Old 01-08-2008, 12:57 AM   #1 (permalink)
ClearBraInstall's Avatar
Strange Problem.<no start/electrical issues?>
Ok,
Here's one for you guys to chew on. Go out to start the car and when I turn the key, I get all the lights but it doesn't turn over. Tried pulling the battery and resetting ECU and nothing. I let it sit overnight and I go out and it starts right up. It has been doing this on occasion so we installed an override switch that I can use to get the car started by bridging the starter when the key in switched on. Now get this, this is the weird part. When the car is doing this, the DIC information button that you use to scroll through the options doesn't work. Also the climate controls also black out. I can't change the vent direction or turn on the AC, just the fan comes on.
Any clues?
Clear
Mods
  • Dynoed at 450HP
  • Hahn High Flow CAT
  • Eibach Sportline Springs
  • SSBC Big Brake Kit
  • Konig Privat 19" Wheels
  • Custom Two Tone Paint
  • Razzi Wing
ClearBraInstall is offline   Reply With Quote
Old 01-08-2008, 07:03 AM   #2 (permalink)
Go-N Def's Avatar
Maybe a bad chip in your key???
Try using your other key that the dealer supplied...
Pics on MySpace
Go-N Def is offline   Reply With Quote
Old 01-08-2008, 10:48 AM   #3 (permalink)
achieftain's Avatar
Maybe the fuse holder issue? Or a bad ground cable attachment somewhere? Solscuba has a simmilar no-start problem, all lights work but starter doesn't spin. And DIC reports funky data.
Pontiac 1926-2010
"We hardly knew 'ya"
Old 01-08-2008, 10:53 AM   #4 (permalink)
Jackknife's Avatar
Maybe we've reached the effective life of the key chips/batteries.
Maybe more of us have this in our futures?
Jackknife
DDM Pro-Beam and back brace
Jackknife is offline   Reply With Quote
Old 01-08-2008, 07:16 PM   #5 (permalink)
Critterman's Avatar
Do you have a garage door keyfob?
There have been reports of them interfeering with the electronic chip in the key
NOT WAITING ANY MORE!
DDM Stage III Upgrade here
Old 01-08-2008, 07:31 PM   #6 (permalink)
I am thinking fuse block crack as well.
Let's get SLIDEWAYS!
Solo Mach and No Cat
JPM custom shifter.
Barney Juice XPR 21
RMR Style Bar.
DDM Works PINK Breastplate
HKS Coilovers
Old 01-08-2008, 07:38 PM   #7 (permalink)
JustMike's Avatar
Originally Posted by ClearBraInstall View Post
Any clues?
You have a PM
#1922 12/03/05
MODS: GM CAI & CATBAck
Dover DE
Pontiac builds excitement...
JustMike is offline   Reply With Quote
Old 01-08-2008, 08:03 PM   #8 (permalink)
Go-N Def's Avatar
Any clues?
Clear
Push the clutch in and THEN turn the key!
Pics on MySpace
Old 01-09-2008, 12:20 AM   #9 (permalink)
Thanks for the suggestions. I am definately leaning towards a wiring issue with the BCM. With the DIC and climate controls also going wacky, I can't think of anything else that would cause it. Will be checking it out this weekend.
Mods
  • Dynoed at 450HP
  • Razzi Wing
Old 01-09-2008, 01:34 AM   #10 (permalink)
CADREAMIN's Avatar
Bcm Issue
Thats what I would say. Seems many cars are having electrical issues. Do you have any parts from the old car to swap out. Sounds like to many unexplainable airplane issues. Good luck Tony..
Laura & Wayne DeLeeuw
Lancaster CA
Solstice delivery date 12/21/05
2008 GXP 12/08
(our 06 N/A was purchased back by GM). Our new ride is a 2008, cool, GXP. Wind Restrictor (GXP flames), Norms Fiberglass F-430 Nose and Hahn Intercooler. View it at http://www.cardomain.com/ride/3124305
Member: West Coast Kappa Car Club,
Student: Embry Riddle Aeronautical University,
CADREAMIN is offline   Reply With Quote
Old 01-09-2008, 07:06 AM   #11 (permalink)
achieftain's Avatar
Check for any electrical parts marked "Lucas", yank them out and toss 'em away - you don't need them. Works every time on a MG.
Pontiac 1926-2010
Old 01-09-2008, 10:20 AM   #12 (permalink)
achieftain's Avatar
Solscuba just reported his problem WAS the cracked fuse block issue. Part is on national backorder, but at least the problem was identified. This certainly could be your problem as well.
Pontiac 1926-2010
Old 01-09-2008, 11:04 AM   #13 (permalink)
Gunnys GXP's Avatar
"BLUE DEMON"
Old 01-10-2008, 10:11 AM   #14 (permalink)
SmokinSolstice's Avatar
I am going to guess what madmods said....he was right about solscuba's car.
Team Solstice 2008
Ordered 11/12/05
Old 01-17-2008, 10:05 AM   #15 (permalink)
Problem Solved
Well it looks like we found the problem. It appears the large connectors going to the BCM were not well seated. I had my wife try the key while I tapped on the BCM and sure enough, it started. I pulled all the plugs and reseated them. Haven't had the problem for several days now. Let's hope we got it.
Clear
Mods
  • Dynoed at 450HP
  • Razzi Wing
