After a few issues with our molds we have finally put the finishing touches on our GXP Fog Lamp Covers. Here is complete install instructions with photos of the finished product. These photos are not photoshopped in any way. This new method of install and the improved mold make for a more factory look and don't allow any light to escape from around the outside edges.
Here's the Install instructions with photos. Those of you who have ordered these and have the old design, we will be happy to replace them with the newly designed version, free of charge.
Thanks for everyones patience.
Tony
The new kit includes the covers as well as a blockout vinyl tape precut to the lamp shape.
Start by removing the bezel from the outside of the lamp. This is just clipped in and pops off fairly easily. This is the same thing you would have to do if you were changing the bulbs in your fog lights.
Once removed, you will see the exposed foglamp.
Clean the foglamp thoroughly with alcohol and let dry.
Peel the vinyl tape off the backing paper and start with the top half of the lamp. Starting with the cutout around the mouting screw stick the tape along the edge of the foglamp. Using your left hand to hold the tape away from the lamp, smooth the tape on with your right index finger. The tape is very flexible and will conform as you pull it along. If you miss a bit, just lift it and try again. This take a little care and patience.
