Old 06-28-2008, 10:24 AM
   '08 Brakes - Non Recall Notice
Don't know if anyone else has received a letter from GM yet, but I got one today regarding the problem of no brakes when first starting our GXP's. It's not a recall, but an offer to "calibarate" the brakes with something "improved." It's an option that you have to call your dealer and ask for - referring to TSB0-7-05-25-007B. Can someone pull up the TSB and see what it actually says? On the same note, I wonder what ...007A says.
wanderso is online now
Old 06-28-2008, 10:41 AM
GXPsy Rose's Avatar
You can search the forum for it as it is on here. Believe "Small Dealer" posted it.
GXPsy Rose
2008 BRAZEN GXP
Ordered: June 1st 2007 & Delivered: July 20th, 2007
Premium Package w/ Ebony & Red stitching
18"Chrome Wheels, Rear Spoiler & Sports Pedals
AT& AC, OnStar, XM radio, 6 disc CD w/Monsoon,
Dual MagnaFlow Exhaust, Opel GT Antenna, Splash guards,
Custom Etched Lighted WR and Miscellaneous "Stuff"
I LOVE MY CAR
Founding Member #52
GM Roadster member
"Life's too short not to drive a fun car"
GXPsy Rose is offline
Old 06-28-2008, 11:38 AM
Small Dealer's Avatar
Was another site member, krisis7, that posted it (and you borrowed for another thread) shortly after it came out back in May.
Released 5-1-08- Brake update on Redlines/GXP
The original version had the calibration release only for Automatics, the "A" version changed some wording and the "B" version added the manual transmission calibration release.
Here is a cleaner copy of the TSB and a PDF of the June 26th target mail date letter (generic sample):
#07-05-25-007B: Pedal Noise/Buzz, Extra Effort Needed to Depress Brake Pedal After Vehicle Has Not Been Driven For Extended Period of Time (Reprogram ECM and ECM) - (May 16, 2008)
Models: 2008 Pontiac Solstice GXP
2008 Saturn SKY Redline
2008 Daewoo G2X
Built Prior to the Breakpoints Listed Below
This bulletin is being revised to announce that the calibrations are available for vehicles equipped with manual transmissions. Please discard Corporate Bulletin Number 07-05-25-007A (Section 05 -- Brakes).
Model-VIN Breakpoint
Saturn-8Y129355
Pontiac-8Y129363
Daewoo-All Vehicles
Please make a copy of this bulletin and give it to your customer for future reference.
System Description
The 2008 Pontiac Solstice GXP, Saturn SKY Redline, and Daewoo G2X are performance vehicles that come equipped with the 2.0L (RPO LNF) engine and an advanced performance braking system called Optimized Hydraulic Boost (OHB). The OHB brake system utilizes the Anti-Lock Brake System (ABS) to assist vehicle braking in low brake vacuum conditions.
The brake systems on these vehicles use engine vacuum to assist the power brake system during most brake applications. The OHB system supplements the power assist brake system when there is low engine vacuum, such as when the engine is initially started after an extended period of no operation or while operating in high altitude.
Condition
Some customers may comment on one or more of the following brake system characteristics:
• Increased brake pedal effort due to low brake booster vacuum conditions that may occur after the vehicle has not been operated for an extended period of time and/or at higher altitudes and restarted.
• Brake pedal movement or pulsation accompanied by a ratchet sound coming from the brake system during OHB activation when braking.
Correction
Reprogram the ECM with an updated engine calibration. This new service calibration will increase engine vacuum when the vehicle is initially started.
Reprogram the EBCM with an updated brake calibration. This programming event will return the module to its original state if it was previously updated for this condition.
These calibrations will be available as an EBCM/ECM programming sequence event. From the controller list, select "EBCM/ECM Sequential Program."
Important:
• After the EBCM/ECM calibration, brake pedal movement or pulsation accompanied by a ratchet sound will be reduced.
• Allowing the engine to idle for a period of time after the engine is started will help increase the vacuum for the power assist brake system.
• If the SVC BRAKE SYSTEM message is displayed on the DIC. The brake system must be inspected for any faults in the system.
Refer to the Owner Manual (page 4-4 for the Pontiac Solstice or Saturn SKY) for additional information on this brake system operation.
