Old 08-07-2008, 04:28 PM
   Top pinching, What lube?
Sly Bob's Avatar
Had the car since the end of May and the top was pinched today when I went to put it up.
Small Dealer a short time ago posted what I believe was a TSB that addressed the top pinching issue. GM wants us to get a $70 tube of lubricant so the top will not pinch any more.
What type of lubricant is everyone using? Shouldn't have to give GM $70 for lubricant that you can likely pick up for $10 elsewhere.
WooHoo!!! Ordered a loaded Deep GXP (minus smokers package) on March 19th, 2008. Order number 0814D93708
Delivered on May 27, 2008
I think I'm in love...
Mods: lose the chicklets, VentureShield, Dual horns, AfterShock spoiler, Weathershield cover, Lil Chromies and red calipers with black Solstice stickers!
Sly Bob is online now
Old 08-07-2008, 06:17 PM
MomsSol's Avatar
Just a quick "Search" lesson:
Go to "Search"
enter "pinching" in the keyword to search for
and
small dealer as the user name
it was the FIRST thread that came up
7/10/08-New Info for Top Pinching
NASSOA(TM)
MomsSol is offline
Old 08-07-2008, 06:55 PM
Resident Tree Rat
Squirrel Boy's Avatar
this is what they gave me
GM part # 12345579
http://www.myspace.com/squirrel_boy1
Pontiac is car...
Founding Member # 21
Squirrel Boy is offline
Old 08-07-2008, 07:19 PM
Small Dealer's Avatar
Here is a post from that thread about the service information (not a TSB). Notice there are two choices for the lubricant, including the less expensive (even for those that can not get it from work) Dielectric Silicone Grease.
Originally Posted by Squirrel Boy
just got my car back from the "top pinch fix" (finally got time to get it done) and I got them to give me a tube of the stuff they put on the gaskets. Its "Dielectric Silicone Grease" GM part #12345579... will this stuff still work
Originally Posted by MomsSol
Dielectric Silicone Grease ... Thanks! Same stuff we use at work and I can get for FREE!
In the back of your Owner's Manuals (2006-2008), both the Dielectric Silicone Grease #12345579 and the GM Weatherstrip Lubricant #3634770 are the recommended "Fluids & Lubricants" for weatherstip maintanance.
So either one should do, and the Dielectric is a lot less and easier to come by.
Here is the most recent version of a 1999 Service Bulletin:
Subject: Use of Silicone for Weatherstrip Maintenance
Models: 2008 and Prior GM Passenger Cars and Trucks (including Saturn)
2008 and Prior HUMMER H2, H3
2005-2008 Saab 9-7X
In the past, questions have been raised regarding the proper care and maintenance of weatherstrips. The purpose of this bulletin is to clarify which materials are recommended for use when required.
Periodically, a thin coating of silicone grease can prolong the life of the weatherstrip. The silicone will reduce wear in the contact areas as well as reduce squeaking and sticking conditions. During very cold or damp weather, more frequent applications may be necessary.
Important: Be careful in areas where clothing may come in contact with the weatherstrip, as silicone or dirt may be transferred to clothing.
Parts Information
Part Number / Description
12345579 (U.S.) / 10953481 (Canada)
Goodwrench Dielectric Silicone Grease (or equivalent) / Lubricant Silicone Grease
3634770 (U.S.) / 10953518 (Canada)
Goodwrench Weatherstrip Lubricant (Krytox*) (or equivalent) / Lubricant
*The use of KRYTOX for coating weatherstrips is allowed, but not required.
INFORMATION POSTED ON SITE
Small Dealer is offline
Old 08-08-2008, 11:50 AM
prattm's Avatar
Send a message via Yahoo to prattm
I found some Dielectric Silicone spray at Autozone $2.99 for the can.
Sprayed some in a paper cup, dipped a Q-tip into the cup, applied it to the part shown on the pics..........works perfect.
Sly, black leather, black top, NA, loaded. Seems like it has everything but On-Star.
Mods:
Stuby Antenna, 42U Splash Guards
2007 bought new 5/16/08.
Loving every minute...
prattm is offline
