View Poll Results: How will GM/Pontiac achieve a higher HP model?
Turbocharger 5 15.63%
Supercharger 22 68.75%
Inline 6 1 3.13%
V6 2 6.25%
V8 1 3.13%
Greater than 2.4 liter 4 cylinder 1 3.13%
VTEC (Honda S2000-like) 4 cylinder 0 0%
Voters: 32. You may not vote on this poll
Old 05-06-2004, 04:17 PM   #1 (permalink)
SolsticeMan's Avatar
What is GM/Pontiac likely to do for higher HP version?
Here's the second half.
You've gone and checked off the V8 on the last poll, knowing full well that GM would never consider that really production feasible, but ya did it anyways 'cause you know there's no replacement for displacement.
Now, try your hand at prognostication: How do you really think the General will handle it? Assume (even though hi-perf versions of the Solstice have never been indicated to date by GM) that there will be a high performance version of the Solstice - be it two weeks after production starts, or 2 years after production starts.
Old 05-06-2004, 04:53 PM   #2 (permalink)
Damovc's Avatar
I went with the supercharger in the poll, just based on the fact that that's what Pontiac has used in the past to boost performance. However it would be really nice to see the new in-line six used in a sports car platform. Kind of a throw back to all those open aired sixties roadsters with straight sixes in them (Jag, Ferrari, Maserati).
My wife's Envoy has the in-line six and it puts out 275hp and 275lb/ft of torque. I'm sure GM could get that up to 300 on both fronts without any trouble. And if they reduced the displacement a little bit from the current 4.2 L by shortening the stroke from the current 3.66 in, they could probably get the engine to rev quite high.
Damovc is offline   Reply With Quote
Old 05-06-2004, 06:39 PM   #3 (permalink)
Chip's Avatar
I think SC is a done deal on this platform. Time will tell!
Chip is offline   Reply With Quote
Old 05-06-2004, 06:50 PM   #4 (permalink)
padgett's Avatar
Personally I'd rather see a V-6. GM knows how to build them and one of the things I look for in a car destined for max handling is an engine behind the front axle.
Unfortunately I suspect that Pontiac has been told what engine it will use, at least for the first year.
"And if they reduced the displacement a little bit from the current 4.2 L by shortening the stroke from the current 3.66 in, they could probably get the engine to rev quite high."
Considering that the 2.4 EcoTec has a 3.9" (98 mm) stroke, it is to laugh :rolleyes
padgett is offline   Reply With Quote
Old 05-06-2004, 09:41 PM   #5 (permalink)
2KWK4U's Avatar
Does it mean nothing that the original concept/show car had a supercharged ecotec?
Old 05-06-2004, 10:55 PM   #6 (permalink)
Brian's Avatar
looking at the automobile magazine thread they quoted that there will be a 250hp turbo version coming out
"The base car should give Mazda a lot to think about, with a 250-horsepower-plus turbo version coming later should be a humdinger. Just fix the sterring please."
do they know something that pontiac has not told us yet. i for one hope so.
Brian is offline   Reply With Quote
Old 05-07-2004, 07:45 AM   #7 (permalink)
padgett's Avatar
So fa I have seen 205 hp (2.0l Cobalt), 230 hp, 240 hp, and 250 hp mentioned by Journalists. Of those only the 205 2.0 is actually in production in this country (been through the EPA testing). There is a 2.3l 230 hp turbocharged SAAB but that is not an EcoTec (but similar). The Opel/Vauxhall VX 220 has a 200 hp 2.0 l turbo engine that is said to be an EcoTec derivative.
The Opel Speedster/Vauxhall VX 220 has a quoted weight of 2215 lbs and 0-60 in under five seconds with the 2.0 s/c engine and under six seconds with the n/a 2.2.
All production GM Ecotec derivatives I have found have a HP peak in the 5400-5500 rpm range. N/A 70 hp/liter, s/c 100 hp/liter. What makes the Speedster/220 so fast is the light weight, over 600 lbs lighter than what has been quoted for the Solstice.
Both are GM versions of the Lotus Elise and rear/mid engined with a Getrag trans, in other words what a 2004 Fiero would have been like. Both are also over $30k which is probably why Pontiac backed off from importing it.
