Old 04-21-2008, 07:13 PM
   Convertible top alignment
Just wondering if any of you had to have your convertible realigned? The 1st time I took it in because the passenger side window would roll up and the seal would be on the outside of the window and not in, and you would have to open the door to get the seal on the inside. Since then I've had the top down twice and when I put it back up today not only is the top out of alignment again, but it is worse than the 1st time.
Is there anything that I can do to try and align it or am I stuck taking it back to the dealer
Clipzedz24 is offline
Old 04-21-2008, 07:54 PM
MomsSol's Avatar
Location: October is Breast Cancer Awareness Month - remember, its not just women who suffer!
Take it back to your dealer and ask them replace the adjustment rod. I had the same problem on my car. The original rods had plastic pieces ... the newer ones are steel.
I've not had any problems since this rod has been replaced.
It's never too late to have a happy childhood. But the second one is up to you and no one else.
NASSOA(TM)
MomsSol is online now
Old 04-24-2008, 05:59 AM
Deepbluegxp's Avatar
Take some pics and post them, I may have a solution for you but I need more info. I'm not sure what you mean about out of allignment. Is it not seating into the slots by the doors, is the window still hitting the fabric?
Southern Maryland Mod Meet #4 October 11, 2008
Team Solstice 2008
Click My MODS link
See my car on cardomain.com
NASSOA Founding Member #48
Buffalo Bills 4 - 1, Lets Go Buffalo
Deepbluegxp is offline
Old 04-25-2008, 06:57 PM
I'll have to grab some pics tomorrow it's too dark outside now. Basically what happens is if I roll my passenger side window down at all and back up I the weather seal is on the outside of the glass completely instead of it being on the inside. It's to the point that I have to have the passenger door open before I roll the window up because it's very difficult to open the door.
Before I took it in it was doing the same thing, however it was not as bad.
Old 04-25-2008, 07:11 PM
ladyt28's Avatar
I'm having the same problem! I'll be keeping my eye on this thread.
Team Save the Ta-Tas 2008
Founding Member NASSOA
Michigan Kappa Club
Chicagoland Roadsters
2007 Aggressive GXP, Wester's Hot Tune, Chrome Wheels, Opal Shorty Antennae, MagnaFlow Cat Back exhaust; Dejon CAI/Intercooler & Aggresive Red Piping; Splash Guards, Beltronics Pro RX75 Plus radar/laser detector, Flash to Pass garage door opener.
Visit my page at cardomain.com http://www.cardomain.com/ride/3038609
ladyt28 is offline
Old 04-25-2008, 07:12 PM
MomsSol's Avatar
IF they made adjustment to this rod and it is STILL doing this this it needs to be replaced as I suggested earlier.
I'm certain that DBG will have you attempt to adjust this also, but IF the tabs are broken off it will back off again and you will still have problems .. this is how it was explained to me by my mechanic anyway. Factory rod has plastic tabs .... replacement is made with steel.
NASSOA(TM)
Old 04-25-2008, 08:34 PM
Yours sounds like the glass is tilted in to far, there are two adjustments for the window but I need some photos to tell you what the procedure is.
Team Solstice 2008
Click My MODS link
Old 04-25-2008, 08:38 PM
MomsSol's Avatar
Joe ... mine was doing this EXACT thing (drivers side) ... plus it was not seating into the gasket on the body behind the door as it should. That was the reason for the adjusting rod replacement - there is a TSB for this now. I've seen this on another car too!
NASSOA(TM)
Old 04-26-2008, 04:36 AM
I'll look up the TSB on service manual DVD
Team Solstice 2008
Click My MODS link
Old 04-28-2008, 07:28 PM
ladyt28's Avatar
My service dealer asked what number the TSB was
Michigan Kappa Club
ladyt28 is offline
Old 04-29-2008, 05:09 AM
I didn't find a tsb on that. There are 30 TSBs listed at Edmunds.com, non cover the top
Car maintenance, car safety reports at Edmunds
Team Solstice 2008
Click My MODS link
Old 04-29-2008, 06:07 AM
MomsSol's Avatar
Hmmm ... my mech said something about the bulletin on the top had changed ... my service writer showed me the paper with the NEW part they were to order and replace ... very curious, very curious indeed.
Let me go check mygmlink and find the part number
::edit:: didn't have the number listed, but here is the diagram showing the link assembly
#10 they used.
NASSOA(TM)
Old 07-20-2008, 06:19 PM
   same prob
souljaboy66's Avatar
Ya im having the same problem on the driver side i just purchase an 2008 base model, im not impressed, love the car but this isnt good. i wonder if its when we put the top down in the trunk that it somehow gets lose of the top. Also what is a TSB
souljaboy66 is offline
Old 07-20-2008, 07:06 PM
kwtoxman's Avatar
Most people with an alignment issue have just had to take care putting the top up. This method is much better than having a dealer fumble around.
Check and try this first.
Air Leak around driver's window
KW V3 co
