I have a Very steep drive as well, if on a cold start you pull out forward or reverse, you have brakes but there is not enough vacum. GM adds a bit of cold idle rpm, but if you jump in the car start it and just drop it into a gear and go then need brakes it still is not FULL of vacum.
Mine after the update only
idles faster at start, if you put it in gear before idle down it drops idle when you shift this might be to save the drive train, you would get a clunk.
I let it idle a bit maybe 10+ sec.(let the oil get around) Rever up to 2k this grabs air intake and letting off the gas makes the needed vacum. This also kicks off the high rich starting setting they seem to use. Almost feels old school, you know the days when warming up a car was minutes, No vacum system in a HPcamed cars, manual brakes, or Soggy power brakes at best even if it ran for a week
my 2cents and the only real way to do this right is a vacum pump and tank that turns on at start or even a bit before if the pump takes longer than a few seconds as some in a HURRY
