http://vauxhall.co.uk/companyInforma...ml?indexNo=720
13/05/03 [May 13, 2003]
Vauxhall Lightning - our first concept car for 25 years.
LIGHTNING STRIKES AS CENTENARY CONCEPT DEMONSTRATES VAUXHALL RENAISSANCE
"Keep it simple, pure, and beautiful." The words of GM vice president Bob Lutz when launching the Solstice concept in the US.
This was the basic requirement for Vauxhall's stunning new concept car, the VX Lightning.
Being launched as a centrepiece to the company's Centenary celebrations, the VX Lightning is a two-seater roadster based on the same technical foundation as the Pontiac concept Solstice, first seen at the 2002 North American International Auto Show in Detroit.
Vauxhall's roadster concept, however, has been designed for British tastes, at GM's UK Advanced Design Studio in the Midlands.
Under the long bonnet of the VX Lightning is a new version of Vauxhall's all aluminium 2.2 ECOTEC engine, reworked with a supercharger to produce a maximum power of 240hp and 305Nm of torque.
A six-speed manual gearbox is mated to the new engine, which drives the rear wheels. The chassis incorporates independent suspension, the front end using a simple and reliable strut configuration with a rack and pinion steering.
At the rear, the independent suspension is all aluminium for weight saving. Overall, the car manages a near perfect 50:50 weight distribution for the best in handling and agility.
Kevin Wale, Vauxhall chairman and managing director says: "The VX Lightning says everything about where Vauxhall is heading. The car represents a return to our early performance roots when Vauxhall was famous as the manufacturer of the first true British sports car - while we continue to be both innovative and bold in exterior and interior design. "We have made great strides recently in terms of our interior packaging through cars like Zafira and Signum. Vauxhall is also about pure driving excitement - just look at the new VX220 Turbo.
"Ultimately the VX Lightning, as a classic roadster, represents the best of our past, and our future - a vehicle that is quintessentially British."
DesignDesigned in the UK, the VX Lightning is a classically proportioned sports car with a long bonnet and short rear overhang.
There are also some subtle echoes of the past, including the rollover hoops sculptured into the rear deck and bodywork which flows down into the cabin.
Fitting for a car with the presence of the VX Lightning, it sits on 19inch alloy wheels at the front (fitted with 245/35 Michelin Pilot tyres) while at the rear massive 20 inch alloys are fitted with 255/35 tyres.
Inside, deeply sculptured seats are finished in black and red leather, while red leather has also been used to trim the sweeping dashboard.
There are currently no plans to build the VX Lightning concept, however Vauxhall will be closely monitoring public reaction to this great new car
33257/SH120503
VX Lightning - technical specifications
Body/chassis structure: unique GM platform, based on the Solstice, with front engine and rear-wheel driveBody material: compositeChassis material: all steel, unibody Suspension: 4-wheel independent, strut front, adjustable for rate and travel Wheels: machined aluminiumFront: 19 x 8.5 inRear 20 x 9 in Tyres: front - Michelin Pilot 245/35R19Rear - Michelin Pilot 255/35R20
BrakesDiscs all-round
Powertrain
Engine: modified, supercharged ECOTEC L850 2.2L 4-cylinderEngine displacement (cu. in/cc):134/2200Max. horsepower (hp/kW):240/179Max. torque (lb.ft/Nm):225/305
TransmissionGM T56, six-speed manual (5th/6th gears overdrive).
Dimensions
Height (in/mm):45.0/1140Length (in/mm):153.1/4100Width (in/mm):71/1808 (1908mm inc. mirrors)Wheelbase (in/mm): 95/2415Track (in/mm):front -60.3/1532
rear - 60.5/1537Weight (lbs/kg):2900/1318
http://vauxhall.co.uk/futureModels/VXLightning.jhtml
The VX Lightning is a two-seater roadster based on the same technical foundation as the Pontiac concept Solstice, first seen at the 2002 North American International Auto Show in Detroit. Vauxhall's roadster concept, however, has been designed for British tastes, at GM's UK Advanced Design Studio in the Midlands.
Designed in the UK, the VX Lightning is a classically proportioned sports car with a long bonnet and short rear overhang. There are also some subtle echoes of the past, including the rollover hoops sculptured into the rear deck and bodywork which flows down into the cabin. Inside, deeply sculptured seats are finished in black and red leather, while red leather has also been used to trim the sweeping dashboard.
Fitting for a car with the presence of the VX Lightning, it sits on 19inch alloy wheels at the front (fitted with 245/35 Michelin Pilot tyres) while at the rear massive 20-inch alloys are fitted with 255/35 tyres.
There are currently no plans to build the VX Lightning concept, however we will be closely monitoring public reaction to this great new car.
Read the press release
VX Lightning - Technical Specifications
Body/chassis structure Unique GM platform, based on the Solstice, with front engine and rear-wheel drive.
Body material Composite
Chassis material All steel, unibody
Suspension 4-wheel independent, strut front, adjustable for rate and travel
Wheels Machined aluminium
Front - 19 x 8.5 in.
Rear - 20 x 9 in.
Tyres Front - Michelin Pilot 245/35R19
Brakes 4-wheel disc power
Powertrain Engine - modified, supercharged EcoTec L850 2.2L 4-cylinder
Engine displacement (cu. in/cc) - 134/2200
Max. Horsepower (hp/kw): 240/179
Max. Torque (lb-ft/Nm): 225/305
Transmission GM T56, six-speed manual (5th/6th gears overdrive).
Dimensions Height (in/mm) - 45.0/1140
Length (in/mm) - 153.1/4100
Width (in/mm) - 71/1808 (1908mm inc. mirrors)
Wheelbase (in/mm) - 95/2415
Track (in/mm) - front - 60.3/15, rear - 60.5/1537
Weight (lbs/kg) - 2900/1318
