reBar or DDM Backbone - Pontiac Solstice Forum
Old 11-22-2010, 09:04 AM   #1 (permalink)
Ozone2552's Avatar
My Christmas present this year is a going to be either a reBar or a Backbone brace by DDM. Before deciding I would like to hear some testimonials from people who have these currently (or previously) installed. If you have switched between the two please explain why. Thanks in advance.
Year:2006
Trim: Base
Color: Cool
Transmission: 5-speed manual
Interior: Ebony Cloth Seats
Wheels: Powder Coated Rims
Options: no power options.
Pre-First 1000 VIN # 100538 of 700.
Modifications:
K&N Hi-Flow Drop-in Filter
PCM4Less ECM Tune
Color Matched Splash Guards (front and rear)
DDM Works Backbone (Street) and Pro-beam
Solo High-Flow CAT
Hankook Ventus V12 Evo tires; more to come...
Ozone2552 is offline   Reply With Quote
Old 11-22-2010, 09:33 AM   #2 (permalink)
AKA SolWhat?
DaveOC's Avatar
The ReBar (Kappasphere) and Backbone (DDM) address two different issues with the handling of the Kappa. It's almost impossible to compare the two for that reason.
Please read the description of the ProBeam and the BackBone on this site:
DDMWorks Solstice Products
Substitute ReBar for ProBeam in those descriptions.
I have both the ProBeam and the Backbone installed and together they have proved to be the biggest bang for the buck spent of all the things I've done to this car. I notice the difference in the handling of the car before I was out of the parking lot at the place I installed them.
1st 1K - #741
DaveOC is online now   Reply With Quote
Old 11-22-2010, 09:37 AM   #3 (permalink)
wspohn's Avatar
The reBar seems to install most easily, but that is partly a function of the reduced number of attachment points.
I looked at this carefully when shopping for this sort of product for my car and concluded that the DDM Probeam was the best because it had attachement points to suspension and frame, was reasonably priced, and was easier to install than the Factory ZOK part.
I would also buy the backbone since they have a special right now and you can get it for only $30 more!
I am not as much a fan of the front reinforcement strut.
1958 MGA Twin Cam (race car)
1965 Jensen CV8
1969 MGC roadster
1969 Lamborghini Islero S
1988 Pontiac Fiero GT
Bill in BC
Old 11-22-2010, 12:13 PM   #4 (permalink)
Administrator
MomsSol's Avatar
ProBeam (DDM's and a better design - as told to me by a GM Engineer ) and the Backbone ... together - priceless.
The Backbone significantly reduces the bump steer.
The ProBeam significantly increases the 'hug of the road' in a turn.
I give both
Both together -
#139640 '07 NA Sly Fully Loaded 12/1/07- Wester's Tune, CAI, Magnaflow Stainless Catback Exhaust, Carolina Custom Armrests and Door Pockets, Custom Painted Engine Cover, Carbon Flash Painted Grills, Custom Painted Guage Bezel, Air Oulets Bezels and Shifter Bezel.
Team Solstice
NASSOA(TM)
Old 11-22-2010, 12:47 PM   #5 (permalink)
Hard question to answer, as you are asking about the difference between apples and oranges -- they are each designed to do different things.
I have both, and you will be happy with either or both.
Now, if you asked me which -one- to get, my answer would be...
Radio Doc is offline   Reply With Quote
Old 11-22-2010, 02:05 PM   #6 (permalink)
I'm going to go out on a limb here, and guess the person meant Probeam vs Rebar, not backbone vs Rebar.
If such is the case, I would go with the Probeam. If you are planning on doing anything SCCA, the installation is slightly different, and you should look up some posts by snaponbob.
2008 GXP
GM Stage II/GMPP Turbo Upgrade, Dejon IC, GMPP CAI, Dejon Pipes & T-Bolts. Quaife ATB.