Figure normal development (and marketting) will have engines rated at 75 hp N/A and 105 hp s/c per liter by the 2006 model year.
Gut feeling and figures I am seeing say that the 6400 rpm peak hp quoted in England was an aberration unless they know something we do not, is incredibly high for that long a stroke. More likely a redline and even that sounds high.
Has anyone seen a 2.2 l Ecotec block ? Is there room for an increase in bore ? Pontiac increased the stroke past 4 inches to reach 455 cid in 1970 because there was no room for an increased bore in the block design. Maybe they are doing the same thing here to reach 2.4 l. Has it reached a design limit and is 2.0 l really the optimum size for boost ?
Without hardware I can only make guesses.
Old 05-07-2004, 11:33 AM   #8 (permalink)
you are going to be good to have around here, especially once we're driving this beast!
Solstice here i come!!!
Vita is offline   Reply With Quote
Old 05-07-2004, 01:29 PM   #9 (permalink)
AeroDave's Avatar
Marketing, It's all about marketing. Remember they are selling these cars. Think of those options from a marketing perspsective.
Inline 6? that is so 1930's, my '53 Willys Areo had one of those. There's a reason that cars nowadays that have inline 6's don't prowdly display a "I6" badge on their fenders. :lol
Turbo Charging? Maybe, but it's alot more cost and trouble than Super Charging and has the problem of turbo lag. I think it's perception is that it's older technology, sort of an '80s thing. :sleep
V6? Could be, but I think it might have an adverse effect on handling and it's sales appeal. It screams out.. cheap way to more power. This is the typical approach that GM has taken in the past and I get the feeling they want to make a break from the cheasy bean counter image they have had. :skep
V8? Never going to happen. No room at the Inn.
Bigger 4? It's already got a pretty big four. Going any bigger won't gain significant power gains and no marketing cache. 2.4 liter or 2.8 liter? Who cares? :yawn
Honda Vtec? That would be Pontiac saying, "We'd like to make our flagship sportscar, the one we're using to promote brand image, a world class car, but we suck. Can you help Honda?" Which one would you rather have, the Honda brand lawnmower, or the cheasy "Honda powered" lawn mower at Home Depot. That move would do everything to improve Honda's image and degrade Pontiac's to bargin brand. If they do that it's time for GM to hang it up. Again the performance gains would only be modest. :banghead
Supercharge? You bet! Very trendy, hip and cool right now. Marketing department can prowdly display that on the fender! The concept car had one for God's sake! The nice part is, Supercharging is cool and does work! Aside from crappy gas mileage and alot of added complexity and engineering associated with any boosted engine, it rocks! That will sell cars. :thumbs About the only thing more sexy would be a turbine powered Solstice... Hummmm. :jester
Thanks again Bob, for building my car! Envious/Ebony VIN #0051
AeroDave is offline   Reply With Quote
Old 05-07-2004, 02:09 PM   #10 (permalink)
Damovc's Avatar
Doesn't the BMW M3 use an in-line 6 engine? I don't think anyone would acuse them of being 1930's. If I'm not mistaken, BMW and Lexus have done extremely well in competition with in-line 6 engines. Also I think Jag was winning LeMans with its XK (in-line 6) engine well into the 60's. I don't know if GM's new all aluminum DOHC In-line 6 would fit in the solstice, but I think the configuration makes a pretty good sports car engine.
Old 05-07-2004, 02:15 PM   #11 (permalink)
2KWK4U's Avatar
Bah, the crappy gas mileage only comes with a heavy right foot. I actually got better gas mileage in my modded GTP than I do in my 4-cylinder VUE. Especially on the highway! Only thing is, the VUE won't run a 13.6 @ 103. I doubt it would even break into the 16's.
Edit: Oh yeah. I-6's ROCK! For some reason, that I'm sure Padgett can explain, they tend to produce heaps of torque when compared to V-6's. They also run alot smoother (from a vibration standpoint) than ANY other common configuration as far as I know... again, Padgett can give the long explaination. It's sufficient to say, though, that they are inherantly (sp?) balanced by their very nature.
