Increase HP with an electric motor addon - Pontiac Solstice Forum
post #1 of 32 (permalink) Old 06-23-2005, 09:36 AM Thread Starter
SolsticeDesire's Avatar
I was looking around for some performance upgrades that can be added to cars and I found this one. It is an electric motor that replaces your altinator. It makes the car a hybrid. Basically, when you need power the motor kicks in and you get more boost. When the you brake or are coasting the motor turns into a generator and recharges the battery. There are some great benefits to this system:
1)Decreased fuel consumption
2)more power without wasting power by using a supercharger or turbocharger
3)The unit is tax deductable (because it is classified as a hybrid)
4)future addon will allow a boost system to be attached for up to 15 psi.
5)cheaper than a turbocharger
I sound a bit like a vendor, but I am actually just excited about this. What product will actually give you more power and eventually pay for itself through fuel savings and tax deductions.
Here is a link:
http://www.sigmaautomotive.com/elect...trocharger.php
Sly/Ebony, AC, ABS, LSD, MP3 CD Player, Floor Mats, Premium, Power and Convenience Packages
SolsticeDesire is offline
post #2 of 32 (permalink) Old 06-23-2005, 09:41 AM
Adrenaline's Avatar
Interesting, I may look into this as well.
Adrenaline is offline
post #3 of 32 (permalink) Old 06-23-2005, 10:42 AM
SolsticeMan's Avatar
I think these systems have some limitations, but basically have been around and experimented with for a while now.
Expect the battery pack to be heavy (>40 lbs), and boost somewhere around 7 hp or so, depending.
SolsticeMan is offline
post #4 of 32 (permalink) Old 06-23-2005, 11:13 AM
LBJay's Avatar
Wow...
Along with that, add one of these, one of these , a few decals and you'll be the terror of the street.
LBJay is offline
post #5 of 32 (permalink) Old 06-23-2005, 11:18 AM
Small Dealer's Avatar
Originally Posted by LBJay
Wow...
Is that first one a $95 blow dryer for your cars air intake?
Small Dealer is offline
post #6 of 32 (permalink) Old 06-23-2005, 11:27 AM
swatthefly's Avatar
Wow...
all you need now is a flux-capaciator!
swatthefly is offline
post #7 of 32 (permalink) Old 06-23-2005, 11:39 AM
If you look at page 4 (TAX INFO) for tax infomation you will see that it dosen't qualify for a clean vehicle tax credit. Only vehicles qualify, not add ons. And the vehicles have to be approved by the IRS.
http://www.fueleconomy.gov/feg/tax_hybrid.shtml
http://www.irs.gov/newsroom/article/...104549,00.html
post #8 of 32 (permalink) Old 06-23-2005, 12:12 PM Thread Starter
Wow...
Don't quite understand your negative response. If you read the article they make it seem like it could increase your hp significantly. If in fact it is only 7 hp it isn't worth it. They haven't actually released the results yet. I believe that you could make a system that does have a significant impact of 50 - 70 hp though. I was told that a similar system isn't allowed in Nascar, because it has too large of an impact on acceleration. I don't know if that is true, but if it is a similar system could have a large impact with the positives and not as many negatives (pretty much the only one being the added weight).
Just so that you know this isn't some cheap kit like the ones that you suggested out of an attempt to belittle. It is a kit is the range of 3 grand. Not that price makes something good, but it very may be something at least worth looking at. Maybe you responded that way because you want to leave your car as stock and not do anything. If that is the case fine, but no need to react stupidly when someone may be interested.
post #9 of 32 (permalink) Old 06-23-2005, 12:15 PM
PAS22's Avatar
Speaking from my racing experience bypassing your alternator, or in this case using an electric motor to produce electric power will only provide very mininal power gains. Not anything approaching what you would obtain through turbo-charging or super-charging.
You would be better off ordering the car without air conditioning and have a greater weight savings, and power/fuel economy advantage.
Vin No. 23 - Deep with Steel/Sand
"I'm sorry you don't like my ride, I didn't buy it for you"
ON WISCONSIN - GO BADGERS!
PAS22 is offline
post #10 of 32 (permalink) Old 06-23-2005, 12:16 PM Thread Starter
That's interesting, because they say it is in the FAQ section
post #11 of 32 (permalink) Old 06-23-2005, 12:20 PM Thread Starter
The power gains don't come from bypassing your alternator, but from the extra power that the motor adds to the system, but the system can also replace your alternator. Actually, you are really not bypassing your alternator, because the motor is essentially acting as an alternator.
post #12 of 32 (permalink) Old 06-23-2005, 12:21 PM
AV8AV8tor's Avatar
I don't think the motor looks big enough to provide any real improvements. Also, the biggest obstacle to electric hybrids seems to be with the size of the batteries and the Solstice already doesn't have enough trunk!
AV8AV8tor is offline
post #13 of 32 (permalink) Old 06-23-2005, 12:38 PM
Installing the ElectrochargerTM on your vehicle does not void your vehicle warranty coverage either.
http://www.sigmaautomotive.com/elect...rocharger5.php
Page 5 is their infomation page on how the warranty will not be voided. They use the Magnuson Moss Warranty Act improperly as their source. They state that the manufacturer or dealer must prove that the aftermarket part caused the failure.
The only way GM will void a warranty is if a branded title (such as a salvage title) has been issued for a car. So they actually got the use of the word "void" correct. GM states that any damage due to alteration or modification is not covered under warranty. Installation puts any engine, emissions, transmission, and drivetrain failure in risk of not being covered.
No proof required. That is becuase this would be an alteration or modification, not the use of an aftermarket part as offered some protection under Magnuson. Magnuson would only protect you if you used a "NAPA" alternator to replace your "GM" alternator, not the installation of the ElectrochargerTM.
post #14 of 32 (permalink) Old 06-23-2005, 01:17 PM
You guys need to give your BS detectors a tuneup! Don't you recognize a BS product when you see it?
Stonebreaker
1996 Impala SS 11.99 @ 115 mph
PhD in RE (Redneck Engineering)
It works in practice, but does it work in theory?
stonebreaker is offline
post #15 of 32 (permalink) Old 06-23-2005, 01:20 PM
mikefred1952's Avatar
The concept is nice. Might work in a basic vehicle but with the Soltice there is no room in the trunk for the batteries.
First 1000 order.
Silver w/everything except On-Star, XM, and smoker's
mikefred1952 is offline
