I've got the shoehorn if you've got the cash!! Muhahahahahaha!
Sometimes its good to be Evil...
If you want bang for your buck get a Turbo or Nitrous. Nitrous is easy on the pocket but if you keep having to fill up that bottle it gets expensive. Turbo is pretty much a one time cash drop that keeps giving power ...till something breaks.
Starting up a business to make parts for you guys! Let me know what you are interested in!
Avatar is the 1954 Corvair Dream Car, My most favorite car of all time!
i feel the car needs more hp so i bought a chip.did anyone try this or has . a nother solution.i find the car is good 0-60 but lags after that thanks
Hey Bob, where did you purchase the chip from or you can PM me the info. I'm all about upgrade. I can possibly get 200hp from my car if i can get a chip. Please, please i beg of you. O,OK, not really begging but hook me up for with some info.
__________________ #1928 Delivered Mysterious Home Oct.19, 2005All past augmentations:, GM Performance Exhaust, Limo Tint, Eibach1"1/4 lowering springs, chromies, Headers, Random Technology High Flow cat Findanza Lighten Flywheel, RKsport Carbon Hood,Hahn S/3Turbo Charger, Greddy BOV, Auto Meter A/F Gauge & Boost , Vertical doors, Oil Catch can, Gravana J2 staggered set wheels, EBC Dimple drilled slotted rotors, Hawk Performance brake pads, Proxis T1R tires, Carbon Fiber Gas Brake & Clutch pedals.
me too ... a chip is what I have been asking about ...
__________________ DDMWorks Supercharger kit #11 - STAGE II- DDMWorks 3 guage pod with PLX gauges (boost/afr/oil temp)- Koni Sport shocks f/r-DDM ProBeam-DDM upgraded brake kit(drilled/slotted rotors-ss brake lines-ceramic pads)-DDMWorks 4-1 long tube headers and hiflow converter-JPM padded center console-DDMWorks Backbone (in RED)-SOLO SQR-2 dual center exhaust-Norms Painted (SLY) rear valence-Kazera KZ-L wheels w/Bridgestone RE760 Sport tires (255/45/18)Waiting on Stage III and the STB (Shock Tower Brace)
My observations with dynoed chips is : save your money. In a word, they
do practically nothing, sometimes even less than nothing and most require
running high test gas as well. Any gains they report are usually limited to a small
portion of the curve, and are essentially inconsequential. Go over to the major
chip tuners and examine their dyno sheets closely. I don't think you'll be impressed. Cold air induction systems are also available at a healthy price and the two tests I saw showed a max 2HP gain (within error of measurement).
"Cold air" is a euphemism - the air is not noticeably colder than what comes thru the stock system. If it were that easy to gain appreciable HP, GM would have done it for the little it would have cost them. Realize that air is moving thru the intake pipes at a high speed and has little time to heat up.
[. Cold air induction systems are also available at a healthy price and the two tests I saw showed a max 2HP gain (within error of measurement).
"Cold air" is a euphemism - the air is not noticeably colder than what comes thru the stock system. If it were that easy to gain appreciable HP, GM would have done it for the little it would have cost them. Realize that air is moving thru the intake pipes at a high speed and has little time to heat up.[/quote]
Does that mean you think the after-market cold air intakes are not worth buying then? I thought they were reporting about 10 HP gain with them.
Sorry you are getting knocked around Bobscars. PM me if you want to know what they find so funny and maybe I can help. Don't know what you bought but I can try to help.
thank you for the reply & not being awise guy like some others
I'm not trying to be a wiseguy if you're talking about me. I'm being serious when I say PLEASE tell me it's not the eBay chip. All it does is trick your engine into running rich, which after about 100 miles or so your ECU realizes what is happening and reprograms itself to correct the error, thus rendering your 'chip' useless.
So I'm just praying that you didn't fall for that scam. I'm concerned to be honest. I don't want to see fellow Solstice owners bite into lame scams like that.
#17313 | Scarlett! | AC | ABS | LSD | Pwr | Conv | Single MP3 | Monsoon! | All but lost...
