Old 07-26-2006, 07:20 AM
   Updates - open, ongoing, closed (product and support)
Small Dealer's Avatar
INFORMATIONAL POST. NO REPLIES IN THIS THREAD PLEASE. ANY QUESTIONS START A NEW THREAD. THANK YOU
INFORMATION POSTED ON SITE
Small Dealer is offline
Old 08-01-2007, 09:53 AM
This is a read only single location thread for open items that people are looking for updates on.
Information is added and moved between posts as needed.
Not intend this to be a thread where "updates" on service issues are posted.
OPEN
PRICE PROTECTION ADDED 10/05/2007
There was a base price increase of $370 MSRP for the 2008 base Solstice and $450 for the 2008 Solstice GXP, starting with production of December 19th.
There was a base price increase of $60 MSRP for both 2008 Solstice models starting with production of November 30th.
There was a base price increase of $60 MSRP for both 2008 Solstice models starting with production of October 5th.
This thread deals with price protection issues, but not a debate on if it was called for. Just information: 8/28 Price Increase and Price Protection Information
POWER SEAT HEIGHT ADJUSTER, DEALERSHIP/RETAILER INSTALLED UPGRADE SEPERATED 12/20, This section deals with just the possible purchase of required parts by an owner. UPDATED 6/14/2007
Here is a notice that Saturn Retailers received September 20th about the Sky. Not sure if the "upgrade" information will apply to the Solstice but thought all should see.
Originally Posted by Saturn Message
Seat Height Adjuster
We previously communicated that the Seat Height Adjuster would be introduced beginning with SKY units produced in September. This date is now forecasted to be November 1st. This feature will be standard equipment on all base and Red Line SKY vehicles.
Vehicles produced after June 26, 2006 can support the height adjustable seat and be retrofitted by replacing the driver seat. Vehicles built prior to that date do not have the necessary wiring harness necessary for the height adjustment.
Again, no more information then this. The interesting part will be to see how much is involved in "replacing the driver seat". Will it be just parts of the seat track or the whole seat frame?
Still have seen no information from Pontiac about an upgrade. Also have not noticed any Saturn messages addressing it. Have any of the Saturn Sky sites mentioned an upgrade? If so PM me the information and will add it here.
UPDATE
Been giving some more thought to what it would take for a 2007 Solstice owner to buy and to install the mid-year enhancement of the Driver's Seat Power Height Adjuster.
Site member gmarcucio is the only one to have tried it and posted about it. So their efforts have helped with this procedure. Additional information have been taken from Service Manuals, Parts Catalogs and various sources.
It is believed that all 2007 Solstices can be updated, as the wiring harnesses were changed in anticipation of the interim introduction of this feature.
One can check under their driver's seat to varify that the harness connections are available. gmarcucio reports, "The wiring for the height adjuster was already in my car built into the seatbelt wiring plug". See their post at: http://www.solsticeforum.com/forum/s...532#post495532
Another check would be to confirm a 20 amp circuit braker in the #37 slot of the Underhood Electrical Center (UBEC). (While there, not a bad idea to check the tightness of your fuses based on other owner's posts.)
The parts list would look like this, with June 2007 suggested list prices for reference:
#15942838 Driver's Seat Cushion Frame with Adjuster $466.13
#15859914 Driver's Seat Adjuster Switch $68.90
#15942912 Driver's Seat Adjuster Switch Bracker $12.63
#11588925 Bolt $2.13 (maybe replaced by #11561674)
#25800455 Driver's Seat adjuster Wire Harness $21.61
#15942941 Driver's Seat Cushion $76.54
Then to finsih the factory look, an owner could replace the seat trim with the cut out for the switch and a different shapped storage pocket (based on recent posts in other threads). One could always make a cut out of their own and save money on this last part.
#15942917 Driver's Seat Cushion Trim Cover #19B/19C Ebony Cloth $99.44
#15942920 Driver's Seat Cushion Trim Cover #192 Ebony Leather $134.59
#15942921 Driver's Seat Cushion Trim Cover #312 Steel/Sand Leather $134.59
#15942923 Driver's Seat Cushion Trim Cover #025 Ebony/Red Stiching Leather $134.59
Remove the seat from the car. Remove the manual adjuster and seperate the lower cushion. Assemble the new trim, cushion and adjuster. The switch attaches to the bracket and then is bolted to the adjuster, based on the illustrations in the parts catalog. Attach the wire harnesses, and reinstall the seat into the car. This is a little cleaner install than gmarcucio's install. They had to get a donor wire harness and used cable ties to attach their old cushion to the new adjuster frame.
