Whiskey Tango Foxtrot - collapsed caliper - Pontiac Solstice Forum
 1Likes
  • 1 Post By raygun
post #1 of 6 (permalink) Old 02-14-2017, 12:33 AM Thread Starter
Unhappy Whiskey Tango Foxtrot - collapsed caliper
And, the #1 thing I did not expect to see after completing a 100 mile drive home this morning:
Somehow, the hub or caliper has moved, and the caliper and rotor were having a spark-generating party. I didn't hear anything weird until about a block away from home. It would explain why someone was driving in my blindspot for 5 minutes, probably live-streaming sparks on YouTube.
Anyone have a spare Wilwood 4-pot FSL sitting around?
Blue-ish 2006 2.4, Werks stage 1 turbo, GMPP cat-back, TCE Wilwood 6 piston front brakes, 4-piston rears , Stainless brake lines, slotted and drilled rotors, DDM braces, BR Racing coilovers, Spec aluminum flywheel, Spec stage 2 clutch, Werks aluminum radiator, DDM oil catch can, Autometer boost, water and AFR gauges, RKSport hood, Morimoto FX-R HID headlights, GReddy Profec boost controller @ 13PSI, custom A-pillar gauge pod.
In progress: custom fiberglass trunk lid.
Currently on engine #4!
post #2 of 6 (permalink) Old 02-14-2017, 07:07 AM
Sly Bob's Avatar
What let go???
Born April 30, 2008
Delivered on May 27, 2008
Sly Bob is offline
post #3 of 6 (permalink) Old 02-14-2017, 07:43 AM Thread Starter
Originally Posted by Sly Bob View Post
What let go???
I'm not sure, haven't had the time to take it apart yet.
There are only a few possibilities, though.
1. Either the rotor has moved - and thus the hub and wheel bearing - which is NOT good, or
2. The caliper has moved, which would require loose caliper-to-bracket or bracket-to-knuckle bolts.
The position of the pad in that picture looks weird to me, but I couldn't really get a good look at it. The pedal does not feel good and the ABS light came on, so *something* else is going on.
I'll find out more this weekend. I'm just glad I made it home without losing the wheel or the brakes. I should probably reconsider that whole "I don't need a parking brake" position.
Steelmesh likes this.
post #4 of 6 (permalink) Old 02-16-2017, 02:10 PM Thread Starter
I finally found time over lunch to jack the car up.
Fun:
One of the three hub bolts was completely gone, the other two were loose.
I had the hub off when I put the ARP studs in several months ago. I know I torqued those down with the torque wrench. At least, I thought so.
I can just see all three bolts coming out and the wheel rolling past me on the road. Now, torqued with lock-tite. I'll recheck them after driving around for a bit.
post #5 of 6 (permalink) Old 02-16-2017, 04:34 PM
Hub bolts have been know to loosen. Mainly, I think, on cars that are autocrossed.
I assume you re-checked the others also?
post #6 of 6 (permalink) Old 02-16-2017, 04:37 PM Thread Starter
Well... I've been doing a lot of that. :/
I haven't checked the other wheels - very busy day. (But I haven't been driving it - benefit of working from home.)
I also had the RH rear hub off to install the ARP studs. (I had to put spacers on to clear the rear brakes, so I went ahead and installed longer studs.) If I messed up one side, odds are the other isn't perfect.
On the plus side, that wonderful creaking sound I've been hearing when backing out of the driveway went away.
I am smrt. S-M-R-T.
