Lowering - Page 3 - Pontiac Solstice Forum
Old 01-15-2013, 08:01 AM   #31 (permalink)
Originally Posted by wspohn View Post
Has anyone bump steered a Solstice? Ground clearance considerations aside, I wonder if dropping one a couple of inches wouldn't introduce some unwanted bump steer.
In my case, the only difference that I noticed was a bit harsher ride because of the reduced travel. I noticed no difference in steering.
I reduced the preload on the springs which helped but it is still noticably harsher than stock.
rob the elder is online now   Reply With Quote
Old 01-15-2013, 09:55 AM   #32 (permalink)
idkfa's Avatar
It's pretty routine to check this when building a race car, and I just figured that one of the serious solo or race guys would have done it, but I guess they aren't watching this thread!
I wonder if it's been answered over on the scca boards. If you ever do hear back, I'd love to know as well.
Old 01-17-2013, 08:28 AM   #33 (permalink)
Carpe Diem's Avatar
Here are some of Punisher at various heights. One of the advantages of BC is you can move it up and down when you wish.
Get Mysti out of the shop tomorrow. Hood dents gone and new front facia and passenger-side grilles. Having the front arrowhead emblem and bump removed. (A nose job.). Anyway, while she was up on the rack, I was looking around underneath. I see some damage to the exhaust flex coupler and a couple other spots from rubbing over speed bumps. She's lowered 1-1/2", and I supposed she's settled a bit more than that. I have BC coil overs as well.
Rob, did you have The Punisher realigned each time you changed the ride height?
Carpe Diem
'Mysti' - '08 Mysterious 5-spd GXP, Custom HP tune, Hahn I/C, K&N filter, DDM ProBeam & Backbone, splash guards, Z0K Sway bars, poly bushings & BC Coilovers, Magnaflow catback, Solo hi-flo cat..
Old 01-17-2013, 08:34 AM   #34 (permalink)
Carpe Diem's Avatar
I believe bump steer is a factor af alignment rather than ride height - specifically toe-in and camber. There are several threads here that discuss bump steer.
Carpe Diem
Old 01-17-2013, 10:49 AM   #35 (permalink)
Yes, but changing the ride height changes the relative angles of all the suspension parts, moving them of of their designed 'sweet spots'. Thus a bump can have a more extreme effect on toe and camber angles than it would at the original ride height.
Not an expert here, so don't know that it WILL have such and effect, just that it could.
Old 01-17-2013, 11:00 AM   #36 (permalink)
wspohn's Avatar
I asked the same question on the Kappa board in hopes that a solo type who has been through it would respond (nothing so far).
Good explanations at
Bump Steer Explained - Circle Track Magazine
and
Longacre Racing Online -- Tech Article "Bump Steer "
Dave at DDM said he may have a graph of toe vs. suspension travel for the Kappa suspension and will post if he can find it. I'll repost here if he doeas.
1958 MGA Twin Cam (race car)
1965 Jensen CV8
1969 MGC roadster
1969 Lamborghini Islero S
1988 Pontiac Fiero GT
Bill in BC
Old 01-17-2013, 11:43 AM   #37 (permalink)
I had a friend that owned a 1970 trans am Mustang (ex Jones car I think). Ford relocated the upper and lower control arm chassis mounting holes 2" higher.
jeff465 is offline   Reply With Quote
Old 01-20-2013, 08:12 AM   #38 (permalink)
jackl's Avatar
Eibach Pro(gressive) on my 2006 Sol...
Other info in signature... Cheers!
SSOOO Facebook Group
2006 Solstice - DDMWorks [Stage II Supercharger, Race Backbone, Powder Coated Valve Cover, Coilcover, A-Pillar Gauge Pod & Header Heat Shield Blanket], Privat Gassen wheels (8.5"F & 9.5"R) w/245/40ZR19 (F) and 255/40ZR19 (R) Hankook Ventus V12 Evo, Solo [SQR2 Exhaust & High Flow Cat], Eibach Pro springs, VDO Gauges, Razzi wing, JPM [Shifter, Centre console & Door pads], Tint*Master Tint, Kappasphere [KappaShield, KappaROO Pouches & KappaATTIC], Kuda Cell Mount
jackl is offline   Reply With Quote
