Go Back   Pontiac Solstice Forum > Supporting Vendors > BTF Racing Inc.
LinkBack (15) Thread Tools Rate Thread Display Modes
Old 07-31-2008, 05:30 PM   1 links from elsewhere to this Post. Click to view. #31 (permalink)
shabby's Avatar
Originally Posted by BaldTurboFreak View Post
Okay we're in buisiness! Weve got a larger induce wheel with the same backwall coming and should be machined up and ready to rock by next weekend. It should provide almost the exact same spool with another 50hp up top.
From which turbo is this wheel from, got some induc/exduc measurements?
shabby is offline
Old 07-31-2008, 07:22 PM   #32 (permalink)
Same exducer size, but the inducer is 46.4mm up from the stocker's 43.25mm.
SO it widens the map, but reduces the max pressure ratio it can make.
BaldTurboFreak is offline
Old 07-31-2008, 08:26 PM   #33 (permalink)
Is this the RS6 wheel that was a subject of a post on another thread?.
LatinVenom is offline
Old 07-31-2008, 08:45 PM   #34 (permalink)
hmm Maybe...
Old 07-31-2008, 09:50 PM   #35 (permalink)
mena661's Avatar
hmm Maybe...
mena661 is offline
Old 08-01-2008, 08:53 PM   #36 (permalink)
Way to go BTF, now this is what I'm talking about, WAHOO!
Let's get SLIDEWAYS!
Solo Mach and No Cat
JPM custom shifter.
Barney Juice XPR 21
RMR Style Bar.
DDM Works PINK Breastplate
HKS Coilovers
lil goat is offline
Old 08-01-2008, 09:52 PM   #37 (permalink)
shabby's Avatar
How big is the exducer, 60mm maybe? The mitsu 16g has the same inducer, potent little turbo.
shabby is offline
Old 08-04-2008, 11:57 AM   #38 (permalink)
I have it written down somewhere, but that little fact got tossed aside when I found out they were the same size. I would assume 56-60mm.
I should have it back by the middle of this week, hopefully on and testing by the weekend.
you'll have to swing down from toronto,Eh? My buddy John (the one with the wicked MR2 I built on my site) is from toronto. Says we gotta go up there with the hotrods' to play. Seems there is quite a racing scene up there.....
Old 08-05-2008, 08:38 AM   #39 (permalink)
Originally Posted by shabby View Post
A little clip on the turbine wheel wouldnt hurt if nothing bigger fits, this is normally done on dsm's with great success. Normally people go with a 10 degree clip on a 16g sized turbo, but apperantly buschur went with a 25 degree clip on his 20g turbo.
Perhaps if it's nessicary, but I'll try to avoid it like the plague. Id rather cut it for a larger wheel.
Clipped Turbine Wheel
When an angle is machined on the turbine wheel exducer (outlet side), the wheel is said to be "clipped". Clipping causes a minor increase in the wheel's flow capability; however, it dramatically lowers the turbo efficiency. This reduction in efficiency causes the turbo to come up on boost at a later engine speed (ex. increased turbo lag). High performance applications should never use a clipped turbine wheel. All Garrett GT turbos use modern unclipped turbine wheels.
Old 08-05-2008, 04:43 PM   #40 (permalink)
shabby's Avatar
Its a poor mans turbine upgrade, normally found on dsm's
shabby is offline
Old 08-13-2008, 06:36 PM   #41 (permalink)
would this mod be a do it yourself mod?
Solo Mach exhaust and Cat
Windrestrictor, lil chromies
Dejon IC pipes and elbow
Wester's Hot Tune
Painted rear fascia
Aftershock Spoiler
Nassoa Member
ebeacham is offline
Old 08-13-2008, 06:51 PM   #42 (permalink)
Yes, you would take your KO4 turbo off and send it to BTF.
He will do the upgrades and returned it to you.
You then have to bolt it back on in the car but BTF will supply you with detail instructions for doing it.
Hope this helps.
I am sure BTF will elaborate more on this for you in case I'd missed something.
Old 08-13-2008, 07:09 PM   #43 (permalink)
Bagpypr's Avatar
Put me on the list as well! WOT we need is more WOT.
Please check out Norma Jeane @ Car Domain
PacificNWRoadsters member
Bagpipes are loud!
Bagpipes... the missing link between music and noise.
Bagpypr is offline
Old 08-14-2008, 02:18 PM   1 links from elsewhere to this Post. Click to view. #44 (permalink)
Well I have pricing for everyone. The total to have your turbo "bigwheel'd" will be $829.99.
That is assuming your turbo is in good shape. If it's wiped out or needs bearings we will contact you with an approximate repair cost.
Thats includes
Disassembly, inspection
CNC machining of the compressor housing to fit the 3.4mm bigger wheel.
Reassembly and balancing of the rotating assembly on a state of the art balancing machine.
Powdercoating: any color on the compressor housing add $45.
Swaintech on the turbine housing:add $75. (this one increases lead time- I'm at their mercy)
Old 08-14-2008, 02:24 PM   #45 (permalink)
Deepbluegxp's Avatar
How long does it take? Is it something that we can bring the car to you and you can do in one day if everything is ok.
See my car on cardomain.com
NASSOA Founding Member #48
Deepbluegxp is offline
LinkBacks (?)
LinkBack to this Thread: http://www.solsticeforum.com/forum/f120/stock-turbo-compressor-upgrade-47371/
Posted By For Type Date
BTF Bigwheel Kit - Chevy HHR Network This thread Refback 01-24-2009 06:29 PM
BTF Bigwheel Kit - Chevy HHR Network This thread Refback 11-17-2008 11:28 PM
BTF Bigwheel Kit - Chevy HHR Network This thread Refback 11-17-2008 06:35 PM
K04 Turbo upgrade - Cobalt SS Network This thread Refback 10-22-2008 10:39 PM
K04 Turbo upgrade - Cobalt SS Network This thread Refback 10-22-2008 10:06 PM
K04 Turbo upgrade - Cobalt SS Network This thread Refback 10-22-2008 11:12 AM
K04 Turbo upgrade - Cobalt SS Network This thread Refback 10-22-2008 04:16 AM
Turbo performance challenge PLAN by LatinVenom and BTFRacing - Solstice GXP Owners Forums Post #0 Refback 09-07-2008 08:08 PM
Turbo performance challenge PLAN by LatinVenom and BTFRacing - Solstice GXP Owners Forums Post #0 Refback 09-06-2008 10:27 PM
Turbo performance challenge PLAN by LatinVenom and BTFRacing - Solstice GXP Owners Forums Post #0 Refback 09-06-2008 09:17 PM
Performance challenge Plan by LatinVenom and BTFRacing - Saturn Sky Forum Post #0 Refback 09-05-2008 07:20 PM
BTF Racing, Inc. - Bald Turbo Freak This thread Refback 09-02-2008 09:30 PM
Opel GT compared to SLK 55 AMG [performance enhancement discussion] - Saturn Sky Forum This thread Refback 08-17-2008 04:54 PM
Opel GT vs SLK 55 AMG - Saturn Sky Forum Post #44 Pingback 08-17-2008 02:29 PM
Stock turbo Compressor upgrade - Pontiac Solstice Forum This thread Refback 06-26-2008 08:12 PM
