I was going to wait until it was completely done and I tested them out.. but I couldnt resist.
We've been working on making the cts-v brembo calipers fit on the stuck hub knuckle. the hub knuckle had to have some machine work done in order for this to all fit properly.
My friend did all the machine work. He has made a lot of various custom things for nissans, and toyotas, mostly for drifters. He recently made a bracket to put cts-v brembos on a 240sx, and wanted to try to put a set on a solstice.
CTS-V calipers, with Z06 14" rotors.
Stock brake setup
The brake setup cost me about $600 and that's include the rear calipers. Which we have not started working on yet. Machine work was free
Well plus I needed brake pads, racing pads I got were about $240, but street pads are under $100.
1x Caliper pin kit - ~$21 (pair)
2x CTSV Calipers - ~$110 (each)
2x Z06 rotors - ~$100 (each)
1x Street pads - ~$100 (pair)
1x Racing pads (HT10) - ~$240 (pair)
2x Banjo bolt 10mm x 1.00 - ~$4 (each) *verified 10mmx1 from napa + copper washer ID:0.40 OD:0.65" *
I needed new tires and my wheels wear pretty scratched up so I got some Enkei PF01 18x8 +40 with some Nitto NT01s. The stock wheels and even my other aftermarket wheels (Moda 18x8 +45) would not fit with this brake setup but the PF01s fit without spacers.
Weights:
New
CTS-V caliper: 8lbs
Z06 rotor: 26lbs
Enkei PF01: 18lbs
TTl: 52lbs
Stock
Stock caliper: 14lbs
Stock rotor: 17lbs
Stock Wheel: 26lbs
TTl: 57lbs
My Old
EBC dimpled rotor: ??lbs
Moda MD2: 28lbs
TTl: ??lbs
