Old 04-10-2008, 07:41 PM
   Control arm torque specs anyone?
motosolo's Avatar
Anyone know the control arm toruq specs off-hand? I installed Z0K springs and need to relax the suspension and re-torque the bushings.
motosolo is offline
Old 04-11-2008, 06:33 PM
WintR's Avatar
Upper or lower? The upper control arm mounting bolts are 81 lb ft, the lower control arm to frame nuts are 122 lb ft.
Mods: Kappasphere CAI, Clear Image Shorty Header, second horn, visor decals, mudflaps, tonneau cover, brake light flasher, trailer hitch, 'lil Chromies, trunk monkey, retune, DDMWorks backbone, GMPP Suspension
WintR is offline
Old 04-11-2008, 06:52 PM
kwtoxman's Avatar
Great info! I'm installing coil overs, anybody have another torque settings I need for the install???
thx
kw........
KW V3 coilovers :o
kwtoxman is offline
Old 04-12-2008, 07:46 AM
motosolo's Avatar
Hate to be a pain, but I'm also installing the Z0K cross brace which mounts to the frame and differential and could use those torque specs as well.
Thanks.
motosolo is offline
Old 04-12-2008, 09:05 AM
WintR's Avatar
Sorry, the Z0K isn't included in the Service Manual. I have to assume the torque settings are included in the install kit instructions. Maybe if you PM Small Dealer?
WintR is offline
Old 04-12-2008, 09:17 AM
Small Dealer's Avatar
From reading posts here on site, I think the Z0K crossmember just includes some or different stiffening material inside.
If so the torque specs should be the same as the only one shown in the service manuals.
Looking at 2006/2007/2008, the 4 support bolts should tighten to 100 N·m (74 lb ft), the 8 rear control arm reinforcement bolts should tighten to 22 N·m (16 lb ft) .
Is that what you came up with WintR?
Oh yea, the 2 Differential Carrier mounting bolts should tighten to 175 N·m (129 lb ft).
INFORMATION POSTED ON SITE
Small Dealer is offline
Old 04-12-2008, 09:19 AM
WintR's Avatar
Thanks.
Well, I don't know why you would need to move these: if you disturb the tie rods, the jam nut is 44 lb ft. If you find yourself moving the stabilizer bars, the bolts that attach them to the body are 41 lb ft, and the link nuts are 53 lb ft. And the steering knuckle attachments are, tie rod end nut and upper ball joint nut, 22 lb ft, lower ball joint nut, 30 lb ft.
The ones you have to change: lower shock mounting nuts are 21 lb ft, uppers are 35 lb ft.
WintR is offline
Old 04-12-2008, 09:34 AM
WintR's Avatar
Yep. I hope motosolo knows he has to drop the differential to replace the crossmember, though.
WintR is offline
Old 04-12-2008, 04:14 PM
motosolo's Avatar
Thanks WintR, I think I needed every spec you listed as I had to pull more apart to get the shocks in than expected.
I just finished the cross brace and didn't have to drop the diff, just had to put a jack unit it.
motosolo is offline
Old 04-13-2008, 11:28 AM
WintR's Avatar
I guess the Service Manual says drop it because it's safer that way. I can't think of any other reason, if you can juggle the brace out without over-stressing the universal (CV) joints in the drive shaft.
WintR is offline