So it looks like about $800 in parts and maybe a little more than an hour.
Please verify the wire harness and circuit breaker before ordering parts. Also check any part numbers with your ordering dealership. Also look for threads from any other brave souls who will go first, or actually second.
Keep in mind that gmarcucio reports that with the adjuster, the seat also goes a little lower than the stock manual seat.
Keep in mind GM's thoughts on adding factory features:
Recommendation/Instructions:
If the following items listed above are not available in a GM Accessory Kit, please do not try to add an OEM option to the vehicle. GM does not endorse adding any OEM system that was not originally installed on the vehicle from the factory. Any attempt to add an OEM option (that was not originally built on the vehicle) will not be covered under warranty and no technical assistance will be supplied by the Technical Assistance Center
Old 08-01-2007, 09:55 AM
ONGOING
PRICE PROTECTION ADDED 11/06/06
There was a base price increase of $1,000 MSRP for both 2007 Solstice models starting with production of August 28th.
There was another increase, this time $120 MSRP on both models starting with production of November 6th.
This thread deals with price protection issues, but not a debate on if it was called for. Just information: 8/28 Price Increase and Price Protection Information - Pontiac Solstice Forum
WEEKLY CONSTRAINTS
Will continue to run this one as it own thread. Now showing 2008 information.
2008 Weekly Constraint and Ordering/Allocation Information - Pontiac Solstice Forum
SAVING THE WINDOW STICKER
If you want to save the window sticker in the best shape, ask for a duplicate. This will come from GM in a big envelope with the adhesive protection still on it. IMPORTANTThis must be done before the dealership reports the car delivered to GM. After it is reported delivered, the system will not produce a replacement window sticker.
PASSENGER SENSING AIR BAG SYSTEM
A little piece with some background information on the Passenger Sensing Air Bag System in the Solstice.
Passenger Sensing Air Bag System Information - Pontiac Solstice Forum
WHAT IS A RECALL AND WHEN IS IT REQUIRED
A little piece about recalls to provide some background information.
What is a recall and when is it required? (FAQ) - Pontiac Solstice Forum
SERVICE INFORMATION POSTED ON SITE
Any GM Solstice Service Manual and Service Bulletin information found here on site, should be thought of as preliminary in many cases. Updates do occur during the year. That is why it takes so long before the printed version is available to order. If something is important, ask your dealership to check and see it the information is site is different from what shows in their system.
DEALERSHIPS REPORTING ISSUES WITH FIELD PRODUCT REPORTS
A thread about how GM and Pontiac would like dealerships to report any issues they find that they feel could be important to GM. A Field Product Report is the reporting method. If you feel that an issue with your car meets the definition, ask your dealership's service department to help out and file a report.
Have Dealerships Submit Field Product Reports - Pontiac Solstice Forum
Old 08-03-2007, 07:32 PM
Informational Post. No Replies In This Thread Please. Any Questions Start A New Thread. Thank You
CLOSED
GM ACCESSORY CAR COVERSUPDATE 9/12/2007
UPDATE 9/12/2007
The GM EPIC system still shows that the #19172066 will Back Order, but the locator shows dealerships are receiving them. So I think it will be ok to head over to your dealership and order the replacement covers.
UPDATE 8/24/2007
Still not quite available yet, but the part number for the new Solstice car cover has been released. It will be #19172066. 8/30, still shows as a part that will back order, but it now shows pricing. MSRP for the new cover is $295.
GM has released the information on how dealerships are to handle the exchange and possible cleaning of cars.
Subject: Staining of Front and Rear Fascia (Polish Fascia and Replace Car Cover)
Models: 2006-2007 Pontiac Solstice and 2007 Saturn Sky
Attention: This condition only applies to vehicles with the Pontiac or Saturn Accessories car cover.
Condition
Some customers may comment that their front or rear fascia may have some shadows or dark areas in the paint after their Pontiac or Saturn Accessories car cover has been removed.
Important: These Pontiac or Saturn Accessories car covers can be identified by the manufacturer's tag located on the hem line in the LF corner at the fender well. This tag will have a part number for Saturn, (17802877, 19158357), and Pontiac, (17802589, 19158355), on it to identify it as the old cover.
Cause
The vehicle or car cover may have been damp when the cover was installed. This may have caused some color transfer from the car cover material to the paint.
