Old 03-26-2006, 07:19 AM
LBJay's Avatar
Originally Posted by Solstice Lover
With the torque showing no signs of slowing down, you'd expect more hp as the tach rises.
Looking at the chart, torque starts dropping after 5300. Looks like they stop logging at about 5500. The small turbo is probably maxed out by then. Just one of the compromises.
LBJay is offline
Old 03-26-2006, 03:55 PM
That is true LBJay but we also know GM has this ENg in the mules making 300 BHP.
LatinVenom is offline
Old 04-09-2006, 12:28 AM
Originally Posted by brentil
This is a flywheel dyno and not a wheel dyno. It might also have mathmatical smoothing algorithym applied to it to make it look better for publication.
I'm certain it has SAE smoothing of like... 10.
Thraxz is offline
Old 05-11-2006, 12:09 AM
Send a message via AIM to Buzz Lightyear Send a message via Yahoo to Buzz Lightyear
Originally Posted by LBJay
Looking at the chart, torque starts dropping after 5300. Looks like they stop logging at about 5500...
The reason the HP and tq are dropping off is because they let off the gas at 5300RPM. Maybe that's what RPM they have limited it to in the tuning? Take away the RPM limitation (point at which they let off the gas), and extend the graph up, and here's what you get.
I know it might not be linear up to 7k RPM, but you get the picture. I'd bet GM is way underrating these by using a lower redline as their rating point.
Let me be the 1st to guess that bone stock, and moving the redline up to 7k in the ECM, it should dyno 240+ HP to the wheels, and that's at the stock boost levels. Throw in some race gas and up the boost about 6psi and it should see 300+ RWHP. Just .02 from a long time performance guy who has seen a few turbos in his day. (Check out my home page...) I could be way off on this, but that dyno graph they published jumped off the page, slapped me in the face, and told me it was time to reveal it's hidden secret. It's WAY too obvious to me that they quit the dyno pull at 5300RPM.
Comments?
Buzz Lightyear is offline
Old 05-11-2006, 05:11 AM
LBJay's Avatar
The GM graph is from an engine brake dyno. The engine is run at full throttle and the dyno places a load on the engine to hold it at an RPM and take a torque measurement.
LBJay is offline
Old 05-11-2006, 07:06 AM
Administrator
SolsticeMan's Avatar
Magister Solstitium Sum!!!
No, I'm not Bob Lutz...
SolsticeMan is offline
Old 05-11-2006, 09:15 AM
I realize it's on an engine dyno. They still have to quit making the dyno run at some point.
Old 05-11-2006, 09:53 AM
LBJay's Avatar
When they stop (close throttle) it doesnt take any more measurements. The dyno ploting ends at whatever RPM they set.
LBJay is offline
Old 07-11-2006, 02:19 PM
Does anyone know what the rod length is in the LNF? The stroke x bore lends itself to high RPM power, and if the rod ratio is high enough (1.70 - 1.75), this could be a KILLER engine with a bigger turbo. I have a feeling that the powerband is limited by the turbo. I would be disappointed if GM put short rods in it.
Spooled is offline
Old 07-12-2006, 03:34 AM
Assuming the deck heigth stays the same(I bet it does) theyd almost have to put in longer rods.
DugsGMs is offline
Old 07-12-2006, 07:35 AM
mena661's Avatar
Spooled,
Start a seperate thread for this. Maybe FrankC5R knows the answer to your question.
mena661 is online now
Old 11-23-2006, 11:33 AM
I have never seen a torque curve like that - that can't be for real
mbsolsticeguy is offline
Old 11-23-2006, 12:41 PM
mena661's Avatar
Magnaflow posted a dyno sheet showing stock and 3" exhaust. Check out the GXP section.
Old 02-03-2007, 06:29 PM
Originally Posted by WasRexPsiFi View Post
I am currently the owner of a heavily modified WRX, suspension, brakes, HP (>400). I don't *plan* on doing that again, but what a ride!
This GXP looks like my next ride. Just hope my WRX last long enough ... 400 + HP takes its toll over 60K miles. I am convinced turbos are THE way to go. Conservative gas mileage with an easy foot, but a blast of HP when you want. The WRX forums taught me what WOT means.
This torque curve is clearly limited by the ECU. Its easy to imagine simple changes to let it open up. This flat curve is definitely controlled by the ECU so someone will soon figure out how to reprogram.
D@mn you forums!!! My life was so simble, so ... ... boring before!!!
my thoughts exactly, only I have an srt4
masssrt is offline