Old 05-07-2004, 03:18 PM   #12 (permalink)
Stephen M's Avatar
True. An I6 engine is inherently balanced without the use of balance shafts. Other configurations that share this property include boxer engines and V12s.
Everything you wanted to know about engine balancing can be found here:
Engine configuration and vibration
I think the straight six fell out of favor mostly due to packaging concerns with front wheel drive layouts. Otherwise, the I6 has some advantages over a V6, such as one head instead of two, two cams instead of four, aforementioned vibration reduction, etc.
-Stephen M
Stephen M is offline   Reply With Quote
Old 05-08-2004, 11:07 AM   #13 (permalink)
padgett's Avatar
Problem with an I-6 is that it is a long engine, for best handling I want to see the engine entirely behind the front axle and that is easier to do with a short engine. The other problems you get into with an I-6 is crank whip (why the best have seven main bearings which adds weight), uneven intake distribution, and a lot of weight (which can be mitigated with aluminum and composites).
OTOH a V-6 is compact, lightweight, and can live with four main bearings. Further a 90 degree V-6 is balanced (the domestic rage for 60 degree blocks was so the tooling for V-8s could be reused). To get the same bearing load you do need a larger diameter bearing because it must be shorter but that is a minor issue.
Just to really get heretical, for a engine designed for under 7000 rpm there is nothing wrong with a traditional single cam in block design particularly for a V-type engine. Small bore just makes rockers easier to design. You can even have some interesting valve designs (might mention the Chrysler Hemis and "Porcupine head" Chevvys). Does make VVT a matter of advance or retard but no difference in overlap. Of course with a boosted engine you do not need VVT anyway. DOHC is pretty and can allow reduced valve angles particularly for a four valve head at slight additional cost.
(Since we don't have lead any more, you really do not need valve rotators. Have been waiting for someone to come up with dual stem valves shaped like a kidney bean for serious flow area but no, we still have lots of conventional round ones. Would need an NC vave lapper... :jester )
As far as I am concerned, from every aspect except turbocharging for a sports car, I like V engines better than In-lines (if going to turbocharge then do like Ford did with the Indy engine, bring the exhaust out the center but suspect that is a bit radical for the General.
As usual, this has become something of a rant but what the heck, its Saturday.
BTW the Columbo designed Jaguar XK engine was a monster, the most sporting versions had triple 2" SUs carbs to keep the mixure even and intake runners short but was of an era when the driver sat over the rear wheel and hoods were long. The over 4" stroke had a deep effect on everyone without unlimited funds - 40 psi on the oil pressure guage at 3,000 rpm on straight 30 weight non-detergent was a mystic number, when it went under, months of 15 cent hamburgers lay ahead. Problem was it was soooo sweetover 6000 rpm. Problem was that the top end could deliver more than the bottom (with post WWII problems with good metal and cotton fabric oil filters) could sustain.
However a 15 second 1/4 was something on 6.00x16 Dunlop RS-5s was hard to resist. :cheers
Old 05-08-2004, 04:31 PM   #14 (permalink)
2KWK4U's Avatar
...Further a 90 degree V-6 is balanced (the domestic rage for 60 degree blocks was so the tooling for V-8s could be reused). To get the same bearing load you do need a larger diameter bearing because it must be shorter but that is a minor issue.
I may not be as well-versed as you, but I think you may have inadvertantly stated this backward. I know for a fact that my L67 (a 90-degree V6) had a balance shaft, and that 90-degree V8s are balanced. I've heard that the general's 3800's were 90-degree motors because they were basically 350s minus two cylinders. Thus the domestic rage for 90-degree V6 blocks was so the tooling for V8s could be used.
Please tell me I'm not off my rocker :crazy
Old 05-08-2004, 08:43 PM   #15 (permalink)
padgett's Avatar
errr, my cat made the entry, brane fade, just wanted to see if you were awake....
You are correct, V-8s and V-6s designed to go down the same assembly line are 90 degree, a 60 degree V-6 like the 2.8/3.1/3.4, and new VVT 3.6 is inherantly balanced with 120 degree separation (and easier to fit into a narrow engine bay). Was correct about the reason, just swapped the numbers.
Personally would rather have the new Global V-6 with n/a configuration in a Solstice than a boosted four.
