I have been asked by several people to clarify which parts make up which of the suspension levels. Here is a compilation of this information, with spring rates and loads.
I hope people understand what a check height and check load mean for a spring. The check height is not the same spring length as any particular loading.
Some definitions:
LE5 = Base naturally aspirated 2.4l engine
LNF = 2.0l turbo SIDI
SDT = Street Edition
FE2 = the option code for the base suspension
FE3 = option code for uplevel suspension
You will notice that the SKY LE5 front spring has a higher load. In general, the SKY is slightly heavier due to option content, differences in structural mass, etc. and requires a slightly higher load spring to keep the trim height in specification.
Code:
Application Front Spring Rear Spring
Frt Shock (chk ht. = Rear Shock (Chk ht. =
211.5mm) 217.5 mm)
FE2 LE5 Solstice 15278695* 15244327 15278696* 15280026
2006 MY Code 9??* (3600N - 22.5 N/mm) Code 9??* (3700N - 31.0 N/mm)
[Tag = Lt Grn] [Tag = Tan]
FE2 LE5 Solstice 15224875 15244327 15236924 15280026
2007+MY Code C404 (3600N - 22.5 N/mm) Code C406 (3700N - 31.0 N/mm)
FE2 LE5 SKY 15224875 10376421 15236924 15280026
Code C404 (3800N - 22.5 N/mm) Code C406 (3700N - 31.0 N/mm)
[Tag = Dk Grn] [Tag = Tan]
FE3 LNF (Non Z0K) 15901220 15784872 15901221 25787858
(All Non-Z0K LNF Kappa) Code C646 (3800N - 30.5 N/mm) Code C648 (3900N - 40.0 N/mm)
[Tag = Brown] [Tag = Purp Stripes]
LE5 Z0K Solstice 15901220 15906534 15901221 15906532
also Street Ed. SDT Code C646 (3100N - 30.5 N/mm) Code C648 (3250N - 40.0 N/mm)
[Tag = Lt Grn Stripes] [Tag = Lt Blu Stripe]
LNF Z0K Solstice 15901220 25849163 15901221 25855626
Code C646 (3100N - 37.0 N/mm) Code C648 (3200N - 50.0 N/mm)
[Tag = Orange Stripes] [Tag = Yellow Stripe]
GM SPO Perf Parts 88965295 88965293 88965296 88965294
Code C388 (3450N - 37.0 N/mm) Code C390 (3350N - 50.0 N/mm)
[Tag = White] [Tag = Lavender]
* The 2006 Solstice had a different shock valving and shorter jounce bumper with a different rate progression.
The 2007 FE2 SKY, introduced early 2006, had a revised jounce bumper and a better shock valving to work with the new jounce bumper.
This was well-received, so the changes were rolled into the FE2 Solstice in 2007 model year and parts commonized.
The 2006 shocks are not available in service, both old and new jounce bumper are available in service.
2006 Solstice are all FE2 and all have the 15159045 jounce bumper. All 2007+ kappa have the 15823830 Jounce bumper.
Front (2) Frt Rear (2) Rear
Stab Bar Insulator Stab Bar Insulator
FE2 LE5 10342785 15887219 10342786 10350105
27.2 x 4.5mm 27.2mm 24.2 x 3.0mm 24.2mm
FE3 LNF Non-Z0K 15224873 25789241 15224878 15224881
& LE5 Z0K 33.3 x 4.5mm 33.3mm 25.4 x 3.0mm 25.4mm
& SDT (street edition)
GM SPO Perf Parts
FE3 LNF Z0K 25855621 25789241 25855622 25855623
33.3 x 6mm 33.3mm 27.2 x 6mm 27.2mm
Also needs
25855624 clamps
I also added it as a txt file.
The shocks have a sticker on them with a code. Springs usually have a tag that is a specific color and has the part number of the spring on it.
Also, keep in mind that the Z0K (both LE5 and LNF versions) are built with two spring seats. Out of the factory, the trim height is within specification with both spring seats, which was necessary due to several areas in the assembly plant that prevented a lower car from getting through the system, as well as shipping limitations at the intended ride height. It is up to the owner to remove this 2nd spring seat/spacer to set the car to intended carrying height. This option was lower cost when compared to other options, such as lifts and/or disposable spring stuffers.
