Cluster removal - Pontiac Solstice Forum
post #1 of 6 (permalink) Old 07-13-2013, 11:23 AM Thread Starter
Cluster removal
Hey guys I'm a new '07 GXP owner and I have a question. Been perusing the forums and seems I read somewhere that the cluster can be removed w/o removing the boomerang. That it can be wiggled out through the tunnel cutout. Anyone have any idea as to the validity of this? Also should battery be disconnected during this procedure? Thanks in advance for any input.
crguy is offline
post #2 of 6 (permalink) Old 07-13-2013, 12:47 PM
Having had my cluster in and out a number of times (and boomerang off even more times), this is just my opinion:
You could remove the faceplate 'glass' through the front and replace the gauge faces that way, but I'm thinking that removing the whole cluster with the boomerang in place would be pretty darn difficult. Apart from anything else, getting the screws out and back in would be, let's say "frustrating"! It's difficult enough, even with the boomerang off.
I think it's actually easier to remove the boomerang to remove the cluster, than try to do it the 'easy' way.
post #3 of 6 (permalink) Old 07-13-2013, 01:31 PM Thread Starter
Thanks TS. That's kind of what I thought you guys with the experience would say.
crguy is offline
post #4 of 6 (permalink) Old 07-13-2013, 01:56 PM
I have had mine out several times. It is possible to get it out without removing the boomerang. It is not easy though
Carol's husband for 48 years
rob the elder is online now
post #5 of 6 (permalink) Old 07-13-2013, 02:04 PM
KappaKadet's Avatar
Yes
Originally Posted by crguy View Post
Also, should battery be disconnected during this procedure?
Would probably be a good idea to disconnect before digging into the dashboard.
KappaKadet is offline
post #6 of 6 (permalink) Old 07-13-2013, 10:54 PM Thread Starter
Thanks rob and kappa.
crguy is offline
