work?
Born April 30, 2008
Sly Bob is offline
post #10 of 19 (permalink) Old 02-12-2017, 08:44 PM Thread Starter
Yes, everything else works, that is all of the other data readouts are functioning.
post #11 of 19 (permalink) Old 02-12-2017, 08:46 PM Thread Starter
Yes, you are correct. The battery was replaced by the seller just before I bought the car. So you say a trip to the dealer is required to reboot?
Thx
post #12 of 19 (permalink) Old 02-12-2017, 08:59 PM Thread Starter
I accepted the car with the Serv Tire Monitor at the time I bought it hoping it was a simple problem. Wish I had negotiated that it be fixed by the seller.
Anyhow, so the TPMS has it's own battery? Any idea where it is located. If I knew I would try checking it and replacing it.
post #13 of 19 (permalink) Old 02-12-2017, 09:01 PM Thread Starter
Considering that it would have to be rebooted the a dealer, would a GM dealership be able to do so?
Thx
post #14 of 19 (permalink) Old 02-12-2017, 09:31 PM
AKA SolWhat?
DaveOC's Avatar
Thx
Each of the TPMS senders, one in each wheel/tire combo, total of 4, has it's own built-in battery. All 4 communicate with the RCDLR (Remote Control Door Lock Receiver). In some RCDLRs, when there is a power loss, it will forget the Tire Pressure senders.
If the key fobs are working, there is another possibility, and that is that the prior owner for some reason removed the tire pressure sensors from the tires, so that should also be checked.
Any GM dealership should be able to check this out, but get a quote before they do the work, it could get expensive.
YMMV
1st 1K - #741
post #15 of 19 (permalink) Old 02-13-2017, 06:02 AM
TPMS reboot
Thanks,
Steve
HI. Had a similar problem with my 2009 G8/GT. I had to have the dealer use their special tool to reset the monitors. It took about 5 minutes and cost me nothing. I confess that I know the service manager and the owner of the Chevy dealership, so that probably helped. However, barring any major problem, the reset is an easy fix by the dealer and (if the problem is like the one I had) should cost very little.
grandpop07
grandpop07 is offline
