Go Back   Pontiac Solstice Forum > Site Help > Test Forum
Old 03-25-2005, 04:08 PM   #1 (permalink)
PAS22's Avatar
Problemo
If I try and log on at at my office with by home password is doesn't work. So, I even set up a seperate identity (PAS23) and it still won't log on! Any ideas anyone?
PAS22 is offline   Reply With Quote
Old 03-25-2005, 04:16 PM   #2 (permalink)
Administrator
Troy Roberts's Avatar
What is the error you are getting?
Did you try logging out at home and logging in to be sure that works?
Did you verify that the caps key is not on and you are typing it in with the exact capitalization? ie PAS22, not pas22
Troy Roberts is offline   Reply With Quote
Old 03-25-2005, 05:36 PM   #3 (permalink)
PAS22's Avatar
Logging on at home has never been an issue. When I try to log on at the office, using PAS22 and my password, the forumn issues a message screen that I need to log in. (I will have to get exactly what it says). When I set up a seperate identity and password at from my office the same screen still comes up. It doesn't matter where I attempt to log in it just keeps tripping back to the same message screen. I'm perplexed.
Old 03-25-2005, 06:23 PM   #4 (permalink)
Per Diem Administrator
brentil's Avatar
Check to make sure cookies are enabled and permitted for this website. If the website can't set the logon cookie when you try to logon it'll never think you've actually signed in. However you might not be able to set this depending on how strict the IT people at your place have locked down settings.
Save the Kappa!
NASSOA (TM)
Old 03-26-2005, 07:52 AM   #5 (permalink)
Administrator
Yep. Probably a cookie issue.
Old 03-26-2005, 07:56 AM   #6 (permalink)
achieftain's Avatar
QUOTE=Cookie Monster " Gimmee Cooookies!!!"
Pontiac 1926-2010
"We hardly knew 'ya"
Old 03-26-2005, 02:30 PM   #7 (permalink)
PAS22's Avatar
Thanks, I'll turn it over to the cookie department. I thought it was something internal.
Old 03-30-2005, 11:03 AM   #8 (permalink)
PAS22's Avatar
Hey I reset some of my internet profiles and like magic I can log on from my office PC! (Wonder what else I messed up in the process!)
Old 03-30-2005, 11:39 AM   #9 (permalink)
brentil's Avatar
Yeah sounds like you had some sort of cookie issue then. Since reseting your profile will also set the cookie settings to default I believe.
Save the Kappa!
NASSOA (TM)
Old 03-30-2005, 12:05 PM   #10 (permalink)
PAS22's Avatar
I think I defaulted all the internet settings, which I will have to watch closely because of our networking firewall issues.
Old 03-30-2005, 08:05 PM   #11 (permalink)
Administrator
Glad to hear it's working for you! Just watch out for the cookie police at work.
Old 03-31-2005, 03:09 PM   #12 (permalink)
PAS22's Avatar
Troy, 200,000+ posts? Doesn't leave much time for......
Old 03-31-2005, 10:09 PM   #13 (permalink)
Administrator
I may have modified that field a little bit.
