The dangers of replacing coil springs - Pontiac Solstice Forum
Old 01-27-2013, 07:49 PM   #1 (permalink)
Ben and Russ show want can go wrong when replacing coil springs on a vehicle.
Pontiac and other cars video collection
trev0006 is offline   Reply With Quote
Old 01-27-2013, 10:46 PM   #2 (permalink)
BuzzardT's Avatar
And these guys know what they are doing.. You always use a spring compressor when changing coil springs.
08 Auto N/A
BuzzardT is offline   Reply With Quote
Old 01-28-2013, 05:21 AM   #3 (permalink)
I actually take it one step further (after punching a hole through the wall of my shop). I safety wire the spring after compressing it with the spring compressor.
bb_kaytor is offline   Reply With Quote
Old 01-28-2013, 01:26 PM   #4 (permalink)
BuzzardT's Avatar
Not a bad idea at all. When working with coil springs if you want to keep your body parts CAUTION is the main idea right next to SAFETY.
08 Auto N/A
Old 01-28-2013, 09:05 PM   #5 (permalink)
carnut122's Avatar
It pays to do your homework and know if the spring is still under tension. I always breathe a sigh of relief when I get done decompressing a spring.
carnut122 is offline   Reply With Quote
Old 01-29-2013, 07:49 AM   #6 (permalink)
EarthNTX's Avatar
I knew they could do that but I've never seen one in action.
Live and learn and thanks for the video.
EarthNTX is offline   Reply With Quote
Old 01-29-2013, 09:52 AM   #7 (permalink)
2KWK4U's Avatar
If you look closely, it seems they WERE using a spring compressor. You can see the shiny hex head at the bottom centered on the spring. This isn't a strut or coilover suspension, so they were using the type of compressor that you put through the center of the spring. Either they didn't install it right, or the compressor failed...
Stored AGAIN for two years instead of bringing it to Russia
2KWK4U is online now   Reply With Quote
Old 01-29-2013, 10:55 AM   #8 (permalink)
Exactly. When mine went, it was a metal defect in the spring compressor that gave way. The pin holding the bottom hook sheared off. It is amazing the amount of energy those damn things contain. I treat every coil spring like it is a hand grenade about to go off.
Old 01-29-2013, 01:37 PM   #9 (permalink)
BuzzardT's Avatar
I will give the guy credit..I don't think Jesus Christ would have been the first words out of my mouth. It took me several times watching it, but I did finally see the Spring Compressor Nut..
08 Auto N/A
