Great video and link, HUH:
I would add one thing to my earlier post on the Sky side. Traction control is a throttle control, it takes fuel away from you if the car senses to much wheel spin. There are situations where that can work against you drastically.
For instance, stuck on ice in the middle of winter, in that situation you will have to shut off the nannies to get wheel spin going to help you out, if you are completely stuck.
But a more serious situation to be aware of is times when you may be expecting to be able to "steer with your rear wheels". Say you are waiting to make a left hand turn at an uncontrolled intersection, and there is a lot of traffic. You are thinking to yourself, I will just gun it and slip in between cars during a small break in traffic.
DON'T FORGET what happens if you have the car set in normal mode (which is the default setting when you start up). You go heavy throttle while making that turn, and you will find that throttle is taken away from you in a drastic way, and you are going
REAL slow.
