Closed Thread
Old 04-17-2006, 09:09 AM
   Rub marks inside of hood from fender
mceb's Avatar
Rub marks on under side of hood and/or wheel wheel:
Inside hood paint wear [rub marks under hood]
fender rubs hood
hood
paint
underside
fender
2006 VIN #30, first 1000 series, black exterior, sand/steel interior
mceb is offline
Old 04-17-2006, 09:10 AM
   New weather stripping added in late 2006 MY
mceb's Avatar
Weather stripping on new versions of car along side hood line? (new part after VIN 10,000?)
Missing Part in first 10,000. Read this! [hood weather strip]
hood
weatherstripping
Updated "clean" version with part # thanks to windface:
Missing Part in first 10,000. Clean Version!!! [weather strip hood seals]
mceb is offline
Old 04-27-2006, 11:09 AM
   Stereo, Radio stuff
mceb's Avatar
AztekzRpurty's aftermarket head unit replacement:
HOW TO: Aftermarket Headunit Replacement
Door disassembly (shows side speakers)
More interior disassembly (door panel and e-brake trim) pics inside!
How to burn ID3 tags on your MP3 CDs:
How to burn an MP3 CD for the CD player to show text [ID3 tags]
Wiring connections for headunit replacement:
Monsoon system headunit replacement
In dash navigation system:
InDash Navigation is Officially "IN"
headunit
stereo
replacement
speakers
door
MP3tags
Navigation
mceb is offline
Old 05-15-2006, 07:13 AM
   GM Wind screen
mceb's Avatar
Issues, changes from orginal spec for drilling holes for GM windscreen:
Problems with the GM Windscreen Installation.
mceb is offline
Old 05-26-2006, 06:51 AM
   Whining Noise / Carrier Replacement
mceb's Avatar
3rd Gear Howl.
Carrier Replacement
High Pitch Whine, Fuel Pump?
http://www.solsticeforum.com/forum/s...672#post270672
Carrier replacement
fuel pump
whine
Also this Scott found on CTS forum: (differential groan growl moan noise rear slow vibration)
LSD problem
mceb is offline
Old 05-30-2006, 01:01 PM
   Tire rubbing wheel well, TSB on issue
mceb's Avatar
Tires rubbing wheel well issue (TSB in 1st thread):
Rear tire rubbing? [TSB on issue enclosed]
Wheel rub problem
rubbing in wheel well
mceb is offline
Old 06-03-2006, 09:04 PM
   Gas
mceb's Avatar
Discussion of 87 vs. 91 Octane
Why would you buy a car requiring premium and cheap out with 87 grade gas?
Gasoline
Octane
Premium
Regular
mceb is offline
Old 07-07-2006, 01:33 PM
   Air bag indicator
mceb's Avatar
Informative post by small dealer on how the air bag sensing system works:
Passenger Sensing Air Bag System Information
mceb is offline
Old 08-02-2006, 06:19 AM
Administrator
SolsticeMan's Avatar
SolsticeMan is offline
Old 08-18-2006, 11:03 AM
   Foam Cubes
mceb's Avatar
Do not remove foam cubes in trunk pouches:
Don't let your dealers remove the grey foam cubes in trunk.
More on the cubes:
!@#(! Foam Cubes
mceb is offline
Old 09-08-2006, 05:49 PM
   Solstice Part Numbers
mceb's Avatar
Solstice part number list by VIN2020:
Solstice GM Part Numbers
mceb is offline
Old 10-10-2006, 07:51 AM
   Air Conditioner
mceb's Avatar
AC warm air TSB:
GM finally addressing AC Problem
mceb is offline
Old 10-12-2006, 12:52 PM
   Diy
mceb's Avatar
DIY Oil & Filter Change:
Oil Change [part numbers, instructions for DIY] - Pontiac Solstice Forum
along with
Oil Filter Change with Pictures
mceb is offline
Old 10-12-2006, 01:10 PM
   Winter Storage
mceb's Avatar
Things to do if storing your Solstice over winter:
Winter Storage Procedures and Tips
Winter
Storage
mceb is offline
Old 10-27-2006, 10:58 AM
   Fuses
mceb's Avatar