DDM Backbrace, DDM Pro-beam
2010 Nissan Frontier V6 6spd 4x4
1992 GMC Typhoon
Old 11-22-2010, 02:16 PM   #7 (permalink)
12_month_wait's Avatar
I personally have both the reBar and the backbone installed. I prefer that setup.
Lots of probeam vs. reBar discussion here:
DDM Pro Beam
"Thou shalt make a GM vehicle** people will like."
**excluding Corvette and other desirable GM vehicles
-Bob Lutz
12_month_wait is offline   Reply With Quote
Old 11-22-2010, 04:43 PM   #8 (permalink)
Ozone2552's Avatar
[QUOTE=MGar;1006068]I'm going to go out on a limb here, and guess the person meant Probeam vs Rebar, not backbone vs Rebar.QUOTE]
yes that is what I meant; thanks. Also, to address everyone else's responses, I like the thought of a combination of the two; something I had not considered before. Looks like I am already starting a list for my birthday
Year:2006
Trim: Base
Color: Cool
Modifications:
PCM4Less ECM Tune
Solo High-Flow CAT
Old 11-22-2010, 06:58 PM   #9 (permalink)
GPSOLcoupe#26's Avatar
[QUOTE=MGar;1006068 Also, to address everyone else's responses, I like the thought of a combination of the two; something I had not considered before. Looks like I am already starting a list for my birthday [/QUOTE]
We have only the DDM Backbone, and have been VERY pleased with the difference it made in the handling. DDM posted a few days ago that they were having a combo sale, so you could pick up both the Backbone and the Probeam and save some serious coin. Splurge for Christmas or make it an early B-Day present.
GPSOLcoupe#26 is offline   Reply With Quote
Old 11-23-2010, 12:13 AM   #10 (permalink)
Carpe Diem's Avatar
I have the BackBone and the ProBeam. I'd do it all over again.
I think DDM now has some kind of a package deal going for BackBone, ProBeam and the front brace.
Carpe Diem
'Mysti' - '08 Mysterious 5-spd GXP, Custom HP tune, Hahn I/C, K&N filter, DDM ProBeam & Backbone, splash guards, Z0K Sway bars, poly bushings & BC Coilovers, Magnaflow catback, Solo hi-flo cat..
Old 11-28-2010, 07:29 PM   #11 (permalink)
eco
Just ordered all three braces from DDM. Early Christmas present to myself!!
eco is offline   Reply With Quote
Old 11-30-2010, 09:33 AM   #12 (permalink)
WickedMike's Avatar
I had a rebar and had to remove it when I installed a solo exhaust. I purchased a Probeam, does same thing as rebar, because it installs much differently and has exhaust clearance. Also have the backbone and believe that the combination of both (rebar or probeam) and a backbone makes a huge difference. I suggest both for everyone.
07 Aggressive NA, 5 spd, purchased 11-06 SOLD 9-17-08
09 WickedGXP 9-25-08 Automatic, Gray stitching, Red calipers w/GXP decals, shorty antenna, windscreen, side grill and backup light covers, leather armrests, console & door pockets , de-badged, pass mirror, pulsing third light, red eng cover,GMPP CAI & Stage Kit, DDM Probeam, Backbone, Clear bra, Aug power for GPS, garage door opener in header, JPM lumbar seat inserts, SOLO Mach Shorty cat back, GM accessory wheels,Conti extreme contact tires
WickedMike is offline   Reply With Quote
Old 11-30-2010, 04:40 PM   #13 (permalink)
There is a third piece missing, however you will not find it on this forum.
It is also less than $100.00
Old 11-30-2010, 10:33 PM   #14 (permalink)
Sly Bob's Avatar
I'm installing mine LV at MMM8. Judging by the reviews thus far, it's really going to tighten up the front end.
Delivered on May 27, 2008
Sly Bob is offline   Reply With Quote
Old 12-01-2010, 04:09 AM   #15 (permalink)
Dejon
Folks:
I went with a DEJON backbone.
JAPX
japx is offline   Reply With Quote
