Steve,
What has worked best for me is to take white string and run it across the hood edge to edge holding it in place with tape up by the windshield to each hood tip corner. Then remove the string so it is straight and not wrapped around to the edges, measure it (or fold it in half) and mark the middle with a marker. Place it back in the same spot. Then take another string and run it from that center mark down the hood to the center of the nose badge. Then take two strips of 2 inch wide painters tape and run them down the hood using the center string as the reference point for the inside edge of each tape strip. This will give you the 4 inch center line of the hood to gap the stripes. Do the same for the rear lid.
If you have removed your badges, then you can use three strings across the hood. The one listed above, one mid way, and one at the lower inner points of the headlight cut outs. Then use the three marker points vice the center line string to lay the 2 inch painters tape.
"BLUE DEMON"
