LinkBack (1) Thread Tools Display Modes
Old 07-31-2009, 05:24 PM   #166 (permalink)
slusamson's Avatar
Originally Posted by Flash's Owner View Post
Oh boy. There is a part number for each color car and interior plastic color variant. You need to know your exterior color and your interior color scheme (grey, ebony or cashmere, for example).
My car is Pure with Ebony interior... got a number for that?? Thanks!!
slusamson is offline   Reply With Quote
Old 08-10-2009, 06:33 PM   #167 (permalink)
IBDRINKEN's Avatar
I was wondering if anyone had the part numbers for any of the hoses in the engine bay, i seem to not be able to read mine
13.5@101.90
2.5" Stubby Black Antenna
Lil' Chromies
Norms Fenders
Kappa Intake
Kappa IC Pipes
Pcm4less Tune
Infinity Kappa Speakers
DDM Probeam
DDM Race Backbone( Not Installed)
DDM Black Coilcover
JPM Center Console
JPM Shifter
Custom Kicker System By JPM
MBRP Heat Shield
Dejon Intercooler
IBDRINKEN is offline   Reply With Quote
Old 08-11-2009, 07:13 AM   #168 (permalink)
Flash's Owner's Avatar
Bit more specifics, please. Pictures with arrows are even better. There are coolant hoses, turbo hoses, etc.
I am a GM Engineer.
I am a proud Solstice GXP owner (Flash). My wife, A FORMER GM engineer, is a proud Solstice GXP Coupe owner (Wicked).
My other hobby: hot turbo wastegate nut adjustment.
Flash's Owner is offline   Reply With Quote
Old 08-12-2009, 02:11 AM   #169 (permalink)
IBDRINKEN's Avatar
coolant, vacum, heater,fuel. Im trying to get steel braided hoses for just about every hose that I can replace and need the numbers to give the company so they can make exact fit ones. I have to figure out how many of each I need.
Thanks
13.5@101.90
Lil' Chromies
Norms Fenders
Kappa Intake
Kappa IC Pipes
Pcm4less Tune
DDM Probeam
DDM Black Coilcover
JPM Center Console
JPM Shifter
MBRP Heat Shield
Dejon Intercooler
Old 08-25-2009, 12:08 PM   #170 (permalink)
There appears to be a piece which fits between the rear of the driveshaft and the differential, and attaches to each with three bolts. Is this the "companion flange"? Does anyone have p/n's for these pieces? BTW, I don't have a Solstice-I'm building a Lotus 7 replica with the Solstice drivetrain.
thanks
sorta_se7en is offline   Reply With Quote
Old 08-26-2009, 05:53 PM   #171 (permalink)
24240205 Transmission Aisin AR-5 (RPO MA5) 2008-later
25858218 Differential Getrag 1:3.91 limited slip 2008-later
Old 09-01-2009, 10:45 AM   #172 (permalink)
AZDarkSol's Avatar
Buttress release cable. This is the cable that releases the convertable top buttresses from the trunk lid. I just had mine replaced in warranty.
Part number # 15805321 Around 60 bucks depending who you get it from. I don't know if the car uses two. Only one was installed on mine but only the driver side buttress failed to release. I suspect there may be one for each side.
Mods: Billet front grille.
Venture shield clear bra
GM mud flaps (front)
Carolina Custom armrest pads
Norm's "Fabulous" Fiberglass Split Dual Rear Fascia
Lovin' AZ
Pontiac: "We Used to Build Excitement! Now We Build Nothing"....
AZDarkSol is offline   Reply With Quote
Old 09-01-2009, 10:54 AM   #173 (permalink)
AZDarkSol's Avatar
Air Filter Element for Stock 2.4 N/A
GM part # 15287103 Around $25
Lovin' AZ
LinkBacks (?)
LinkBack to this Thread: http://www.solsticeforum.com/forum/f12/solstice-gm-part-numbers-22079/
Posted By For Type Date
GM OEM Rear Facia for Sol - Saturn Sky Forum This thread Refback 04-25-2008 07:22 PM
