I plan on keeping a list of the Solstice GM (only) part numbers, so as you post the numbers and parts descriptions I will update this initial post.
This list should be important so others can take advantage of saving with on-line purchasing of these items.
List is sorted by description
Please keep the format like the following.
GM Part #......Description................................ .................................Dealer Price
89025003......A/C compressor
15264321......Arm, Rear Axle Lower Control Arm....................................$195.66
15264322......Arm, Rear Axle Lower Control Arm....................................$195.66
15264001......Arm, Steering Knuckle Upper & Lower Control Arm................$158.48
15822072......Arm, Steering Knuckle Upper & Lower Control Arm................$160.48
89025064......Bumper Cover, Nose.............................................. ......$ 289.80
19120721......Bumper Cover, Nose- GXP..............................................$ 355.90
15254986......Bumper front lip - GXP
89225065......Bumper, Rear bumper (- 7831)........................................$ 252.00
15867069......CONSOLE ASM-F/FLR EBONY
15867070......CONSOLE ASM-F/FLR LT CASHMERE
15916412......Dash TRIM ASM-R/WDO PNL EBONY/LT SIL &UW5&19I&67U.
15916405......Dash TRIM ASM-R/WDO PNL EBONY/BLACK &UW5&19I&41U.
15916413......Dash TRIM ASM-R/WDO PNL MD STL/M BLU &UW5&25U&31I.
15916414......Dash TRIM ASM-R/WDO PNL MD STL/L SIL &UW5&31I&67U.
15916415......Dash TRIM ASM-R/WDO PNL MD STL/D SIL &UW5&31I&42U.
15916406......Dash TRIM ASM-R/WDO PNL MD STL/BLACK &UW5&31I&41U.
15916427......Dash TRIM ASM-R/WDO PNL EBONY/YELLOW &UQ3&19I&34U.
15916426......Dash TRIM ASM-R/WDO PNL EBONY/M BLUE &UQ3&19I&25U.
15916428......Dash TRIM ASM-R/WDO PNL EBONY/EMRALD &UQ3&19I&38U.
15916429......Dash TRIM ASM-R/WDO PNL EBONY/VI RED &UQ3&19I&74U.
15916430......Dash TRIM ASM-R/WDO PNL EBONY/DK SIL &UQ3&19I&42U.
15916431......Dash TRIM ASM-R/WDO PNL EBONY/LT SIL &UQ3&19I&67U.
15916424......Dash TRIM ASM-R/WDO PNL EBONY/BLACK &UQ3&19I&41U.
15916432......Dash TRIM ASM-R/WDO PNL MD STL/M BLU &UQ3&25U&31I.
15916433......Dash TRIM ASM-R/WDO PNL MD STL/L SIL &UQ3&31I&67U.
15916434......Dash TRIM ASM-R/WDO PNL MD STL/D SIL &UQ3&31I&42U.
15916425......Dash TRIM ASM-R/WDO PNL MD STL/BLACK &UQ3&31I&41U.
15916407......Dash TRIM ASM-R/WDO PNL EBONY/M BLUE &UW5&19I&25U.
15916408......Dash TRIM ASM-R/WDO PNL EBONY/YELLOW &UW5&19I&34U.
15916409......Dash TRIM ASM-R/WDO PNL EBONY/EMRALD &UW5&19I&38U.
15916410......Dash TRIM ASM-R/WDO PNL EBONY/VI RED &UW5&19I&74U.
15916411......Dash TRIM ASM-R/WDO PNL EBONY/DK SIL &UW5&19I&42U.
15916416......Dash TRIM ASM-R/WDO PNL EBONY/WHITE &UW5&19I&50U.
15916417......Dash TRIM ASM-R/WDO PNL MD STL/WHITE &UW5&31I&50U.
15916435......Dash TRIM ASM-R/WDO PNL EBONY/WHITE &UQ3&19I&50U.
15916436......Dash TRIM ASM-R/WDO PNL MD STL/WHITE &UQ3&31I&50U.
15916437......Dash TRIM ASM-R/WDO PNL MD STL/EMRLD &UQ3&31I&38U.
15916438......Dash TRIM ASM-R/WDO PNL MD STL/V RED &UQ3&31I&74U.
15916418......Dash TRIM ASM-R/WDO PNL MD STL/EMRLD &UW5&31I&38U.
15916419......Dash TRIM ASM-R/WDO PNL MD STL/V RED &UW5&31I&74U.
10345219......Deflector (Rubber chin spoiler)........................................$ 21.24
15299260......Door, driver, no mirror (old)...........................................$5 63.64
15909689......Door, driver, no mirror (new)..........................................$58 0.55
15299261......Door, passenger, no mirror (old).....................................$563.64
15859723......Door, passenger, no mirror (new)....................................$560. 92
12603530......ECM (2006) Emission Control System Hardware (obsolete)....$383.83
12605843......ECM (2006 & 2007) Emission Control System Hardware........$383.83
12578182......Engine Crank
12596088......Engine Connecting Rod
15779404......Fender LH (behind left front wheel).................................$ 70.00
15779405......Fender RH (behind right front wheel)
19120266..... Folding top linkage Right Side
19120267 .....Folding top linkage Left side
15265486......GRILLE, Radiator Grille (?Back).......................................$ 35.00
15265487......GRILLE, Radiator Grille (?Black)......................................$ 35.00
15282192......GRILLE RH(Silver)........................................ ...............$ 35.00
15282193......GRILLE LH(Silver)........................................ ................$ 35.00
15254984......GRILLE large - GXP (Left?)
