Old 11-18-2005, 10:16 AM
   Shock Failure (Shock Leak, Leaking Shock)
tugmate's Avatar
I had two shocks fail. The dealer inspected and ordered two to replace them. They were leaking the fluid all over. It was my front left and right rear. I found it when cahnging the oil when it was on the lift. What do people think about the ride. Will it be worse? It seem's as if I go over the slightest bumb it is like bang!! Any opinions would be great.
tugmate is offline
Old 11-18-2005, 11:48 AM
TOY4TWO's Avatar
no way. Bilstein made 2 bad shocks on the same car?
TOY4TWO is offline
Old 11-18-2005, 11:50 AM
   Seems smooth to me
smartin's Avatar
___
The ride in mine seems smooth.
Deep/Ebony leather everything but OnStar and 6-Cd changer
smartin is offline
Old 11-18-2005, 11:52 AM
CaSol's Avatar
Send a message via Yahoo to CaSol
If they were to fail that fast, I would have upgraded to the KYB's instead of the Bilstein. Ive heard that Bilstein isnt all that good lately.
CaSol is offline
Old 11-18-2005, 11:55 AM
TOY4TWO's Avatar
must have dropped the car off a truck carrier or the grease monkeys did somethimg. Or GM is using inferior parts.
TOY4TWO is offline
Old 11-18-2005, 12:04 PM
Dealer close by me had two sols in - one sold, one for show. The one sold had a bad left front shock and replaced it with the show car.. I wonder if this could be a bigger issue with shocks.
IWantOne is offline
Old 11-18-2005, 12:59 PM
tugmate's Avatar
I just hope it has nothing to do with the suspension. I mean it really bangs pretty good when I hit a bumb or something. I can understand feeling the bump but not hearing the noise.
tugmate is offline
Old 11-18-2005, 01:05 PM
MAKsys's Avatar
Has it been fixed yet? Maybe the reason you're experiancing such a harsh ride is the broken shocks.
Hard to imagine how the suspension design could cause the shock failure (unless the shocks were undersized, which would give a squishier ride - the opposite of how most describe the Sol).
It is odd to see so many shock failures - sounds like a bad lot
...sunlight on chrome, the blur of the landscape, every nerve aware...
1971 Javelin SST
2001 Silverado
2006 Solstice
MAKsys is offline
Old 11-18-2005, 02:53 PM
This is a bilstein problem if I've ever seen one.
Thraxz is offline
Old 11-18-2005, 02:59 PM
achieftain's Avatar
I would agree that the harsh ride may result from the bad shock. Certainly still under warranty. And the warranty will only cover replacement with factory parts.
achieftain is offline
Old 11-18-2005, 03:00 PM
Administrator
brentil's Avatar
That defintely sucks tugmate. How many miles on your car at the time of incident?
brentil is offline
Old 11-18-2005, 03:07 PM
MITCH's Avatar
Thats what happens when we let the Damn Commies build car parts.
If thoses shocks were built in the good old U.S.of A. you wouldnt have a problem.
Sing along with Mitch Daddyo!
Took delivery Oct, 6th 2005
Presently 9,406 miles. Finally out of storage" See you in Mooseport"
"Note: I do not necessarily agree with every statement made by another author, other than myself, posted for your entertainment, even if the Author's name is not posted.
MITCH is offline
Administrator
SolsticeMan's Avatar
Depending on how bad the shock has lost pressure, banging is not out of the question.
Magister Solstitium Sum!!!
No, I'm not Bob Lutz...
SolsticeMan is offline
Old 11-19-2005, 04:17 PM
tugmate's Avatar
Brentil I only had 1k miles on it when I found it. The shocks are on backorder and am still waiting for them to come in. Thanks everyone for your opinion on the ride.
tugmate is offline
Old 11-19-2005, 04:27 PM
birdliver's Avatar
Hey Tug, I'm sure it occurred to you but I'd make a case for all four. It may have been dropped, as someone mentioned. The other two may have also been traumatized. Check it out.
birdliver is offline
Old 11-19-2005, 06:51 PM
tugmate's Avatar
Thanks Bird! I have no idea how it may have been dropped but you never know. They said when I bring it in they will need it the entire day. She rides better at higher speeds. We will see. Thanks
tugmate is offline
