Old 08-01-2008, 05:16 PM   #1 (permalink)
Yamatr3's Avatar
ZOK Rear Diff Brace
I thought I'd post a few up close pics of the brace. For those that are interested, the part number is, 25877302 and it was $322. The reason I decided to go this route instead of the DDM brace is two fold. First, this brace (supposedly) has harder rubber in it where the diff bolts too and secondly because my custom exhaust interferes with the DDM brace. Most exhaust systems don't interfere, but mine is a little different.
Old 08-01-2008, 05:59 PM   #2 (permalink)
AlohaSolstice's Avatar
Nice. Are you doing the install yourself? If not, how much would you expect to pay?
AlohaSolstice is offline   Reply With Quote
Old 08-01-2008, 09:30 PM   #3 (permalink)
salty's Avatar
Yamatd3,
What's involved with installing this piece? Any clues?
[quote=yamatd3;730514]I thought I'd post a few up close pics of the brace. For those that are interested, the part number is, 25877302 and it was $322. The reason I decided to go this route instead of the DDM brace is two fold. First, this brace (supposedly) has harder rubber in it where the diff bolts too and secondly because my custom exhaust interferes with the DDM brace. Most exhaust systems don't interfere, but mine is a little different.
Werks Turbo Stage II - 400 Hp / Exedy Clutch / Werks A-pilar pod / Magnaflow 2.5" Dual exhaust / Werks Radiator / Werks Free Flow Cat / H2O-Meth Injection (REPLACED WITH A PONTIAC G8 GT)
salty is offline   Reply With Quote
Old 08-02-2008, 07:36 AM   #4 (permalink)
Yamatr3's Avatar
Here is a Sky thread where they talk about it in more detail. Install is pretty straight forward. I'm not going to do the install on mine as I am having the A arm bushings replaced in my car too, so i am going to have them do the brace at the same time.
Rear Suspension Brace Upgrade - Saturn Sky Forum
Old 08-02-2008, 01:11 PM   #5 (permalink)
Rickady88GT's Avatar
Is that foam inside the brace?
I will own a V6 Kappa even if GM does not offer one as an engine upgrade. I have made my mind up, I want the Cadillac CTS 3.6L V6 with a 6 Speed manual tranny. And I will do the conversion my self if I have too :)
Rickady88GT is offline   Reply With Quote
Old 08-02-2008, 01:59 PM   #6 (permalink)
The normal piece is foam-filled, too.
alphajesse is offline   Reply With Quote
Old 08-03-2008, 07:39 PM   #7 (permalink)
Exactly how wide is that brace?
Old 08-03-2008, 08:38 PM   #8 (permalink)
Yamatr3's Avatar
It is the same width as the stocker, it just has that U shaped plate welded to the top of it. It also (supposedly) has harder rubber diff bushings in it.
Old 08-03-2008, 10:56 PM   #9 (permalink)
Is there a parts list of what makes up the ZOK package?
tdrc is offline   Reply With Quote
Old 08-03-2008, 11:08 PM   #10 (permalink)
Yamatr3's Avatar
Part No...........Name................................. ....................Qty..........MSRP
25849163........Front Spring............................................ ..2............96.14
25855621........Front Stabilizer Shaft..................................1.......... 315.00
25855626........Rear Spring............................................ ...2............71.32
25855622........Rear Stabilizer Shaft...................................1
25855623........Rear Stabilizer Shaft Insulator.....................2..............5.40
25855624........Rear Stabilizer Insulator Clamp....................2
25877302........Rear Suspension Support Crossmember........1...........420.00
Old 08-04-2008, 12:45 AM   #11 (permalink)
I have an 08 GXP with the A31 PWFE3 Sport Tuned Suspension is there any real difference?
Old 08-04-2008, 01:45 AM   #12 (permalink)
davytudope's Avatar
just every part on the list above
2007 black solstice gxp:gmpp turbo upgrade, PAW tune, gmpp cai, magnaflow exhaust, 18x9 silver oz ultraleggeras, 275/35/18 kumho xs, gmpp recommended brake pads, kw v3's w/6k springs, energy suspension bushings, z0k rear brace, hp tuners
TEAM FAIL RACING
davytudope is offline   Reply With Quote
Old 08-04-2008, 02:40 AM   #13 (permalink)
bigblau's Avatar
I have a 2006 Z0K and have also bolted on the DDM brace. I should be ready now for the new DDM StageIII S/C -hoping its Eatons TVS series. Otherwise I can wait some more.
bigblau is offline   Reply With Quote
Old 08-04-2008, 07:44 AM   #14 (permalink)
Yamatr3's Avatar
Did the 2006's even have this same brace? I think they found out about the flexing afterwards. I don't think you have the u channel like on the one I pictured. I believe they came out in 07, but I could be wrong. So, if you have the DDM one, you are accomplishing the same thing.
Old 08-04-2008, 09:30 AM   #15 (permalink)
$300+ for that peice of metal, wow.
2007 Aggressive GXP "Natsumi"
GMPP Tune, GMPP Intake, Solo Mach Shorty, Solo High-flow cat, SSR Type-C RS Wheels, DDM Backbone.
Lithium Lotus is offline   Reply With Quote
