Hi there!
I just bought a rear caster gauge on eBay about 30 seconds ago
I don't know if other GM cars do/will use this tool or not, but it doesn't seem like a bad thing to have around.
I've done DIY caster/camber/toe adjustments on my S-10 (lowered, coilovers, etc.) and had good results. I've not tried the Solstice yet. We used an angle gauge, string/jackstands, etc. We've since started using a laser level (which is nice for aligning the front and rear wheels on a motorcycle) but anything I can do to make this more repeatable is a Good Thing.
The previous owner apparently went off-roading in my car (the big damage being a tweaked passenger rear tie-rod) but did not have the suspension aligned. That wrecked the Cooper Zeon tires (which are going to be replaced as soon as I figure out what I want). I had the dealer align it as I didn't have time to do it myself, but I don't think they checked rear caster -- at least, it wasn't printed on their alignment sheet (which I had to ask before they'd give me a copy).
So, I think I would at least like to check it. Also, since I'm planning on new springs and shocks (GMPP or LNF Z0K) it would probably be a good idea to go over the alignment again.
Besides, I may see about building an adapter to use it for other stuff...
