Old 04-21-2008, 07:22 AM   #16 (permalink)
LOST SOL
MSG_McKee's Avatar
Originally Posted by Go-N Def View Post
Whoops, missed that. I had a long day of driving yesterday, about 700-750 miles.....
Anyway, since you don't have an air box, try loosening the mount and then pushing the pipe inboard. Get someone or something to hold it in place and tighten everything back down. Should wrk....
I am going to try that today but it appears that it will not go too much further and keep the mount by the horn lined up.
Originally Posted by Topcat View Post
When you say Short? Do you mean that with the motor side connected and the brackets lined up the Pipe looks like it could be a little bit longer to fit completely in the intercooler coupling?
I noticed that my front bracket the one that mounts to the front of the car was too low, so mine isn't even connected to the car.
I used the mounting brackets, but that made the gap on the engine side appear to be bigger than it should have been ... for the supplied coupler. The Drivers side went on "like a glove" but the Passengers side seemed like either the coupler, or the pipes were as SB said a little short. I eventually made it work, but it was MUCH harder to do than the drivers side.
Current sMiles: 21,622
Click Here To See My Mod Page
Old 04-21-2008, 11:02 AM   #17 (permalink)
Holey crap people . . .
there is plenty of adjustment room built into the mounting parts for the pipes.
I had a problem where the stock through bolt hit the pipe when I torqued it down on the right side. I "adjusted" the tab on the Dejon pipe - bent it with my pliers - and then I put a slight Z bend in the stock mounting sheet metal bit. I torqued down the pipe to mounting arm, left the pipe to intercooler joint loose, then tightned down the vertical mounting stud / nut which drew the intercooler pipe down about the 1/4 inch it needed for clearance. then I tightned up the pipe to intercooler joint and all is fine.
I did a similar modification on the left side pipe to get everything clearanced and lined up the way I wanted it to fit. No problems.
Old 04-21-2008, 11:53 AM   #18 (permalink)
blacksky's Avatar
Originally Posted by Squirrel Boy View Post
I've had mine on the car for 2 months with no rub....
Ok , check this out ... my factory pipes were rubbing about in the same area.
My new Dejon pipes for some reason sit lower and further forward in the car ( actually had to make a longer connector hose to make it work ) I'll post a picture tomorrow after work.
..... just a thought .... anybody with an automatic (besides me) have these pipes on their car?
I have an automatic with Fujita pipes and had them on there for a year before I noticed the rub so for some reason it just recently started to rub.
blacksky is offline   Reply With Quote
Old 04-21-2008, 12:11 PM   #19 (permalink)
LOST SOL
MSG_McKee's Avatar
I am sure I can fix it, but I just wish I knew before the hood scaped the pipe. Seems like this is a common issue and should be looked into IMHO.
Old 04-21-2008, 01:29 PM   #20 (permalink)
IBDRINKEN's Avatar
my passenger ic pipes from fujita does it as well. they replaced the pipe and it still does it but its worse than whats pictured aboved.
13.5@101.90
2.5" Stubby Black Antenna
Lil' Chromies
Norms Fenders
Kappa Intake
Kappa IC Pipes
Pcm4less Tune
Infinity Kappa Speakers
DDM Probeam
DDM Race Backbone( Not Installed)
DDM Black Coilcover
JPM Center Console
JPM Shifter
Custom Kicker System By JPM
MBRP Heat Shield
Dejon Intercooler
IBDRINKEN is online now   Reply With Quote
Old 04-21-2008, 02:51 PM   #21 (permalink)
Deepbluegxp's Avatar
Dejon has a fix for it on their web site, this is their picture.
It is caused by the clearance between the hood bracket, to fix that you have to knotch the airbox right below the pipe.
See my car on cardomain.com
NASSOA Founding Member #48
Old 04-21-2008, 04:24 PM   #22 (permalink)
LOST SOL
MSG_McKee's Avatar
I run the Fujita CAI and others with the same issue have a CAI too, so it might be another issue involved. I am an old Infantry Soldier, so I will adapt and overcome but just hated seeing the scratch.
Old 04-21-2008, 05:26 PM   #23 (permalink)
tony t's Avatar
Pipe rub.
After seeing this thread I went out and checked out mine. Sure enough there it was, the bracket that holds on the passenger side hood comes down and hits the intercooler pipe, enough that it is chipping the paint off of my almost chrome pipe.
I'm going to grind down the bracket just so it clears the intercooler pipe, that should keep it from hitting.
Who ever has the Dejon intercooloer pipes need to grind down the bracket or else it will chip the paint off. This is hitting with the air box removed and the Dejon CAI by itself.
2007 Mysterious GXP
Acoustic Headliner
A/C
Rear Spoiler
Metallic Pedals
5-Speed
Premium Package
Chrome Wheels
OnStar
Monsoon Audio System
6-Disc Player
XM Radio
MODS:
Billet Grille
3" Magnaflow Cat Back
Stubby Antenna
Little Chromies
PAL
Dejon CAI/Intercooler Pipes
Front/Rear mud Flaps
tony t is offline   Reply With Quote
Old 04-21-2008, 06:48 PM   #24 (permalink)
Squirrel Boy's Avatar
picture 1 how long of a coupler it took
picture 2 very close but does not touch
picture 3 stack of washers to make the bracket reach
picture 4 airbox mod for turbo side
picture 5 airbox mod for cold side
dejon-ic-pipe-rub-1.jpg  dejon-ic-pipe-rub-2.jpg  dejon-ic-pipe-rub-3.jpg  dejon-ic-pipe-rub-4a.jpg  dejon-ic-pipe-rub-4b.jpg
http://www.myspace.com/squirrel_boy1
Solstice + HHR = peanut butter + jelly
Squirrel Boy is offline   Reply With Quote
Old 04-21-2008, 06:50 PM   #25 (permalink)
the factory pipes were rubbing new ones dont....go figure
Old 04-21-2008, 07:19 PM   #26 (permalink)
Go-N Def's Avatar
Yeah, but in a different spot...
Pics on MySpace
Go-N Def is offline   Reply With Quote
Old 04-21-2008, 07:21 PM   #27 (permalink)
Go-N Def's Avatar
Thought I just heard a Call For Fire...
Pics on MySpace
Old 04-21-2008, 09:23 PM   #28 (permalink)
Shot, Over.
Old 04-22-2008, 12:01 AM   #29 (permalink)
Had the same problem on the Sky. Dave claimed he had never heard of this happening and was either something wrong with the car or an installation error on my part. I have a Dejon CAI, so no problems with the stock air box. I tried everything.. the washers, pushing the pipe as far down into the I/C coupler as possible, moving things left, right, up, down.. nothing worked. I was worried it would finally wear through the thin aluminum wall and create a bad leak. Dave reluctantly took them back. If you purchased them packaged with the I/C, make sure your refund isn’t minus the entire package discount.
boostednlinefor is offline   Reply With Quote
Old 04-22-2008, 06:45 AM   #30 (permalink)
If you are having this issue without the factory airbox, then you need to set the front intercooler pipe farther into the rubber coupler.
