Windshield wiper fluid not coming out - Pontiac Solstice Forum
post #1 of 14 (permalink) Old 12-15-2011, 05:24 PM Thread Starter
DRM
DRM's Avatar
The windshield wiper reservoir is full and when I press the button to use the windshield wiper fluid I can hear the fluid reservoir pump motor running, but no fluid is coming out.
Any ideas?
2007 Pontiac Solstice GXP Deep/Ebony/Silver Stitching, traded 8/17/12 for a 2012 Ford F150 Lariat...I'm very sad.
2006 Pontiac Solstice Mysterious/Steel/Sand F1K(#78) 2nd owner, purchased with 1,400 miles, traded 3/07 for GXP
My Garage
DRM is offline
post #2 of 14 (permalink) Old 12-15-2011, 05:46 PM
John_Salgado's Avatar
it could be clogged, i wouldnt know how to flush it.... but that may be the problem we just need a solution
John_Salgado is offline
post #3 of 14 (permalink) Old 12-15-2011, 06:11 PM
Administrator
MomsSol's Avatar
Any ideas?
How cold have your temps gotten? Did you put the fluid in or a shop?
The reason for the questions.....mine froze up in the reservoir, slush...due to the dealership's oil change shop was watering down the wiper fluid..the repair shop proved that themselves as I never put any in and I had all my maintenance dome there...needless to say, they replaced my put, a hose, and refilled the reservoir. The oil change quick shop now has the right fluild (wink wink).
Team Solstice
NASSOA(TM)
MomsSol is offline
post #4 of 14 (permalink) Old 12-16-2011, 09:00 AM
smartin's Avatar
Any ideas?
Hey Derek!
I would see if it is clogged like John said and I would also check the type of washer fluid you are using. It might just be cheap and gunks things up easily.
Good luck getting it fixed and hope to see you soon!
2008 AGGRESSIVE SOLSTICE GXP
SMARTIN's SOLSTICE
QUEEN
"THE RED ROCKET"
Custom Tune
2006 Deep Solstice
"O Sol O Mio"
11/15/05 - 02/25/12
RE-TIRED
smartin is offline
post #5 of 14 (permalink) Old 12-16-2011, 09:06 AM
There is also often a check valve, that prevents the fluid from running all the way back down to the reservoir tank after the pump shuts off. That check valve can fail as well. Can be a common problem on some cars.
Carbon Sky is offline
post #6 of 14 (permalink) Old 12-16-2011, 10:05 AM
R&T
R&T's Avatar
A quick shot of compressed air can unclogged a nozel but that usually doesn't happen since it is difficult for debris to get into the washer resevoir. If you do, make sure you turn down the regulator. You don't need a lot of pressure. You can do it from the sprayer as well if you can get to them. If it has been cold for you then let the car run for about 5-10 minutes and that will be plenty of time for it to warm up. Run the defroster as well. If these don't work then look at the check valve like mentioned above.
2008 GXP Manual, every option and more to come....
R&T is offline
post #7 of 14 (permalink) Old 12-19-2011, 03:35 PM Thread Starter
DRM
DRM's Avatar
Moms,
It has been a warm December here in Maryland.
I do all of the fluid changes my self. Now I had the water pump resently replaces. Not sure if that would have affected it though.
My Garage
DRM is offline
post #8 of 14 (permalink) Old 12-19-2011, 03:37 PM Thread Starter
DRM
DRM's Avatar
I fill the fluids and always make sure that the reservoir never gets low. Maybe a stink bug got in there...LOL
My Garage
DRM is offline
post #9 of 14 (permalink) Old 12-19-2011, 03:39 PM Thread Starter
DRM
DRM's Avatar
Originally Posted by smartin View Post
Hey Derek!
Hey Susan!!!
I use the Walmart brand fluid...not sure how that would clog it up, but you never know.
Thanks...Hopefully...
My Garage
DRM is offline
post #10 of 14 (permalink) Old 12-19-2011, 03:42 PM Thread Starter
DRM
DRM's Avatar
Crap...I hope not...I wonder if that's covered under warranty...probably not with having over 80k miles. If this is the case, I wonder if I need a new pump or just check valve...gotta check out my manual.
My Garage
DRM is offline
post #11 of 14 (permalink) Old 12-19-2011, 03:44 PM Thread Starter
DRM
DRM's Avatar
Great...thanks, I will try the compressed air and see if that works.
My Garage
DRM is offline
post #12 of 14 (permalink) Old 12-29-2011, 11:43 PM Thread Starter
DRM
DRM's Avatar
Well I finally found the problem.
I hooked up my bike tire pump to the disconnected Driver side washer fluid nozzle under the windshield wiper and blocked the Passenger side washer fluid nozzle to see if I could blow out any kind of blockage...didn't work.
So I removed the Washer Pump and disconnected the pump hose from the pump and tried to force air through that end...still blocked.
I then started to follow the pump hose all the way up under the driver side wiper and what do I find...a crease in the line. I pulled the crease out and now the air/fluid flows.
There seems to be a lot of extra pump hose in a tight area under the driver side wiper. I think over time an area of the pump hose creased under stress.
You can see the crease in the pics below.
My Garage
DRM is offline
post #13 of 14 (permalink) Old 12-30-2011, 01:08 AM
KappaKadet's Avatar
Thanks for the followup report.
for posting your findings!
Nice photos clearly show the culprit.
Some great under the hood detective work.
KappaKadet is offline
post #14 of 14 (permalink) Old 06-13-2016, 10:39 AM
dazueta's Avatar
Someone knows the part number?
Hi, my passenger side wiper washer hose is broken (the one under the hood that connects from the inside of the hood to the wiper) so the water is not coming out just flushing under the hood, does someone know the part number for that hose? Online I found the part number 25820394 but not sure if that is for the whole hose or just a part of it... Someone that could help me? :S.
Actually now I found the part 15240723, it looks like it is the hose I am looking for... It is like the one in the pictures above... Somebody that could corroborate this?
Thanks!!
dazueta is offline
