Old 09-04-2008, 10:40 AM
   BTFR ported Cyl heads
I cant get my hands on castings for another few months, but here's whats coming..
I will have 3 stages of cyl heads.
1) mild pocket porting 3 angle valvejob and upgraded springs
2) Handported runners/valvepockets + above
3) Full out CNC ported, welded lifterbosses hoping for 300+cfm.
Get ready for this winter's shennangans!!
The last one wil be part of an upcoming longblock availible spring '09. I have 800rwhp planned for you lunatic's out there(my brothers and sisters). No Im not kidding in the slightest
BaldTurboFreak is offline
Old 09-04-2008, 01:00 PM
lil goat's Avatar
BTF you are a very very sick man, keep up the good work!
Red Bull Drift Team 2008
Solo Mach and High Flow Cat
Wester's Garage RACE tune II
JPM custom shifter.
Barney Juice with Militec-1
DDM Works PINK Breastplate
lil goat is offline
Old 09-04-2008, 01:25 PM
idkfa's Avatar
LE5 work as well? Can I just send you mine?
idkfa is offline
Old 09-04-2008, 01:50 PM
Yes,
Id be happy to work on your LE5 as well.
Old 09-05-2008, 07:22 AM
SOMEBODY's calling around to have nasty matching bumpsticks ground for the above stage kits.....
Was that a solstice or a superbike that just whipped by???
Old 09-09-2008, 10:16 AM
Old 09-09-2008, 08:47 PM
Send a message via AIM to Stinglikeabee
Originally Posted by BaldTurboFreak View Post
Easter Bunny, Playboy Bunny, Tooth Fairy, Anniversary and Birthday gifts for the rest of your life. What does that thing cost besides both arms, legs and first born
Stinglikeabee is offline
Old 09-10-2008, 09:50 AM
Mr. Stone's Avatar
Ooo...ported heads. What is the cost indeed?
The Boogeyman
Stone's modification page
Mr. Stone is offline
Old 09-10-2008, 09:10 PM
coopcj7's Avatar
cost yes please
coopcj7 is offline
Old 09-10-2008, 09:59 PM
Not sure yet. I'm going to have to put some developement time on the flow bench first + parts tally before I can get there.
I cant get the LNF castings for another month,
But YamatR3 has hooked me up with two LE5 castings to get to work with right away.. One to develope for CNC porting one for a stage 1/2 core.
Old 09-30-2008, 06:47 AM
Maybe I misunderstand your plan, but aren't the LNF and LE5 heads different because of the provisions for direct injection? Are you just developing on the LE5 and then moving over to the LNF once you can get the castings?
I must admit my general ignorance on the theory here. I know the idea on n/a applications is to get more airflow through the engine and increase high rpm power. Is it the same on t/c applications? Wouldn't a higher flowing head directly affect the boost threshold? Enlighten me, please!
2008 BRAZEN GXP - 5M Loaded
oldskool is offline
Old 09-30-2008, 08:32 AM
carlintexas's Avatar
BTF, when available - pricing for option #1 for my LE5 please
TEAM SOLSTICE 2008
NASSOA(tm)
Founding Member #2
1st 1K #781
DDM Custom Turbo System
3" Magnaflow cat-free
Riken Raptor's 255/45/18
carlintexas is offline
Old 09-30-2008, 09:46 AM
Yea, they are two totally different heads and will therefore have different ports.
I havent gotten to the point yet where I have 2 heads next to one another to compare.
When it comes to forced induction,all things being equal, NA theory applies.
However all things are NOT equal so there are a few specific needs for forced induction.
A well designed port will have no more cross sectional area than is nessicary for maximum power.
That is calculated using a max velocity in the port at power peak. The idea situation is near equal velocity throught the cross sectional area( great port utilization), so drag losses are at a minimum and the entire column of air has as much INERTIA as possible. This is the real key to great overall power.
Enter the forced induction into the equation and our inertia increases dramtically as boost pressure rises. This somewhat changes the way our fluid (air) behaves.
To make a long story short, forced induction ports tend to be a little smaller than their NA counterparts to mix on/off boost performance.
Max performance FI ports will be very similar to their NA counterparts because off boost performance is of little concern.
The biggest differnce in NA vs FI setups is in the camshaft selection,specifically the lobe separation. A non-issue in our fully variable cams.
http://www.btfrstore.com/
Old 09-30-2008, 09:52 AM
Will do bud. It'll still be a while yet, I havent gotten the LE5 heads yet/nor LNF's.
Still forkin dough over like nuts to get the new building done before winter.
Once the CNC is moved and the flowbench is set up (home built using Audie pro-flo sensors) I will begin working those heads over. Gotta get the equipment setup so I can do the job right.
Old 10-31-2008, 07:29 AM
Any progress on the head work? Just curious and excited...mostly excited
oldskool is offline
Old 10-31-2008, 10:45 AM
WWI Flying Ace's Avatar
Details please? 800RWP?
How? Do you have a checklist of parts / mods that get you from stock to there? On regular gas? Jumpin' Jehosephat! 800 RWP? What mods would you have to do to the powertrain to handle that?
800 RWP...that would be..are there words for how cool that would be? I can't think of an appropriate one right now...
That is the biggest number I have seen on the forum for potential HP...now you REALLY have my attention!
WWI Flying Ace is offline