Correction
Customers are to return the Pontiac or Saturn Accessories car cover to their local dealer/retailer for exchange. At that time, the dealer/retailer will make arrangements to clean and polish the front and or rear fascia, if needed.
Note: Once a replacement car cover has been provided to the customer, the original car cover must be destroyed and scrapped by the servicing dealer/retailer in order to prevent it from being installed on another vehicle.
Parts Information
Pontiac dealerships can obtain new car covers from General Motors Service and Parts Operations (GMSPO). Saturn Retailers can obtain new car covers from Saturn Service and Parts Operations (SSPO).
The new Pontiac or Saturn Accessories car cover can be identified by the manufacturer's tag, located on the hem line in the LF corner at the fender well. This tag will have the new GM part number on it to identify it as the new cover.
Part Number-Description
19172067-Cover (Sky)
19172066-Cover (Solstice)
UPDATE 7/14/2007
The new covers are now expected to be available by the end of August. So exchanges will be able to done then.
PREVIOUS INFORMATION
Some may have purchased, through one source or another, a GM accessory car cover for their Kappa. Solstice part numbers were #17802589 & #19158355, and for the Sky #17802877 & #19158357.
Some users have reported that color transferred form the cover fabric to the car. There was a second hand account of that on the Solstice site. To limit this from happening, user should immediately remove the car cover. Keep the cover as there will be an exchange program. GM/Pontiac/Saturn will be contacting owners of the covers in the near future with this information. When replacement covers become available, owners will be recontacted to exchange covers. At that time there will also be an inspection of your car for any color transfer.
Just sit tight. Remove the cover. If you have a GM cover that you did not purchase from a dealership, you may just want to drop a note to your dealership's parts department. If you do not receive the first mailing, scheduled to go out around April 11th, drop a note to your dealership's parts department.
Here is the request GM sent out for names in March 2007:
SERVICE - TO: ALL PONTIAC DEALERS AND SATURN RETAILERS
ATTENTION: PARTS MANAGER
Subject: Potential Quality Problem with the
Sky and Solstice Accessory Car Covers
Message #: WIS20070157
Date: March 7, 2007
To: All Pontiac Dealers and Saturn Retailers
Attention: Parts Manager
General Motors is investigating a potential quality problem with the Sky and Solstice Accessory Car Covers. To support this investigation, please search your part sales records for any customer that purchased the following part numbers:
Solstice 17802589 or 19158355
Sky 17802877 or 19158357
Please provide the customer name, address and phone number along with which part number was sold in an e-mail to xxxxxxxxxxxxxxx.
Your assistance in providing this information is greatly appreciated.
2008 PRODUCT BROCHURESUPDATE 8/27/2007
UPDATE
2008 Brochures arrived today, August 27, in the Northeast. Two pages longer than the 2007 version, must be the two page tease on the G8.
Same pictures on the same pages, just harder to see.
The luggage rack is not on the accessories page. And the Ebony/Sand picture looks like last years Steel/Sand picture.
Original
Question has now came up about 2008 product brochures. No word as of yet on what form the 2008 brochures will take, individual model like 2006 or one giant everthing book like 2007. It was into August last year before dealerships were informed
2008 PRODUCT INFORMATION UPDATED: 5/24/07
The on line order guides are now available to dealerships in the password protected web portal of GM DealerWorld.
Look for the 2008 Weekly Constraints and Ordering/Allocation Information Thread for additional details.
Also look for achieftain's sticky thread on 2008 changes.
2007 SERVICE MANUALS UPDATED: 4/20/07
Helm Inc is the source for GM (among others) service manuals. www.helminc.com is the site. WintR has posted previously that there could be a link to helm for the MyGMLink.com page.
Currently the manuals are not available in the more affordable paper format. No know expected date.
The 2006 manual didn't become available until August of 2006. Hopefully for those that want it, the 2007 wait will not be as long.
UPDATE 4/18
We received out 2-volume, 3,000+pages 3 7/8" thick 2007 Solstice service manual set today. (Along with a G6 3 volume 7 1/2" thick!! set.)
Helm Inc ( www.helminc.com ) is not showing retail availability as of yet, but you can sign up for email notification when it becomes available. Shouldn't be long once the dealership annual subscription shipments are completed, then it should be on sale to the public.
UPDATE 4/20
Cpt_kludge is reporting that the Helm site is now showing the manuals in stock. Thanks Cpt_kludge for the update.
