WTB: (for 2.4L) A/C compressor, center brake light, misc parts - Pontiac Solstice Forum
 1Likes
  • 1 Post By ChopTop
post #1 of 4 (permalink) Old 04-19-2017, 08:17 AM Thread Starter
All,
I'm in need of the following parts. I'm hoping that some of the members that have upgraded or are parting out cars can help. These are going on my 06 (2.4L), but I doubt that matters for most items:
- A/C compressor, with pulley
- Passenger door handle, though I'm certain I can make the other one work. Lock cylinder not required
- center brake light
- LH mirror glass. (I should mask better when welding.) Or, the whole mirror, but I just painted mine, so. *shrug*
- If I can find a good deal - convertible top. Black or blue.
- Trunk release button (the one that goes in the glove box)
- Interior light dimmer from a SKY. (I have a SKY interior.) I have the knob, but not the module that it plugs up to.
- Driver's headlight. It's okay if the lens is cracked or scratched. I really need the reflector cup and the bottom case.
If you have one or more of these parts available, please PM me. If you're anywhere near DFW, I can meet to pick up & pay, and will probably buy you a beer or frosty beverage of your choice.
If anyone is interested in a trade, I have a variety of stock 2.4L parts available:
- Head (complete)
- fuel rail
- injectors
- intake manifold
- exhaust manifold
- stock catalytic converter. (from an 06, has about 36k miles on it)
- engine harness
- Lots of other stuff that I can't think of at the moment.
Cheers,
Dave
Blue-ish 2006 2.4, Werks stage 1 turbo, GMPP cat-back, TCE Wilwood 6 piston front brakes, 4-piston rears , Stainless brake lines, slotted and drilled rotors, DDM braces, BR Racing coilovers, Spec aluminum flywheel, Spec stage 2 clutch, Werks aluminum radiator, DDM oil catch can, Autometer boost, water and AFR gauges, RKSport hood, Morimoto FX-R HID headlights, GReddy Profec boost controller @ 13PSI, custom A-pillar gauge pod.
In progress: custom fiberglass trunk lid.
Currently on engine #4!
post #2 of 4 (permalink) Old 04-19-2017, 11:42 AM
A/C compressor, with pulley - heck with Hoosier and eBay. They show up there.
- Passenger door handle, - cobalt door handle on Amazon cheap. Identical part.
- center brake light - good luck. they are available but EXPENSIVE. Check Hoosier for recycled unit.
- LH mirror glass. The glass pops out for replacement. Check eBay for mirror units which some times are cheap. Or check with Hoosier
- If I can find a good deal - convertible top. - You want an assembly or just the canvas? Assuming the assembly then you are constrained to black from an online source. They are NIB for $1600 right now which is a steal. Else you are in a crap shoot for a used one that can be of questionable quality.
- Trunk release button Amazon for less than $20. Get a couple because every time you pull the dash panel you break the damn thing.
- Driver's headlight. check eBay or Hoosier. he will have the best price. Tell him you want one that has a bad lens and you will get it cheaper. They come apart very easily with heat.
Carol's husband for 48 years
post #3 of 4 (permalink) Old 04-19-2017, 11:50 AM Thread Starter
Thanks, Rob! I didn't realize the Cobalt handle was the same, good sources for the other stuff. I'll start harassing Hoosier.
post #4 of 4 (permalink) Old 04-19-2017, 12:01 PM
ChopTop's Avatar
From my totaled Solstice thread: F/S Totaled Solstice's Thread
https://mcallen.craigslist.org/pts/6066020408.html
https://orlando.craigslist.org/pts/6058842813.html
Avoid CL scams, buy locally: https://www.craigslist.org/about/scams
raygun likes this.
ChopTop is online now
