Old 04-29-2005, 11:28 AM
   Reference Links
Administrator
SolsticeMan's Avatar
Reference Links to support site index
Magister Solstitium Sum!!!
No, I'm not Bob Lutz...
SolsticeMan is offline
Old 04-29-2005, 12:02 PM
   Solstice Specification Links
Administrator
Old 05-03-2005, 08:58 AM
   Seating, Fit, Seated Eye Height, Sightlines
Administrator
Old 05-06-2005, 07:08 AM
   Tire, Tire Technology, Tire Optimal Sizes, Discussion
Administrator
Old 06-15-2005, 07:51 AM
   Video Links
Administrator
Solstice_CNBC Discussion (Solstice Video): Solstice on Behind the Wheel (CNBC)
Saturn Video / Saturn Sky Video
Sky Video
Old 10-12-2005, 06:35 AM
   Wheel Dimensions
Administrator
Hooked on LSD
18" X 8"
Bolt Pattern = 5 X 110mm
55 millimeter offset
16mm bolt holes
35mm Center-bore or pilot hole diameter
Available as Painted, Polished, and Chrome, same outer surface and form, 5 spoke design.
Weight = 23.6 lbs for Painted & Polished, 24.6 lbs for Chrome.
Old 12-05-2005, 10:38 AM
   Pass-Key III+ (Passkey)
Administrator
What should I know about the PASS-Key III+ theft-deterrent system?
PASS-Key III+ is a passive theft-deterrent system. This means you do not have to do anything special to arm or disarm the system. It works when you insert or remove the key from the ignition.
When the PASS-Key III+ system senses that someone is using the wrong key, it prevents the vehicle from starting. Anyone using a trial-and-error method to start the vehicle will be discouraged because of the high number of electrical key codes
from here: MYGMLink Solstice FAQ
PASS-Key III - What is it?
Old 02-04-2006, 12:15 AM
   Golf Clubs in Trunk
Administrator
