GFORCE Chip - Pontiac Solstice Forum
post #1 of 8 (permalink) Old 12-15-2010, 11:32 AM Thread Starter
jonnymx25's Avatar
GFORCE Chip
I have been thinking about adding a GFORCE Performance Chip to my 09 Sopstice GXP Coupe and was wondering if anyone else has tried it yet? I like to do some research before any mods. Thanks.
jonnymx25 is offline
post #2 of 8 (permalink) Old 12-15-2010, 12:40 PM
Can you say, S-C-A-M? I approached them and asked for a before-and-after dyno print-out; never heard another word. Caveat Emptor.
Cheers
BarFury is offline
post #3 of 8 (permalink) Old 12-15-2010, 01:10 PM
There are plenty of tunes available that are proven from venders who have demonstrated both their technical acume and their customer service.
If you check out the threads related to the GMPP tune, you will find out a lot of real world experience and engineering data that was shared. The Kappa is a fly by wire car and there are a lot of well understood ways to add HP that allow you to go to just about any HP level you want in increments.
Basically, the best / most cost effective thing you can do for a 2.0 is install the GMPP tune which will give you a huge increase and maintain your warranty.
Both the NA and 2.0 will show significant gains from swapping to a high flow cat.
The exhaust and intake are not limiting until you get to high output numbers.
For the 2.0, the CAI does nothing but add noise. Same for the catback.
Charge tubes with a tune does improve flow and thus reduce the high RPM losses due to the factory charge tubes being limiting.
for the NA there are tunes, headers, . .. and best of all supercharget kits that will bolt on a ton of HP.
See werks, ddm, hahn, wade's garage etc for more info
Carol's husband for 48 years
post #4 of 8 (permalink) Old 12-15-2010, 02:01 PM Thread Starter
jonnymx25's Avatar
Thanks you both for the feedback. I am looking to increase HP but definately don't want to void my warranty. I don't want to spend thousands to do it so I was hoping there is a way to gain about 30+ HP for a few hundred.
post #5 of 8 (permalink) Old 12-15-2010, 02:23 PM
If you have a 2.0, the cheapest route is to get the GMPP tune kit installed. crate engine depot last time I checked had them for less than $500 and you can get it installed for a couple hours of labor. Takes the 2.0 from 260 HP to 290 HP and removes the learn down feature that eliminates any gains you might get from any other mods. Do a search on learn down.
Second best thing you can do is get a high flow cat that once the learn down code is removed (mostly) will give you on 16-18 HP gain.
Getting to 305-310 HP is pretty straightforward and will not impact your warranty. Putting in a chip is more likely to do so as its changing the baseline configuration of the computer / software subsystems.
post #6 of 8 (permalink) Old 12-15-2010, 03:51 PM Thread Starter
jonnymx25's Avatar
Cool thanks. I will keep recearching and check out the GMPP tune kit
post #7 of 8 (permalink) Old 12-16-2010, 02:03 AM
Based on MY research....chips are scams. You need a re-flash of the ECM. Older FI systems like Motronics can get a HP increase with a chip but not this system.
06 Solstice Convert 2.4 N/A
73 Porsche RS, cab, 3.6 EFI ratrod
Melon is offline
post #8 of 8 (permalink) Old 12-16-2010, 07:43 AM
spiky3480's Avatar
A chip is an absolute scam for our cars! I was a tester for the Westers tune, while it was being developed...trust me when I tell you that a chip from some no-name company is not going to do anything except risk hurting your car. Tuning is something that an experienced person must do or you risk serious damage to the car. Many vendors on here have a proven and tested tune that modifies many more parameters than one can even think.
Companies that I know have proven tuning are:
1. Westers Garage
  • Tune using the software on your laptop or mail in your ECM
  • Also has a transmission tune for the 2.0
  • Many years of tuning experience and lots of testing done
  • Free re-tunes after the addition of engine mods
  • Contact: Lyndon Wester
2. DDMWorks
  • Also have proven results and are very well-versed in knowing their way around our car
  • They do tuning at the mod meets, or you can mail in your ECM
  • Great bunch of guys to work with and they stand behind their work
  • Contact: Dave, Randy, or Ivy
3. Trifecta
  • Handheld tuner
  • I don't have too much experience with Trifecta, but from what I have head, they are great to work with
  • Contact: Vince
4. GMPP
  • Flash and install done by dealer
  • Nice HP gains, but not quite as aggressive as the other mentioned tunes
  • Some have had issues with the flash, and some with bad O-rings
  • Warrantied by GM (unless you install the sensors and wiring yourself)
SOLO Performance
goingsolo2@hotmail.com
516-655-9002
2007 Mysterious GXP
Exhaust Sound Clips
spiky3480 is offline
« newbie | P-2187 »
