Old 02-12-2008, 01:03 AM
Any pics of the new brakes?
2007 Aggressive GXP "Natsumi"
GMPP Intake
Lithium Lotus is offline
Old 02-12-2008, 12:31 PM
New pics yes!
Kuprito is offline
Old 02-12-2008, 01:40 PM
compression's Avatar
Compression's Last Look...
here is a link to a few pics. Sorry I thought I posted it up a while back.
Performance Auto and Sound
Compression Performance
compression is offline
Old 02-16-2008, 04:38 PM
madmods's Avatar
Andrew,
Glad you like them. I need them!!
Team Solstice 2009
How I built my solstice:
2008 show sponsors: Team Solstice 2008, Tillett, Wind Restrictor, Werks, Aspis, Norm's Fiberglass, DDM, AfterShock, Universal Studios, Cardomain, Easystreet AirLift, Alpine, Parkerracing, Madmods-Motorsports, Scap. To be a sponsor, just pm me.
madmods is offline
Old 04-02-2008, 02:00 PM
Spiro_GT's Avatar
@compression
APR studs (where did you get them from ?? website ??)
New lug nuts (where did you get them from ?? website ??)
for the front wheels to fit the APR studs, which were 7/16 thread pattarn.
9mm wheel spacers (where did you get them from ?? website ??)
Kuprito tried to fit the Rotoras for the Opel GT with stock rims and they did not fit either.He also needed spacers....
Wheel spacers
Too bad for a $1800 kit....
Spiro_GT is offline
Old 04-03-2008, 04:21 AM
Compression, help us!
Kuprito is offline
Old 04-06-2008, 02:53 PM
The company for the wheels spacers is Skulte Performance Designs - Skulte Performance Designs
The company for the apr studs is JRP - Canada & USA Supplier of Aftermarket Performance Parts
as for the 7/16nuts. I went to my local auto parts place. I think in the USA you guys have pep boys, and Auto Zone ? As for th Opel GT. I couldnt tell you what auto stores you have over there. sorry.
Also if you look on the Skulte Performance Designs - Skulte Performance Designs website they have nuts and bolts. So I'm sure they could make you a 7/16's nut to fit onto the apr stud.
Hope this helps. Sorry I didnt check this post for a long time.
Old 04-18-2008, 12:02 PM
DrJones's Avatar
Originally Posted by kwtoxman View Post
I don't think it is simple as the last few posts.
If the base brakes can hold the tires at the limit of braking through the entire braking distance then larger rotors and brakes won't help. I doubt GM built the solstice brakes in a manner where it couldn't brake the car at the limit of braking in a typical cold (street) scenario. Imagine the liability issue alone. And the fact that it isn't hard to engage the antilock on the car (ie the limit of braking performance where tires are the the limit in braking performance). In a street drive (cold) I doubt braking distance would significantly improve.
The real advantage with larger brakes and rotors comes in when hot, which is typical track/racing use.
As mentioned reciprocating mass matters. Larger brakes increase reciprocating mass hindering braking ability in some regards.
All IMO
kw.....
Not sure if anybody still had questions about how brakes work (I’m not picking on kwtoxman, he was just the last one to post on the topic )
The only thing that truly "stops" your car is the tires. The contact patch of the tire is where the opposing forces act to slow your car down.
So the only way to improve your stopping distance, if current brake system can lock the wheels up, is getting stickier tires.
You calipers are not stopping the car. They are converting kinetic energy into heat energy (energy cannot be made or destroyed, only converted). And the larger BBK kits usually can manage/dissipate heat better. So they can perform threshold braking for longer periods of time (i.e. road racing).
The BBK kits that increase the effective radius of the rotor [ (outer contact radius - inner contact radius)/2 ] will not make your car stop any faster. BUT, they will decrease the pedal effort needed by the driver to stop. This is why people think they are stopping faster, because they didn't have to push the pedal as hard.
This is part of the brake system "gain". other items that effect the gain is the size of the vacuum brake booster, the lever ratio on the brake pedal, the size of the master cylinder piston compared to the caliper piston size, the overall size of the tire (shorter tire = easier to stop)
Now if your car has a really crappy brake system and you cannot lock up the wheels (with ABS disable) then a BBK will help you stop faster because you were never able to get to the peak tire braking force. This should be over 1 g of deceleration achieved between 10% and 30% slip depending on the tire (100% slip is a locked wheel).
Alex
2007 - GXP - White
A Street Prepared - Crazy Monkey Racing
DEJON Powerhouse - Wester's Garage
DrJones is offline
Old 04-18-2008, 06:19 PM
Excelsior's Avatar
I agree. The brakes on the stock Solstice or more than efficient for hard driving without problems or heating up too much. Just watch an autocross event to see what I mean.
When I had my 74 Opel Manta with original brakes, they were way to small for the weight of the car and needed serious upgrading. I added BMW calipers with 2 cylinders instead of the 1 cylinder stock, a much larger set of rotors and it took me a few hours to do. When I tested it the first few times, I DID almost hit my head on the windshield and I could swear that I lifted the rear wheels off the ground once.
Small cars and old cars NEED good brakes and a LOUD HORN!
Previous #14 Owner / Current 08 GXP
Deep | LOADED | #14 Photo Album
My mods - updated 6/17/08
CNY Kappa Club Event Calendar
8/24/08 Meet/Drive
Excelsior is offline
Old 04-18-2008, 06:50 PM
kwtoxman's Avatar
Dr Jones, quit picking on me. What I'd say is that you put forth my argument in a more comprehensive manner. Kudo's.
kw.......
KW V3 coilovers :o
kwtoxman is online now