15254985......GRILLE large - GXP (right?)
89025309......Hood................................ ........................................$595.13
15909540......Headlight assembly driverside(same for GXP and NA)
15805581......Instrument Panel-Gauge Cluster........................................$ 207.20
15912960......Instrument Panel-PLATE ASM-I/P CSTR TR DK GRAY MET &VGL&19I.
15912961......Instrument Panel-PLATE ASM-I/P CSTR TR V DK STL GRA &VGL&31I.
15867060......Instrument Panel-BEZEL-I/P ASST HDL DK GRAY MET &19I.
15867061......Instrument Panel-BEZEL-I/P ASST HDL V DK STL GRA &31I.
15867067......Interior-Dash HANDLE ASM-I/P ASST V DK STL GRA &31I.
15254355......Interior-MOLDING ASM-Windshield UPR Garnish MD STEEL GRA &31I
1052358........LSD additive
15852707......LSD New relief valve Hex Chrome Free Vent
15233712......LSD OLD relief valve (replaced by 15852707)
15213620......Mirror, driver, electric.......................................... .........$124.15
15229255......Mirror, passenger, electric.......................................... ...$124.15
17800974......Molded Splash Guards - Front with No Logo........................$ 60.00
17800975......Molded Splash Guards - Rear with No Logo.........................$ 60.00
12586646......O2 sensor (from the cat back).........................................$ 55.12
12579143......Oil Filter............................................ ........................$ 7.84
5927272........Radiator with C60 Option ( Air conditioning, front)
5927273........Radiator with C60 Option ( Air conditioning, front)
5927276........Radiator with C41 Option ( Heater, outside air, with fan)
5927277........Radiator with C41 Option ( Heater, outside air, with fan)
15789266......Rear Facia Panel single exit (-7381)...................................$207.00
15254993......Rear Facia Panel GXP dual exit..........................................$230 .90
19120801......Rear Spoiler........................................... ....................$271.19
20064875......Retainer for underhood liner............................................$ 1.59
15265484......Scoops next to front turn signals - GXP (Left?)
15265485......Scoops next to front turn signals - GXP (right?)
11609230......Suspension Front A-Arm Chassis Side Lower Bolt (Camber adjust)
10254818......Suspension Front A-Arm Chassis Side Lower Washer (Camber adjust)
15265486......Turn signal front grille - GXP (left?)
15265487......Turn signal front grille - GXP (right?)
17800058......Wind Deflector (Wind Screen)..........................................$ 250.00
Corrections are also welcomed.
Reason: Added Instrument Panel and Interior Items
What ever happened to the in-country AWOL's and deserter's of the Vietnam conflict? Read the story that has waited for over thirty years to be told at... www.lulu.com/TrentYoung
i printed out instructions for : (1) lifting
(2) wheel alignment - "special instructions and special tool required"
- i just hope i can keep track of stuff like that too -
no doubt we'll all need a lift and alignment eventually ------ hopefully in the DISTANT future
that would be a good list too..lol.......
GM Part #......Description................................ .............Dealer Price
10345219......Deflector (Rubber chin spoiler)....................$ 21.24
17800974......Molded Splash Guards - Front with No Logo. $ 60.00
17800975......Molded Splash Guards - Rear with No Logo.. $ 60.00
12579143......Oil Filter............................................ .....$ 7.84
89225065......Rear Facia............................................. .$ ??.??
20064875......Retainer for underhood liner.......................$ 1.59
17800058......Wind Deflector (Wind Screen)....................$ 250.00
I have a list of all GM Solstice Part numbers (including those "mystery hood rubbers", parts wt colour variation, and who is the supplier) for the 2006 model. It just doesn't include after market parts.
But I can't post them becauses its a rather big file (and also another possible issue).
If it's file size send it to me maybe I can reformat it. If it's another reason feel free to PM me and we'll see if we can get around it somehow.
__________________ -2006 VIN #30, First 1000 Series
part # 12586646 part 02 sensor this is the one you find on the exhaust from the cat back cost $ 55.12. Started putting in my new exhaust. The 02 sensor threads were shot
mods MagnaFlow cat-back,High flow cat from Hahn
boosted by WERKS sweet
VIN# 3783,cool,no lsd,no xm,no on star, name Breezy
Reason: spelling
These are the two panels behind the wheel on each front side. Numbers accurate as of 9/15/2006.
Rear Fascia part# changed. It is now... 15789266 7831-Panel $207.00.
The other number (89025065 - 7831 Fascia) as listed for the rear Fascia is the really the rear bumper. $252.00. Make sense?
I dont have any data that contradicts your post, so I updated the list.
Just thought of something.....
Even though creating a list of part numbers provides some benefits.... its could also be futile.
For those who work at one of the plants, you might know what I mean. GM changes part numbers on a consistant basis. Sometimes each year, sometimes several times a year depending on the part. A list generated here will help, but how relavent will the information be in say a few months from now.
Don't mean to be negative about it... just thought you all should know before massing allot of time on it.
