Old 08-23-2008, 02:50 PM
   Anyone else interested in Line lock?
IM thinking about putting together a Lineloc kit for the Kappa's with pre-bent lines and harness.
Whom else would be interested in such a kit?
Line loc- is a electically opereated solenoid in the front brake lines that when actuated will only allow fluid to flow 1 way- ON
Used to hold the front brakes when in the burnout box warming the tires.
Used to keep from rolling out of the beams when staged, and spooling on the clutch.
Used in daily driving to hold yourself on a hill without rolling (taking off from a stoplight uphill with a stick)
I used it everyday in my old lowrider pickup just to hold the thing from rolling on the converter from light to light.
BaldTurboFreak is offline
Old 08-23-2008, 04:17 PM
LiquidPT's Avatar
That sounds interesting... what ballpark price would this come in at? How hard would it be to install? Would a shadetree be able to install it, or would this take a shop?
Thanks...
LiquidPT is offline
Old 08-23-2008, 09:21 PM
I'm shooting for a pair of Benjamin'$, give or take.
It should take a few hours to install, with simple hand tools and another person to help you bleed the brakes afterward.
Old 08-25-2008, 09:46 PM
Hopefully the ESC wont freak out.
Dragracing has been a bit or a 3 armed launch, esp with the contortion job I have to do with the E-brake.
Old 08-25-2008, 10:12 PM
LiquidPT's Avatar
I was wondering about the ABS and traction control... would this work ok with that stuff?
LiquidPT is offline
Old 10-28-2008, 11:08 AM
I for sure have a solution from the electronics and ease of use standpoint for the manual guys if you want to roll a line-loc kit into play.
Motivated Motorsports
08 Sky Redline 263whp/328ft.lbs. 13.20 @ 103.39
-My tune, RPI GT, no cat, N2MB 2-step, airbox mod
04 Ion Redline 250whp/235ft.lbs. 13.559 @ 109.68
-My tune, 2.8, Cobra HE, PS header, no cat, intake
dont_blink is offline
Old 11-06-2008, 08:14 PM
   Line Lock
Intimidator's Avatar
If you produce the kit, I'll deffinitely take one. Please keep me in the loop.
Cheers,
Steve
Mysterious w/everything but On-star + Performance Autowerks LS2 conversion w/Livernoies Stage II cam/StageII heads and UMI Racing 90mm TB w/Delphi 4B ECU, AFX wide band 02 sensor, F.A.S.T. 90mm intake, 13" rotors w/SSBC 3 piston calipers.
Intimidator is offline
