Go Back   Pontiac Solstice Forum > General Solstice Discussion > Getting Your Solstice
Old 11-13-2009, 08:30 AM   #1 (permalink)
Small Dealer's Avatar
New Car Purchase from Stock and Oil Change Recommendation
It has come up from time to time, so here is GM's recommendations to dealerships on oil changes for cars that have been in inventory for a while. So go out and buy those remaining 2008s!
Lubricants & Oil Life Monitor
As vehicles are kept in stock for longer periods of time, questions may be raised not only by the new car prep personnel, but also by customers. Here are some suggestions as to proper business practices.
The Oil Life Monitor in new GM vehicles will count down as vehicles are started, moved and run for the purpose of battery charging. If vehicles remain in stock for longer periods, what guidelines should you follow to answer questions about the oil life monitor?
• When the vehicle was assembled the oil life monitor begins counting down the useful life of the oil. If the Oil Life percentage indicates below 90% of the oil life left before vehicle delivery and the vehicle is older than 7 months, it is advised that the oil be changed before delivery to the customer (An alternative would be to offer the customer a discount coupon good for a reduced cost oil change, to compensate for used up oil-life before delivery).
Important: The Oil-Life Monitor should not be reset at the time of delivery unless the vehicle oil has been changed.
• If the Oil Life Monitor indicates above 90% or the vehicle build date is within 6 months or newer, the vehicle may be delivered without additional action. There is always some period of time that a vehicle is in dealer stock before it is delivered, and that small drop in oil life is expected.
Important: If a vehicle remains in stock for 1 year or greater, you should change the vehicle engine oil.
INFORMATION POSTED ON SITE
Old 11-17-2009, 03:28 PM   #2 (permalink)
Windrestrictor!'s Avatar
Very informative post, thank you!
Christmas In July 20% OFF + FREE custom graphics with purchase of ELK.[/
Laser Engraved, Illuminated Windscreens for the Pontiac Solstice
Original "WindRestrictor" TM
* block wind turbulence
* maintain cabin temprature
* personalize your Solstice
* turn lots of heads!
more information >> info@windrestrictor.com
Call now to order 972-487-5987
Windrestrictor! is offline   Reply With Quote
Old 11-18-2009, 06:01 AM   #3 (permalink)
zzzybil's Avatar
sooooooooo translation - DIC says ( lol) 10-12K miles-guessin cuz mine said 11k - anyone know the time interval of owner manual ? is it the same 6-7 months ?
and dealership-(GM) @ 90% or 6-7 months ?......
kinda confusing
- i feel better about being OCD changing mine .....thanks for an eye opener
BOOsted 2.4
42lb injectors
3" tubes front to back
10 boost
38mm tial wastegate / bov
custom i/c (BELL)
Werks radiator
aem wideband
hi flo cat
HPTUNING - the hard part !!!
(tune therapy -> randy @DDM)
JET-HOT 2000
aerologic egt kit
DDM backbone
AEM boost control
custom .08ss heatshield
YEAH I DID THAT !
zzzybil is online now   Reply With Quote
Old 11-18-2009, 07:16 AM   #4 (permalink)
Believe the owner's manual will say, when the Oil Life Monitor shows 20% life left. But in no case more than 12 months.
