After Market B.O,V. - Pontiac Solstice Forum
Old 02-20-2013, 11:55 AM   #1 (permalink)
After Market B.O,V.
Which of these would you advise I put on?
Synapse (w/ hks adaptor | eBay
Gatorgetter is offline   Reply With Quote
Old 02-20-2013, 12:02 PM   #2 (permalink)
I forgot to mention I have a 2009 GXP w/5spd and Trifecta tun.
Old 02-20-2013, 12:23 PM   #3 (permalink)
Carpe Diem's Avatar
What other mods have you made to your engine? Why do you want to install an aftermarket BOV?
Carpe Diem
'Mysti' - '08 Mysterious 5-spd GXP, Custom HP tune, Hahn I/C, K&N filter, DDM ProBeam & Backbone, splash guards, Z0K Sway bars, poly bushings & BC Coilovers, Magnaflow catback, Solo hi-flo cat..
Old 02-20-2013, 02:25 PM   #4 (permalink)
Aftermarket B.O.V.
Can ya also help me out on this?
shadowsonic is offline   Reply With Quote
Old 02-20-2013, 03:00 PM   #5 (permalink)
It's stock other than the Tune.
I like the sound.
Old 02-20-2013, 03:41 PM   #6 (permalink)
Dave@ddmworks's Avatar
We use the synapse on most all of the 2871 turbo installs for several reasons. We are very happy with the response of it, the synapse will dump pressure quicker then the stock bypass valve, the synapse does not leak even at very high pressures and I also like the look of it (personal taste thing).
You can use one on the Solstice/Sky and they are sold with an aluminum weld on flange that can be easily welded to either of the charge tubes, but we typically install it on the drivers side tube if we can.
Hope that helps,
Dave
Dave Michel
DDMWorks
Sales - 864-438-4949
Tech Support - 864-907-6004
WWW.DDMworks.com
Dave@DDMWorks.com
Dave@ddmworks is offline   Reply With Quote
Old 02-20-2013, 05:01 PM   #7 (permalink)
Guys i have Solo center exhaust, highflow cat and trifecta tune with all ic pipes, synapse bov just won't work too quiet I'm looking for something to vent to atmosphere and give me a loud whoooshhh sound
Ideas on ones that do work and what i'd need to get it accomplished without fearing the codes.
Old 02-20-2013, 05:12 PM   #8 (permalink)
LiquidPT's Avatar
I seem to recall an issue with an atmosphere vent and the MAF readings...
LiquidPT aka Matt
driving Black Sun
LiquidPT is offline   Reply With Quote
Old 02-20-2013, 06:29 PM   #9 (permalink)
Valhalla's Avatar
dejon intake and dejon BOV replacement spring. makes all kinds of noise.
2008 Agressive Red GXP- Auto trans
Magnaflow Exhaust, Dejon CAI, DDMworks IC tubes, Dejon BOV spring, Solo High flow Cat, Trifecta tuned, HAHN Racecraft intercooler, ASAP carbon fiber kit, fog light and backup light covers.
Album of my mod pics
Valhalla is offline   Reply With Quote
Old 02-21-2013, 09:36 AM   #10 (permalink)
Racer_X's Avatar
No issues and I vent to atmosphere... HKS SSQV III--- and yes I get the high pitched engine "Queef." It was exactly what I was looking for and I can't complain!
2008 Sly GXP (Z0K) Custom Tune, Dejon Precision 5557B Kit, Wiseco/ARP/K1 Built Bottom End, AEM Meth Injection, SPEC Stage III Clutch, DDMworks Backbone, Kappasphere ReBar, DDM Crossbrace, Custom Front Splitter, HKS SSQV, Norm's ZR-1 fenders, Cobalt SS BBK.
SOLD
Racer_X is offline   Reply With Quote
Old 02-21-2013, 04:43 PM   #11 (permalink)
Racer X - what did you do in order not to get any problems? Which way did you do the hoses? BOV on the right side or left? I can't find the model you have only HKS Super SQV4 also did you use Compressor Bypass Valve Clamp?
Old 02-21-2013, 06:06 PM   #12 (permalink)
Racer_X's Avatar
So your telling me you could not find an HKS SSQV III? Internet is a good place to start!
as for a diagram I'll post a pic, but it's kinda small- I'm sure you can blow it up tho.
you will need to install a compression spring from Dejon in your factory turbo so it wont leak at 21+psi. then you just take the boost line off of the factory internal BOV and connect it to your BOV. The line connects from the 3way fitting on the intake mani (the little black box thingy behind the red bar) to the nipple on the back of the BOV.
SOLD
Old 02-21-2013, 09:04 PM   #13 (permalink)
elff's Avatar
Selling?
Say it isnt so.
LUSIFER
I'm not short, I'm concentrated AWESOME
elff is offline   Reply With Quote
Old 02-22-2013, 01:05 PM   #14 (permalink)
If I'm replacing the stock BOV with another different BOV call me stupid but why change compression spring on the stock BOV if I'm removing it? As for searching online i have found some on ebay
Old 02-24-2013, 03:39 AM   #15 (permalink)
Racer_X's Avatar
Because the stock BOV could still let pressure out, because it was not designed to withstand greater than 18psi! The spring will tighten the stock BOV to ensure it will not leak.
SOLD
