Old 07-21-2008, 11:42 AM
   aerodynamics
just wondering if any company makes canards splitters side splitters rear diffusers vortex generators anything
THE DARK KNIGHT is offline
Old 07-21-2008, 12:03 PM
normsf's Avatar
Hello The Solstice has the frontal C/D aero of a brick, but were working on it, Thanks Norm norm's fiberglass home page
normsf is offline
Old 07-21-2008, 12:33 PM
hoo yah keep me updated i will be willing to purchace
Old 07-22-2008, 04:37 PM
Frank I's Avatar
Norm:
No doubt about the front C/D having the aerodynamics of a brick. Some SUV are getting lower numbers than the Solstice.
What do you believe the front airdam redesign is going to offer in improve airflow? Are you planning any other improvements?
Keep up the great work, your much appreciated!!!!
Frank I
07 Black GXP
Current Mods:
SOLO Performance Mach Exhaust
SOLO High-Flow CAT
Hahn Intercooler
Fijita Intake
Dashhawk
Beltronic G-Meter
Painted Calipers
Future:
ECM Mod
Slotted & Drilled Rotors
Frank I is offline
Old 07-22-2008, 04:51 PM
fr0stb1t3's Avatar
Any chance we can get some sky lovin' too?
fr0stb1t3 is offline
Old 07-22-2008, 05:51 PM
normsf's Avatar
Hello after the hood is finished, Im going to need a Sky over here Im almost done with the rear Sky diffusser. Thanks Norm norm's fiberglass home page
normsf is offline
Old 07-22-2008, 05:54 PM
fr0stb1t3's Avatar
Yay! Let me know when you get some pics, I may jump on that big time!
Old 07-22-2008, 06:10 PM
what do you think the differance will be with your splitter?
perris is offline
Old 07-22-2008, 06:48 PM
normsf's Avatar
Hello, without being too radical Im looking to push a little air away from the frontal contact with the rolling tires. Its the rolling tires that present a problem and when looking at the front of a solstice you see how exposed they are. thanks Norm norm's fiberglass home page
normsf is offline
Old 07-23-2008, 06:40 PM
could you make a front diffuser splitter out of aluminum maby some side splitters
Old 07-23-2008, 08:08 PM
Area 51 has a pile of Vortex generators on sale.
SCISOLSTICE is offline
Old 07-23-2008, 08:25 PM
idkfa's Avatar
i was actually contemplating utilizing a set on a hardtop. Coupled with a proper diffuser they might make a large difference in our extreme wake.
idkfa is offline
Old 07-23-2008, 08:33 PM
Moose GXP's Avatar
A splitter isn't going to do anything except reduce front lift and increase drag in the process.
NASSOA Founding Member
Moose GXP is offline
Old 07-23-2008, 09:05 PM
ya that's the idea of the splitter to give you down force. What I'm curious about is how it makes drag
Old 07-23-2008, 09:55 PM
spider's Avatar
It increases drag the same way it increases downforce. Probably gain a little air to the intercooler while blocking some to the radiator intake under the car. Anyone know of the Solstice having too much lift at the front end or the rear for that matter. Cornering at speeds in excess of 100 mph some downforce would be welcome but would need big spoilers & splitters which will cut into your top speed, mileage & tire wear. Just get a peel & stick fake hood scoop & call it a day.
spider is online now
Old 07-24-2008, 05:23 AM
Moose GXP's Avatar
Whenever you increase downforce (or just reduce lift) your more than likely going to increase drag. You're essentially pushing the vehicle downward and increasing it's resistance to forward motion.
Old 07-24-2008, 08:06 AM
Cool Sol's Avatar
Actually by removing the turbulent air from under the car with a splitter does more to reduce drag then the harm it may cause from protruding from the car, canards will add turbulence but once again its purpose is to control air turbulence along the side of the car and move it away from the rolling tires, once again reducing overall drag at speed.
Once a car is properly set up with ground effects, and you learn to use them properly i.e. the faster you drive it the better it holds the road, it's an amazing thing. The convertible top and flying buttress design does more to harm the aerodynamics then anything.
Life's not a journey to the grave with the intention of arriving safely in a pretty, well-preserved body.... but rather to skid in sideways, thoroughly used up, worn out, chewed-up and spat-out loudly proclaiming, "Wow Man, what a rush!!!
Cool Sol is offline