You will also notice that the same shock is used for the LNF Z0K as is used for the lower spring rate cars. This shock is not fully optimized for these higher spring rates, and the GMPP shocks will be closer but oriented toward heavier rebound damping than is necessary for the increased spring rate, and significantly tighter bypass (bleed), which is typically more desirable for autocrossing vs. street usage or road racing. It is assumed that anyone buying an LNF Z0K for T2 or serious AS autocross would be replacing stock shocks, no matter how they are tuned, with their own choice in Penskes, Olins, Konis or other racing or adjustable shocks.
__________________ I am a GM Engineer.
Quick question: On the spring specs, I kind of figure the N/mm is Newtons per millimeter, since I'm used to seeing spring rates in pounds per inch, plus converting Newtons per millimeter to pounds per inch works out to 211 pounds per inch in the case of the LNF Z0K front spring. But what is the first number? For example, for the LNF Z0K solstice, the front spring is listed at (3100N - 37.0 N/mm). The GMPP front spring is listed at (3450N - 37 N/mm).
I'm guessing that the 3450N is the force needed to compress the GMPP spring to the check height of 211.5 mm? And that since the load for the GMPP springs at check height is in the middle of the FE3 and Z0K spring loads, the car will sit somewhat lower than stock but higher than the Z0K?
3800 - 3450 = 350N
350 N/37N/mm = 9.46mm = .37 inches, or about 3/8ths of an inch lower than stock, right?
Stonebreaker
1996 Impala SS 11.99 @ 115 mph
PhD in RE (Redneck Engineering)
It works in practice, but does it work in theory?
I'm guessing that the 3450N is the force needed to compress the spring to the check height of 211.5 mm?
that is correct, the check load is the load to compress the spring to the check height. There are different check heights for front and rear.
They are the attribute of the springs that ensures they yield the proper trim height when installed in the vehicle. More accurate than "free length" because of changes and non-linearity of the springs at the ends of the coils.
Thanks, I think you pretty much solved my speed bump problem.
Stonebreaker
It appears that one of my GMPP rear shocks is leaking (after only 4 months of use ). In as much as I bought these off of eBay, I'm without a warranty. Can I replace the shock with the FE3/Z0K shock (using the GMPP spring)?
Thanks.
--Chemist
Thanks.
--Chemist
You want to replace a
P/N 88965296 code C390 shock
with your
stock P/N 15901221 Code C648 shock, right?
You can do it, sure. Physically they are the same travel, but you will have two different performing shocks on either side. Some potential ride irregularities may show up, but then again you have been running with a reduced performance part since it started leaking anyway. That is a bummer, the leaky shock deal.
A new part is about $170 or so if you get close to dealer cost. If it were me, I would probably do it, and see if it makes much of a difference in handling or ride symmetry.
If so, I would even consider changing them both back as a pair. My guess is you would probably have an increase in transient understeer (corner entry), and a small bit of pitch in large ride swells because of the lower amount of rebound damping with the increased spring rate of the GMPP spring, but it is not a combo I have ever tried myself.
Thanks. I had planned on replacing both for reason you listed, to have the same performance on both corners. I'm going to see what price I can get for the 88965296 shock locally. I've got a line on the 15901221 shocks rather inexpensively ($70 each) and will go that way if the others are way too much $$
I do appreciate the rapid post.
--Chemist
I have a question in reguards to the "two spring seats". If i understand this correctly can we can lower the car to the second seat? and if so is there a thread to help?
Second, i have a question about suspension, what can i do to stiffen up... i am doing the turbo tune and have heard about this backbone? to reduce wheel hop? is any of this nessary? or is the GXP stock suspension good enough?
Thanx in advance!!! [quote=
You will also notice that the same shock is used for the LNF Z0K as is used for the lower spring rate cars. This shock is not fully optimized for these higher spring rates, and the GMPP shocks will be closer but oriented toward heavier rebound damping than is necessary for the increased spring rate, and significantly tighter bypass (bleed), which is typically more desirable for autocrossing vs. street usage or road racing. It is assumed that anyone buying an LNF Z0K for T2 or serious AS autocross would be replacing stock shocks, no matter how they are tuned, with their own choice in Penskes, Olins, Konis or other racing or adjustable shocks.[/QUOTE]
MI NEGRO DE BELLEZA
Black on Black Leather
'09 GXP Coupe
VIN #0539
Dealer stock Beaver Dam, WI 3July09
Soft top
GM Turbo tune
Magnaflow catback
GM Chickletless
Shorty Antenna
5% tint