POWER SEAT HEIGHT ADJUSTER CLOSED 12/20/06
Solstice Power Seat Height Adjuster ... (AF2) Driver 2-way power seat height adjuster is not currently available, but is being phased in for 2007MY. Initial production of AF2 as standard equipment is expected to begin on November 14, 2006.
New Information
Here is a notice that Saturn Retailers received September 20th about the Sky. Not sure if the "upgrade" information will apply to the Solstice but thought all should see. There is a more firm target date then Pontiac's previous messages.
UPDATES
1) cincat12 is reporting that .."100% of the cars produced starting with VIN # 8359 will have power seat lifters.", based on a conversation with a GM employee in Michigan.
They say the height adjuster was phased in. So certain trims may get it sooner than others.
But everyone after #8359.
Thanks cincat12.
2) cincat12 has confirmed that their car does NOT have the seat adjuster. Which was expected with their VIN coming before #8359.
No word from Pontiac about confirmation or VINs.
I have seen nothing from Saturn either, or about possible upgrades. Keep it mind that the idea of an upgrade came from a Saturn message. Never been mentioned by Pontiac.
3) deluke is passing on a report of a Saturn Redline with the adjuster. VIN#8519, built date of 11/15/06 and with the Saturn Colbot Red/Ebony Leather trim.
4) Rusty reports that 8324 has the adjuster.
As of moving this to the closed post on December 20th, no word from Pontiac about the VIN breakpoints. Have not noticed any Saturn messages either.
Keep in mind that it was Saturn that said there maybe a dealership installed upgrade possibility, not Pontiac.
POWER DOOR LOCK SWITCHESCLOSED 10/21/06
Solstice Power Door Lock Switches ... were recently phased into 2007MY production. Although the Owners Manual makes reference to this feature, it only applies to vehicles produced after mid-October. Vehicles produced prior to this time frame cannot be retrofitted with this feature.
So it is no retrofit for the door locks.
2007 POWERTRAIN LIMITED WARRANTY IMPROVEMENT
On September 6th, GM announced improvements to the Powertrain Limited Warranty, Roadside Assitance and Courtesy Transportation for all 2007 models. They have now been extended to 5 years /or/ 100,000 miles. Lots of information in this thread.
9/6 GM Announcement(Warranty Improvements - "Elevate" Plan, 100K Powertrain)
2007 GMPP PURCHASE REFUNDSTHREAD UPDATED 10/25/06
With the announcement of the new longer Powertrain Limited Warrnaty, people who have purchased the General Motor Protection Plan extended service contracts will be effected. This thread contains information on the refund process.
GMPP Purchases on 2007s before 9/7/2006
2007 PRODUCT BROCHURES CLOSED 9/07/06
Question has now came up about 2007 product brochures.
Here is the offical word:
This year Pontiac has consolidated all of our 2007 models into a single catalog. This new format showcases Pontiac’s entire lineup while still providing
customers the detailed product information such as standard and available features, options, colors, and accessories.
2006 SERVICE MANUALS CLOSED 8/29/06
Helm Inc is now showing the 2006 Solstice service manual as available in paper. Thanks to WintR for catching this one.
WintR reports that you can link through to Helm, Inc from the MyGMLink site. Also can go to www.helminc.com and go from there, I believe.
AUTOBOOK PRICING CLOSED 7/29/06
GM Autobook, the salesperson desk top vehicle configuration tool, has been updated with both 2007 Base Solstice and 2007 Solstice GXP pricing and ordering information. This is effective with the July 25th revision, which came on line July 29th.
This delay in updating had kept many dealerships from "knowing" that pricies are out and from them pricing orders.
CONFIGURATOR AT PONTIAC.COMCLOSED 10/12/06
The configurator, "Build Your Own", tool at Pontiac.com is now updated. This allows better visuals of the car you are building, including adding of GM accessories.
Old 08-03-2007, 07:33 PM
ACCESSORIESUPDATED 07/02/2007
Before ordering just check with your dealership that there has been not been any part number, pricing or application changes.
Will try to check on availability regularly and update this post.
(A)= Available currently.
MOLDED COLOR SPLASH GUARDS-(sold in sets)
"Black" Front..........................17800974...(A)
"Black" Rear...........................17800975...(A)
"Deep" (Dark Ming Blue).............19154367....(A)
"Sly" (Dark Tarnished Silver)......19154361....(A)
"Cool" (Light Tarnished Silver).....19154349....(A)
"Agressive" (Victory Red)...........19154355....(A)
The molded color guard sets have been priced at $150 suggested retail.
