Old 10-18-2006, 02:15 PM
Administrator
brentil's Avatar
Is your jack a low profile jack? Because I could never figure out how to get my normal sized jack underneath the front of the car...
Can you take some pics of where you jacked it up from the front please?
brentil is offline
Old 10-18-2006, 02:47 PM
Chemist's Avatar
The first picture is the box my jack came in (from WallyWorld). The second picture is the jack passing under the edge of the car right behind the front right wheel. The clearance is only about 1/2". The third picture is the jack under the front right lifting point (square pad behind and inside the front right wheel) with a piece of 1/2 particle board as a "lifting pad." (Please excuse the dirt. It's been raining on and off for a week. I have not had time to wash her.)
Does this show what you need to see? LMK.
--Chemist
solstice-jack-lifting-points-jack-box.jpg  solstice-jack-lifting-points-jack-going-under-car.jpg  solstice-jack-lifting-points-jack-under-jacking-point.jpg
"Muirne" --- Envious, ebony leather, LSD/ABS/AC/Monsoon w/6CD changer, mats, splash guards, DDM Stage II S/C, DDM stainless headers/cat/exhaust, DDM 4-piston brakes/slotted rotors, Probeam, Backbone, black "stubby" antenna, Lil' Chromies, K-sphere pedals, Kazera KZ-L wheels, the TWEETY door unlock/lock button, Garmin nuvi 750 GPS, High Note horn, Brushed Al door sills, etched/lighted WindRestrictor, white LED map/footwell lights, 3rd brake light pulser. --- She moves!
NASSOA Founding Member
Chemist is offline
Old 10-18-2006, 07:14 PM
Ex-Miata Man's Avatar
Hey Doc,
We shop at the same store. I had to get a lower floor jack and got the same one as you. It works great under a "low Sol."
AKA xmm
DEEP with Steel/Sand leather,
72,300+ miles on the odo - Silver side stripes - My wife named my car "Nittany" after Penn State, my Alma Mater
Proud Member - ICoD EHDoR&M
WPASC
Founding Member #41
"It's Going To Be A Girl......plus one more on the way!!!"
Ex-Miata Man is offline
Old 10-19-2006, 08:01 AM
--Chemist
According to the pdf file picture of jacking and lifting points that is not either, although I have used it with some makeshift wooden blocks also and it seems OK.
Ron
Ron
Sly/ebony leather/MP3/Power Pkg./Premium Pkg./Convenience Pkg./ABS/Stick
VIN117129
coiran is offline
Old 10-19-2006, 08:59 AM
Chemist's Avatar
Ron
I have found the pdf file to be less than clear. A new look just now confirms that you are correct (as far as I can see! ) But, as you say, the position I used works.
--Chemist
Chemist is offline
Old 10-19-2006, 09:10 AM
Administrator
brentil's Avatar
--Chemist
Awesome, yeah that's what I wanted to know. My current floor jack can't fit under that are at all, it's about the exact height of the bottom of the panels on the car. I needed something to fit under the front for when I go racing so I can change wheels. Having never been able to get a jack under the front I hadn't really been able to figure out where to jack from.
How much did it cost you at wally-world?
brentil is offline
Old 10-19-2006, 09:11 AM
Administrator
brentil's Avatar
Ron
Like Chem just said I can't figure out where the hell the PDF is telling me to jack from at the front of the car.
brentil is offline
Old 10-19-2006, 10:15 AM
dengel's Avatar
brentil, in post #30 of this thread, I have a couple of pics of how I jacked up the front of the car. I know it was a tight fit to get the jack under the axle, and one of the reasons I went with the "knuckle" as the location for the jack was because the jack actually fit under it (you can see the knuckle is higher than the frame member it attaches to).
http://www.solsticeforum.com/forum/a...8&d=1158098158
From what I remember, I slid the jack under the car from the side, forward of the tire, probably to use the additional clearance afforded by the wheel well.
I did jack the car up one side at a time, not at a center point that would lift both front tires at the same time.
Purchased off the lot on 6/30/2007 from dealer stock to replace My Baby, lost on the Tail of the Dragon on 6/25/2007. You can read all about it here, Tail of the Dragon - Accident
Red Bull Drift Team 2008
dengel is offline
Old 10-19-2006, 10:37 AM
Administrator
brentil's Avatar
woo-hoo, awesome thanks dengel.
I've come to the conclusion I need a new jack. Mine is a 5-1/2" minimum clearance when I see the one Chem was using is a 5" clearance and I'm betting yours is too. The 5-1/2" jack will NOT fit under the front of the car at all.
What brand jack do you have, where'd you get it, and how much was it?
brentil is offline
Old 10-19-2006, 11:00 AM
Chemist's Avatar
This jack (which I still laugh at since is a "Mr. Goodwrench" ) was less than $20 as I recall. I want to say $17 and some change.
I bought this one specifically because it claimed a 5" clearance. As you and I know, 5 1/2" is too high.
--Chemist
Chemist is offline
Old 10-19-2006, 11:02 AM
dengel's Avatar
don't recall the brand, so you'll have to wait until I get home for that.
But I bought it as part of set, the jack, 2 jack stands, X-type lug wrench and two worthless wheel chucks for $38.00 or so at Walmart.
If I remember to check when I get home, I'll check what brand it is and let you know.
dengel is offline
Old 10-19-2006, 11:51 AM
Administrator
brentil's Avatar
To Walmart!!!
Thanks for the input, this will help greatly. I was having a lot of issues getting the front wheels up high enough safely to do the tire changes from other points. When I'm at the track some places are not paved too so it would have been impossible to jack the car up in some areas due to the jack being to high. Hopefully they have what I need in stock.
brentil is offline
Old 10-19-2006, 05:02 PM
Locat
