Old 08-02-2008, 01:34 AM   #1 (permalink)
Rickady88GT's Avatar
Need help getting measurements.
I would like to transplant a Solstice suspension into another car. BUT before I spend any money on this kind of project I need to do some research.
If some one is willing to crawl under their Sol and get as many pictures and measurements as you can I could I can use the info to see if the Sol suspension will work for this transplant.
Basically I need to know the exact locations of the "A" arm mounting points relative to each other.
How far apart are the upper and lower "A" mounts, how far apart are the left and right side mounts, how far apart are the front and rear "A" arm mounts?
And any other info that might help.
Thanks, Rick
I will own a V6 Kappa even if GM does not offer one as an engine upgrade. I have made my mind up, I want the Cadillac CTS 3.6L V6 with a 6 Speed manual tranny. And I will do the conversion my self if I have too :)
Rickady88GT is offline   Reply With Quote
