Go Back   Pontiac Solstice Forum > Supporting Vendors > BTF Racing Inc.
LinkBack (15) Thread Tools Rate Thread Display Modes
Old 10-07-2008, 05:14 PM   #256 (permalink)
ender's Avatar
What are balance shaft blanks, what are drawbacks and what is it about stock balance shafts that would cause an RPM limitation?
Thanks!
Russ
Speed Is Life
ender is offline
Old 10-08-2008, 05:46 PM   #257 (permalink)
Status: Delivered
Delivered On: 10/08/2008
5:25 P.M.
BTFRacing has the Turbo, now let's get the wheel upgrade done and the turbo SwainTech.
Then up to the 1st tuner that wants to start testing it for 15 days.
LatinVenom is offline
Old 10-09-2008, 09:56 AM   #258 (permalink)
I opened it up this morning- Now THAT'S an example of a nice core. That turbo is in Top shape!
I'll get it going on ASAP. Your beatup turbo is on it's way as well.
BaldTurboFreak is offline
Old 10-09-2008, 10:01 AM   #259 (permalink)
Thanks!
Russ
The neutral balance shafts are in the GMPP catalog. The stock ones are not capable of sustaining that rpm and fly apart.
Remember, a COUNTERbalance shaft does that, cause a deliberate imbalance in the engine block to counteract the 2ndary forces created by an inline 4cyl.
They are cast and will "G out" under high enough sustained rpm.
Old 10-09-2008, 10:08 AM   #260 (permalink)
ender's Avatar
So balance shaft blanks have no imbalance, spin more smoothly (alone) and provide no balancing of the secondary forces in the motor?
So you get a shaky motor that can spin faster?
Thanks,
Russ
Speed Is Life
ender is offline
Old 10-09-2008, 10:11 AM   #261 (permalink)
Precisely correct ,Russ.
Im going thru the removal of a set right now in a H22A4 for my buddy. You only notice the additional vibes at idle, off idle and this little window at 3200.
Old 10-09-2008, 10:13 AM   #262 (permalink)
But in greasey jockey's car you really couldn't notice beans.. I cite the 55lb dual mass flywheel as the savior..
Old 10-09-2008, 09:12 PM   #263 (permalink)
there is also a company somewhere,the name escapes me at the moment, that makes balance shaft delete kits for the ecos, not just blanks. i have the blanks from gmpp, they are just a solid slug of steel machined into tolerance, they still have a substantial mass. the delete kit that is out there should get rid of a good chunk of rotating mass as well. i beleive the delete kit is a set of press in sleeves to block the oiling holes, and just the end of the stock balance shaft machined off so that the front end of the shaft sits in the first bore and the gear can still turn in place on the water pump chain. should be fairly simple to make. hint hint
greaseyjockey is offline
Old 10-09-2008, 11:44 PM   #264 (permalink)
mena661's Avatar
I removed the balance shafts from my old car and didn't notice any difference. But I made up for that by installing Energy Suspension motor mounts.
mena661 is offline
Old 10-10-2008, 06:57 AM   #265 (permalink)
Hmm the thing about the Delete is that we would have to go to a Meziere 55gpm electric WP.
Bates engieering is making the Neural balance shaft kit along with the delete.
Gmpp is no longer going to carry them once house stock is gone. Alot of part numbers are like that.
Old 10-10-2008, 10:58 AM   #266 (permalink)
POuring Concrete today!!!! DYno Dyno dyno!!!
Old 10-10-2008, 02:01 PM   #267 (permalink)
OMFG are my arms and legs sore.
First I had to suck out 260 cu/ft of water 12 gal at a time with my wet dry vac. (including a 20ft haul to dump, each round) So that's what 260x7.5gal=1950 gal! /12= 162 trips!
Then pulled and pushed 4 yards of 5000psi concrete w/mesh around for 2 hours.
a little nap then some more bullfloating and it's done.
once this pad cures I have to set the dyno roll into the hole. then 3 courses of block around it, then backfill with washed stone (for drainage to the sumppump), then pour a 15yard slab (24x33) for the main floor of the new shop addition.
Then I'll have a total of 1500sq/ft on the main floor and 1171 on the 2nd and 3rd floors.
Pretty much not enough, but it's all I can afford right now.
Old 10-10-2008, 07:16 PM   #268 (permalink)
BTF,
I am pretty sure the larger wheel mod will help your bank account.
Old 10-20-2008, 07:55 AM   #269 (permalink)
LV, your turbo is all done except swainttech. Even as nice as that turbo was it still had an ugly looking thrust bearing and some scoring in the shaft. My rebuild guy told me it looked like oil contamination to him, as though some small amount of debris went thru the oil galley.. I had it rebuilt using all new BW parts and had the turbine shaft ground 0.0050".
I'll be giving you a helluva deal on the rebuild since I feel for you on that last turbo, and your trying to get this ball rolling for everyone.
Old 10-20-2008, 11:43 AM   #270 (permalink)
DirtyMike's Avatar
I'll be sending mine up soon, just as soon as I get some more cash! Probably late Nov early Dec if not sooner
07 Sky Redline, 5 spd manual, black w/ black & red int, spoiler
Shabby Pipes w/ Tial Q
HID-low & fogs
stubby ant.
5% tints
RPi GT Exhaust & Race Pipe
Hahn IC
Dejon BOV Spring
Dual Aeroforce Guages
DDM ProBeam,Race Bacebone & A-Pilar
Wester's race tune
TenzoR DC-5 v.1
Eibach Sportlines
BTF Big Wheel K04
JPM Shifter
HKS Turbo Timer
& Some CF Bits
DirtyMike is online now
LinkBacks (?)
LinkBack to this Thread: http://www.solsticeforum.com/forum/f120/stock-turbo-compressor-upgrade-47371/
Posted By For Type Date
BTF Bigwheel Kit - Chevy HHR Network This thread Refback 01-24-2009 06:29 PM
BTF Bigwheel Kit - Chevy HHR Network This thread Refback 11-17-2008 11:28 PM
BTF Bigwheel Kit - Chevy HHR Network This thread Refback 11-17-2008 06:35 PM
K04 Turbo upgrade - Cobalt SS Network This thread Refback 10-22-2008 10:39 PM
K04 Turbo upgrade - Cobalt SS Network This thread Refback 10-22-2008 10:06 PM
K04 Turbo upgrade - Cobalt SS Network This thread Refback 10-22-2008 11:12 AM
K04 Turbo upgrade - Cobalt SS Network This thread Refback 10-22-2008 04:16 AM
Turbo performance challenge PLAN by LatinVenom and BTFRacing - Solstice GXP Owners Forums Post #0 Refback 09-07-2008 08:08 PM
Turbo performance challenge PLAN by LatinVenom and BTFRacing - Solstice GXP Owners Forums Post #0 Refback 09-06-2008 10:27 PM
Turbo performance challenge PLAN by LatinVenom and BTFRacing - Solstice GXP Owners Forums Post #0 Refback 09-06-2008 09:17 PM
Performance challenge Plan by LatinVenom and BTFRacing - Saturn Sky Forum Post #0 Refback 09-05-2008 07:20 PM
BTF Racing, Inc. - Bald Turbo Freak This thread Refback 09-02-2008 09:30 PM
Opel GT compared to SLK 55 AMG [performance enhancement discussion] - Saturn Sky Forum This thread Refback 08-17-2008 04:54 PM
Opel GT vs SLK 55 AMG - Saturn Sky Forum Post #44 Pingback 08-17-2008 02:29 PM
Stock turbo Compressor upgrade - Pontiac Solstice Forum This thread Refback 06-26-2008 08:12 PM
