Originally Posted by AaronSS
Nah. Just put it in place of that ugly stock air box. That four core integrated into the manifold is pure tits. I really think it could be done in somewhat similar fashion, maybe minus a core or two for the HHR. I'm interested in this idea mainly for straight line applications as opposed to a singular cooling solution. I want ATO to ATW with an icebox or maybe filled with CO2 to freeze the core. Have you tried that Andrew from OZ?
We haven't got into any other form of cooling as yet, we intend to try an ice slurry in the future and we have some ideas on running refrigerant (freon or similar) through the cores which Laminova say on their site is possible to achieve as well.
We want to get a few different shape configurations up and running 1st and I would also like to do some flow testing to see what configuration works out best.
I suspect the flat arrangement (we call it the pancake) will flow the best and the one integrated into the manifold will be the worst as we have to change the air direction 90 degrees through the intercooler and past that to the inlet ports.
It's all really interesting stuff to work with, I've done air to air's in the past and anyone can buy a cheap Chinese generic cooler and fit one so I'm not interested in them anymore.
We intend to get all the tech info regarding temp differential, pressure drop, flow rates etc and post them up as we have nothing to hide because we are "enthusiastic amateurs here
We're not going to hide behind "our coolers flow 400 bhp, 650 bhp or so many CFM as it means absolutely zip if they don't tell you if it was flowed under vacuum, boost or whatever conditions.
We're having fun building these at the moment, there's basically not a lot of information available on them and how they perform apart from anecdotal so we intend to find out just how good they really are, and I have to say that at the moment they are pretty damn good.
Regards Andrew from Oz.