No word if the other colors (Mean, Envious, and Pure) will be coming out.
The "Black" guards are the previously available guards. The accessory listing doesn't show a paint code number with them, as it does for the other molded color guards. So may not be a match for the actual Mysterious exterior paint.
Would be interesting to see some contrasting applications, such as a Pure car with Aggressive flaps, or a Mysterious car with painted calipers-red wheels cap center decals and Aggressive flaps.
CARGO MANAGEMENTUPDATED 11/13/2007
Console Storage Bag,
Ebony with embroidered Pontiac logo ($85 MSRP)...............19156075...(A)
You can store items in the zippered compartments of this Console Storage Bag. It fits over the center console of your Solstice and features cord cut-out for electronic devices. The center section was designed large enough to hold CD's and/or a standard CD player. Side sections are perfect for cell phones, MP3, maps, etc. This includes detachable shoulder strap. It is available in Black with the Pontiac logo.
Portable Trunk Organizer Bag,
Ebony.($99 MSRP)............................................. .19156892...(A)
This custom-designed Trunk Organizer Bag fits your Solstice trunk area perfectly. The zippered compartments located at both the top and sides allow for easy access. This bag includes a detachable carrying strap and is black with the Solstice logo.
Luggage Rack
Black............................................. ...........19156320...[(A)
Silver............................................ ............17800045...(A)
Rack Install Drill Kit.....................................19166260.. .[(A)
November 2007 and finally these racks are showing as available. The estimated install time is 1.5hrs. Important note: Information released indicates that a drill bit kit is required in order to install the luggage rack correctly and not damage the deck lid.
INTERIOR
Pedal Covers, brushed aluminum
Manual Transmission..................................1780 1274...(A)
Automatic Transmission..............................17801275 ...(A)
Site member glider rider reports on 7/18/07, that these covers include a matching dead pedal. Here is their install post: http://www.solsticeforum.com/forum/s...581#post534581
EXTERIOR
Locking Gas Cap.................................10326376...(A)
Front-End Cover
Black, With License Plate Cover, With V-Crest Logo.......17803120...(A)
Black, Without License Palte Cover, With V-Crest Logo...17800048...(A)
Passenger Compartment Tonneau Cover, Black.....19154788...(A)
Wind Deflector, Black, Without Logo....................17800058...(A)
Vehicle Cover Black, With Gray Sosltice Logo(NEW)........19172066
Currently not available. $295 MSRP.
Those that have purchased the GM cover previously, should discontinue use immediately. GM/Pontiac/Saturn will be contacting you about an upcomming exchange program for your covers. See the "Open Items" section for more details.
MECHANICAL
Cat Back Exhaust System GXP.................................19166012.......(A)
2007-2008 Pontiac Solstice GXP - Cat-Back Exhaust System with Welded on Tips... Put an aggressive growl in the exhaust note of your Solstice with this custom-built Cat-Back Performance Exhaust System. Tubing is fabricated of T-304 stainless steel using mandrel bending for precision and a smooth appearance. The system includes a semi-polished muffler and fully-polished welded on exhaust tips featuring the Pontiac logo. MSRP $850 (7/2/2007) and suugest install time of 1 hour.
ELECTRONICS
Portable Music Player Interface Cable...................88965274...(A)
Dealerships can also order this cable in 5 packs (178000595 (A)) and 20 packs (17800596 (A)) which would/could/should result in reduced costs per cable.
Personal Audio Link...........................................1917102 8
Personal Audio Link provides full "read" functionality* of the iPod, such as sorting by category (genre, playlist, artist, album, song, podcast or audiobook) and shuffling songs/titles within a selected category. The iPod-PAL connection is concealed inside the glove compartment (or auxiliary glove compartment, depending on vehicle) so there are no messy extraneous wires. The iPod also charges while connected to the PAL with the vehicle on. For 2007 Solstices with the upgeaded radios US8-Single Disc/MP3 and US9-6-Disc/MP3.
*iPod settings and content cannot be changed using the PAL.
Accessories generally have a smaller markup then regular parts. So the savings that can be obtained from online sources could be wiped out by shipping and handling costs. Can be a good way to make some points with your local dealership's parts department by ordering from them. Give it some thought.
Old 08-03-2007, 07:34 PM
The pictures have been released for the molded guards, listed in the accessories post above.