The recalibration is covered under the New Vehicle Limited Warranty for 36 months or 36,000 miles, which ever comes first.
The NHTSA has closed their Preliminary Investigation into the 2008 Solstice GXP and 2008 Saturn Sky Redline and the OHB System. So it appears no further investigation or no escalation to a recall request will be forthcoming.
Originally Posted by NHTSA
A SAFETY-RELATED DEFECT HAS NOT BEEN IDENTIFIED AT THIS TIME AND FURTHER USE OF AGENCY RESOURCES DOES NOT APPEAR TO BE WARRANTED. ACCORDINGLY, THIS INVESTIGATION IS CLOSED.
INFORMATION POSTED ON SITE
Small Dealer is offline
Old 06-29-2008, 08:00 PM
Hossman's Avatar
So has anyone had this done?
Would you recommend this - I drive my car almost daily, never had this issue. I really don't like the idea of an increased idle to fix a vaccume issue, sounds like one evil for another?
What is the felling aout getting this done on my car? would you do it to yours?
Thanks
2008 GXP-Mysterious
5- speed, On-Star, XM Radio, Premium Package, Leather Seats, Monsoon 7 Speaker High Performance Stereo with 6 Disk CD Changer, 18" Chrome Wheels, Rear Spoiler and Sport Metallic Pedals.
Hossman is offline
Old 06-30-2008, 04:58 PM
Got mine today, only problem I have had is when I back out of the driveway, will get mine fixed when I get back from Myrtle beach.
08 DEEP GXP
tazz is offline
Old 07-01-2008, 05:12 PM
I just had my brakes looked at as well when I was having another minor thing replaced. They are not working well in reverse. They did the recalibration and I truly do not feel hardly any difference. The brakes in reverse still randomly choose when and when not to work. It makes me VERY nervous to back up, esp. if on an incline.
HangingGardens is offline
Old 07-02-2008, 02:03 PM
Old 07-03-2008, 02:48 PM
SunSports's Avatar
I have a steep driveway and backing out is interesting when the engine is cold. (Really bad design.)
I went to the local dealer today for the update. They read the update from GM and had no idea what to do. Waste of time! I think that I will just keep living with it.
08 GXP Orange Auto Loaded
07 GXP Yellow Auto Loaded
07 GXP Yellow Man Loaded
06 Red Auto Loaded
06 Red Man Loaded
06 Grey Man Loaded
06 Red Man
Vista House Meet 1/15/06
Mt St. Helens Meet 3/25/06
WV Wine Tour 5/13/06
S Solstice CRG PreRun 5/28/06
S Solstice CRG Meet 6/24/06 6/25/06
Solli4Meet Mt. Hood 7/29/06
OR/WA FC Run 10/28/06
South Mt Run Phoenix, AZ. 1/14/07
Orygun Run 4/28/07
2nd S Solstice CRG Meet 6/23/07
TVR 9/22/07
LCD 10/27/07
3rd S Solstice CRG Meet 6/21-22/08
SunSports is offline
Old 07-04-2008, 10:16 AM
Hossman's Avatar
Thanks all - I will contact the dealer.
2008 GXP-Mysterious
Hossman is offline
Old 07-04-2008, 11:42 AM
Jeff Donald's Avatar
I would find a new dealer. The procedure is straight forward and GM offers phone support to the techs as well.
Jeff Donald is offline
Old 07-08-2008, 08:56 PM
I had mine done Saturday; it's a small country dealership and they knew exactly what to do when I showed them the letter. I have not noticed any change in behavior on my GXP.
Old 07-16-2008, 08:58 AM
Hossman's Avatar
My car is going in on Saturday - I was away in Baltimore for the last week - Had to get away from all the smoke here in California.
2008 GXP-Mysterious
Hossman is offline
Old 08-03-2008, 06:50 PM
Hossman's Avatar
I got the service bullitin taken care of on 8/1/09 - The delearship needed the car on a week day so they had the phone support. All is well - I fell no change in the Solstice. Mileage does not seem to be any different in the last couple of days.
CHEERS & THANKS ALL FOR THE ADVICE
2008 GXP-Mysterious
Hossman is offline
« Koni | Scanner »
