Those of you who are SCCA Club Racers, LBJay had posted the link for the PDF that classifies the Solstice in SSB.
I got my print mag, and was reading and saw the weight at 2850 lbs. That is pretty impressive, usually, the SS weight of a car is quite a bit heavier than the stock weight.
I also noticed that the MX-5 weight was revised upward from 2630 (I think) to 2750 lbs
I assume that this will require ballast for the MX-5, thought those of you following the MX-5 closer would know more. It puts the lbs/hp at the same level for both the Solstice and the MX-5.
Should be an interesting year.
