View Poll Results: Please respond with your experience with the rear differential
I have had no problems with the rear diff 402 50.25%
I have had a pinion seal leak 116 14.50%
I have had a driveline clunk 64 8.00%
I have had a vent leak 33 4.13%
I have had a complete rear carrier failure 15 1.88%
I have had a pinion seal leak and driveline clunk 69 8.63%
I have had a pinion seal leak and vent leak 24 3.00%
I have had a vent leak and driveline clunk 30 3.75%
I have had a carrier failure, and pinion seal leak 12 1.50%
I have had a carrier failure, and driveline clunk 7 0.88%
I have had a carrier failure, and vent leak 2 0.25%
I have had a carrier failure, leak, and clunk 26 3.25%
Voters: 800. You may not vote on this poll
Old 02-06-2008, 03:13 PM
spiky3480's Avatar
Update: After my third vent tube leak, they installed a filter into the modified differential hose. The past numbers are 5651682 (filter) and 22518665 (clamp). Its seems ok so far. Going in Monday to get the pinion deal recall done.
TEAM SOLSTICE 2008
ONCE YOU GO SOLO, YOU NEVER GO BACK
2007 Mysterious GXP- "Intruder"
Member of LISSC
Exhaust System Sound Clips
SOLO Performance Exhaust Sound Clips
Spiky3480 Modification Page
Mods: 70
Updated 8/13/08
spiky3480 is offline
Old 02-17-2008, 07:12 AM
   Will GM keep replacing our differentials?
Goldfinch's Avatar
I was just wondering how long GM will keep replacing the bad differential for us. Will they refuse to replace them on the same car over and over again. In a couple of years I don't think I would be very happy if I had to pay for a new differential some day. This and getting stranded will cause me to totaly flip out. Will GM pay for hauling my car to a dealership if it looses power in the middle of nowhere?
I do understand that problems will occure on new cars, It is the same as everything else, takes time to work out all the kinks.
I guess my biggest worry is in a few years am I going to have to pay for these problems out of my pocket.
Goldfinch is offline
Old 02-17-2008, 08:21 AM
spiky3480's Avatar
New update: The car was in for its fourth vent tube leak and they decided to replace the entire differential. Will have it back next week...and it now takes me out of the required cars for the recall work.
TEAM SOLSTICE 2008
Member of LISSC
Mods: 70
Updated 8/13/08
Old 03-19-2008, 06:14 PM
DanthManUA's Avatar
I voted that I didn't, but sure enough, it's leaking now.
DanthManUA is offline
Old 03-19-2008, 08:35 PM
Team Red Bull & Vodka
MSG_McKee's Avatar
Just got my second leak fixed @ 15,000 miles.
2007 Aggressive GXP (Manual) loaded minus On* and Smoker's Pkg (Born 11/10/2006 and picked up on 11/22/2006)
Current sMiles: 18,777
Click Here To See My Mod Page
TEAM RED BULL & VODKA 2008
MSG_McKee is offline
Old 03-20-2008, 02:46 PM
Len
Len's Avatar
Originally Posted by Bob W View Post
My 06 Solstice w/Manual Trans has a problem not shown on your list: Excessive Pinion and Ring Gear howl noise only on the steady pull side, not on decel or coast side. The noise is loudest at a steady throttle range of 35-45 mph which generally means 3rd or 4th gear, but I can also duplicate the noise in the other gear ranges when the engine is under a steady throttle. Since I have had no fluid leaks from the rear diff, I am choosing to take a wait and see approach for now to see if it get worse with more problems than just this excessive howl noise. At some point in the near future I will ask the dealer to fix this noise problem as it is both annoying and embarassing to hear this ugly noise while driving an otherwise beautiful looking and running car. I have 5900 miles on the car and it was put in service on 12-2-05. I first noticed the gear howl noise at about 2000 miles, but the noise has gotten louder this year. /Bob W
Had a similar problem plus a seal leak. They fixed the leak and than I complained of the noise. They replaced the whole rear last week and the car runs great. There were metal filings in the rear. Good Luck
Mysterious, Ebony, Chrome Wheels, Event Code 3800 Produced 3/16/06 Delivered 3/27/06, GM CAI & Cat Back, Kappasphere Shield, Shorty Headers
Solstice Received thread
Len is offline
Old 04-24-2008, 05:13 AM
rear end was great untill 26000 miles. no leaks no noise no klanks and three days after recall letter came in the mail
the rear blew out at 65 mph. on my way to work. (got some grey hairs from that one)
limpt it to the dealer in 2nd gear and lots of noise. thankfully it was only 2 miles away
and they were open. (iowa hours u never know)
1darksolstice is offline
Old 04-25-2008, 01:12 AM
31000 and I took it in to the dealer for a leak from the rear, not sure where & didn't ask. They replaced the oil and 2 weeks later replaced the rear diff with a new one. No problems since.
Wamin is offline
Old 05-06-2008, 06:43 AM
   Rear Differential
I've recently had an issue with a grinding sound coming from the rear and turning would accentuate the sound. Upon bringing the car into the dealer they explained that the differential fluid broke down and GM had another fluid. They said they drained the original fluid and replaced it with the new additive available for differential to eliminate noise. This was yesterday and I do still hear a faint noise and am concerned that the damage has already been done with the grinding. It's too bad that at a minimum GM can't offer the 100,000 mile warranty to the '06 owners that they do to the '07 and '08 owners. I'm not sure what my next step should be and when I asked if there was any damage done to the differential I was told there was none.
solstermiss is offline
